Question about Ford Vehicle Parts & Accessories
My line is pinched on thpower steering near the filer can i cut it and put a hose and two clamps ther on a 1990 ford thunderbird super coupe
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 137 Answers
YOU CAN TRY...IF ITS THE HIGH PRESSURE SIDE YOULL HAVE TO REPLACE THE LINE!!
Posted on Jan 11, 2014
How much torque on head bolts&intake bolts on 1990 thunderbird super coupe
Here's a link to the head bolt torque specs.Here's the intake bolt torque.
Jan 13, 2013 | 1990 Ford Thunderbird
How do you remove a 1990 ford thunderbird steering wheel?
There will be screws/bolts around the outside(under some kind of covers), holding the center section on. after you get that off there will be one nut right in the center(remove that and pull the steering wheel(most of the time you need a steering wheel puller)
Feb 29, 2012 | 1990 Ford Thunderbird
The best way to change your power steering hose on a 2002 ford thunderbird?
Define best way ??
All you have is a bolt & o-rings on hose assy at rack
The rest of the system is spring clamps
The pump has a nut & a teflon washer
Jun 28, 2011 | 2002 Ford Thunderbird
Need a belt routing diagram for a 1990 thunderbird super coupe
There are 2 possible diagrams according to which motor is in the car. They are listed below:
#1
#2
Jun 05, 2011 | Ford Thunderbird Cars & Trucks
How to repair leaking fuel lines under the tank
Okay, prepare to get some gas on you. You need to drain the gas
You'll need:
1 pair hemostats or hose pincher
1 pair of wire cutters
1 screwdriver phillips or flat head
1 nut driver 1/4 inch or 5/16 inch
New fuel line. (cut 1 two inch piece and put the bolt in one end making a plug) = 2 inch plug
Hose clamps.
1 Bolt that will fit inside fuel line.(make line plug)
Pinch either side of the fuel line with hemostats. Cut the factory clamp off and pull the hose off. Put the 2 inch plug on the tank,and that will stop the gas from coming out. put a hose clamp on it if you want so it don't leak.
Now put a gas can under the pinched line and unpinch it and let the gas drain out of that tank.
When done draining , cut that hose off the tank and put it on the other side where that plug is. Remove the plug and put that line on and let that tank drain.
Once the tanks are drained., Just cut the hose to length and replace, using new hose clamps and new fuel line.
If your quick enough you can swap the hoses out without draining the tank.
You will get gas on you no matter what.
Dec 02, 2010 | 2000 Harley Davidson FLHTCUI Electra Glide...
How to replace power steering pressure hose
The hose connection at the steering box can be real fun. The best bet is to cut the line off close to this fitting. Then use a 6 point socket to remove the fitting. The other end is not a prob!
Mar 26, 2010 | 1990 Ford Thunderbird
98 Ford Escort (Mk6) Power Steering Cooling Tube Clamps
well to do it right u should replace the hose
Jan 28, 2010 | 1995 Ford Escort
Service manual 1990 Ford T-bird Super Coupe
Try the autozone.com website and register the vehicle information. They should have an online repair manual that will be of some help to you. It doesn't cost anything and is a pretty handy resource. Hope this helped and best wishes.
Oct 03, 2009 | 1990 Ford Thunderbird
Vehicle Parts & Accessories Logo
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
