Question about Sony FWD50PX2/S 50 in. Plasma Television
Horizantal lines while showing the picture - Sony FWD50PX2/S 50 in. Plasma Television
    President:
  • 1,284 Answers
In most cases on a plama TV the upper and lower buffer boards will cause diagonal lines to appear in the picture in top or bottom half or sometimes both.
Posted on Jan 16, 2009
Panasonic plasma flat tv have picture and horizantal black lines
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Jul 02, 2015 | Panasonic Televison & Video
Xl 2400 replacement bulb---dim after replacement
did you use a genuine sony replacement bulb or aftermarket? Often the aftermarket lamps are not up to par with the OEM versions.
Nov 01, 2012 | Televison & Video
Black thick line going horizantal on screen can it be fixed?
Usually a bad board but someone has to open set and troubleshoot to decide which board is the problem.
Apr 08, 2012 | Sharp LC-26DA5U 26 in. HD-Ready LCD...
I haveMy compaq presario CQ40 and my monitor screen got flicker always for past few days and more red horizantal lines @bottom of the screen, where i couldn't see the data,time,date... Plz help me...
This is usually a sign of either a bad LCD screen cable, a bad LCD screen, or a bad display adapter.
If you connect an external monitor & you get a picture without these red horizontal lines, then your display adapter is OK.
Diagnosing a bad LCD screen cable or a bad LCD screen requires that you disassemble the LCD screen panel, & swap them one at a time with a matching part. This way you can identify which part is causing the problem & replace it.
Sep 02, 2011 | Compaq Presario CQ40 Series Laptop Charger...
Mitsubishi CS 40503
it is repairable and can be fix,,
Jul 30, 2008 | Mitsubishi CS-40503 TV
Sony kv32v15, Red screen with fine horizantal lines then shuts off
I would suggest to measure the 200 volt B+ at the CRT socket. If that voltage is found to be low, disconnect the socket from the CRT and measure again. If the voltage reading returns to normal you may have a defective CTR.
Also check for open or defective diode on flyback transformer for the 200 vdc source.
I would also suggest to take all the necessary precautions since you are working in a very high voltage area.
Good Luck.
Jan 14, 2008 | Sony KV-27XBR45 27" TV
Aiptekdzo-v58
no picture in screen black horizontal lines only appears
Jan 01, 2008 | Aiptek PVR Camcorder
Sony FWD50PX2/S 50 in. Plasma Television Logo
129 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
