Question about Roper Dryers
There is water in my Roper dryer.
Water in my dryer. When I tipped it over, water ran off the top portion
    Top Expert:
  • Roper Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Dec 06, 2012
Not spin water
do you mean the lid switch is loose? 02 Control and Rear Panel Parts for Roper RAX4232PQ0
if it is broken -- you could bypass it 01 Top and Cabinet Parts for Roper RAX4232PQ0
take out the two screws on the top control panel edged and remove the panel - just tip it back-- see that squiggly metal piece in the edge -- use a flat screw driver and stick the end in the slot of the tip of the brass looking squiggly piece and relieve the tension. The top will now be loose and there is the lid switch
Jan 12, 2014 | Roper RAX4233PQ Top Load Washer
The cold water cycle is not working on my Roper washer top loader heavy duty
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
May 12, 2011 | Roper RAX4232KQ Top Load Washer
I press the start button and nothing happens. I ran the dryer yesterday and it worked fine.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Apr 23, 2011 | Roper Dryers
Roper top loader problem with a RTW43408q0. Washer wouldn't spin at first. I ran that cycle again. It filled with water and didn't agitate or drain the water at all.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 21, 2011 | Roper Washing Machines
Freezer is working but the refrigerator portion isn't
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 27, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
I am replacing a 3 prong cord with a 4 since we have moved into a newer newer home and the dryer has a white wire attached to the frame instead of a green wire. Is the the ground and can I just place the...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Aug 23, 2010 | Roper RES7646KQ Electric Dryer
Dryer Belt Roper RES7646
the front has to be removed to re place the belt lift the top takeout the two screws holding the front on unplug the door switch then kinda snap the door forward the drum should stay put and then but the belt on and you should find the pulley it fits in a slot in the bottom part of the drier put it in its slots pull it back to put tension it then let it back to keep tension on the belt
Feb 11, 2009 | Roper RES7646KQ Electric Dryer
Dryer not drying
Check your lint filter. Put it under running water to see if the water goes through it. Chances are it is clogged up. Wash it and put it back. Should do the trick.
SGt 48
Jun 18, 2008 | Roper Dryers
Dryers Logo
26 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
