Question about Tappan TEF242 Electric Kitchen Range
The oven element and the broiler element dont work and since i unplugged it it gives me a f30 code
    Top Expert:
  • Tappan Master
  • 9,472 Answers
F30 is for a faulty thermostat which would explain the elements not working. Here is the part to order.
Posted on Dec 05, 2012
Broiler element doesn't work
Reseating the Element The broiler is heated using an electric element which should be clipped in to the top of the broiler enclosure. If this has come loose then it might not be making contact with the necessary terminals. Try to reseat the terminal but before doing so you must ensure that the electricity is turned off.
Testing the Element The element is what heats up and cooks the food in the broiler. Over time the heat can damage the broiler element. These elements are supported by stand-offs and if the element burns out or becomes damaged then this can be a common reason why the broiler isn't working.
The easiest way to test whether this is working is to turn the broiler on and look at the element. If it is working correctly then the element should be glowing red.
Another slightly more complicated test for the broiler element is to remove the element from the oven and disconnect it. Then use a multimeter to check the continuity of the element. Set the multi-meter to measure resistance and then put it either side of the element. The normal measurement should be between 20 and 40 ohms. If the element is infinitely resistant then this means it's broken and will need to be replaced.
Testing Oven Controls Another reason why the broiler will fail to work is because of problems with the oven controls. A thermostat is used to set the temperature of the broiler, and the oven selector controls are used to control the setting of the broiler.
Turn the oven controls on to see whether the broiler is working properly. If not the controls can be removed and tested using a multimeter. Check the outputs to ensure that the controls are working correctly.
These can also be replaced if required by fitting a replacement part designed specifically for your oven.
Read More: Troubleshooting an Oven Broiler Doesn Work
Feb 09, 2014 | Thermador SEC302 Electric Double Oven
Cannot get oven to work
I need more info, dose the top buners work ? dose the broiler work ? Did you take a flashlight ad look over the lower cal-rod or element ? for damage get back to me on and off here all day and some nights till 9 pm
Dec 13, 2011 | Ovens
Maytag MER5755QAW Range and the oven will not Heat
You said the broiler element which is the top element is working fine what about the botom element, needto check it, i would say its probally bad, also before you do anything be safe and unplug unit completely before checking
Feb 18, 2010 | Kitchen Ranges
GE XL44 Oven and stovetop work - broiler does not work
The broiler is the top element in the oven. Look at it. Bad ones sometimes have burnt into or have a melted spot. If it looks ok take it out by removing the screws at the back and pull the wires out a little and unplug the element. With an ohm meter it should show continuity. Replace it if any of these things apply.
Feb 04, 2010 | GE Kitchen Ranges
When I turn my oven on bake the broiler element runs and eventuly the f2 codes comes on.
your oven uses fboth the broiler element and the oven element during baking. Since you know the broiler element works, you most likely will have to replace the oven element.
Oct 01, 2009 | Ovens
I have a ken more range and the broiler stay on the control for the broiler need to be replace but i don,t want to put lot,s of money in it i disconnect the top element can i use my oven to bake or do i...
NOOOOOOOOO
you may be able to disconnectr the element
after doing so trey heating your oven
some need the broiler to preheat properly some dont
b ut do not connect them together
Sep 18, 2009 | Kenmore Kitchen Ranges
Oven will not shut off broiler element stays on
The control knob more than likely operates a relay that has gotten stuck in the energized position. If this isn't the case then the Temp sensor or thermostat probably shorted internally. Unplug the unit before attempting any work.
Nov 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Tappan TEF242 Electric Kitchen Range Logo
89 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal De
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
