Question about Targus (AWE55US) Laptop Cooler
Lap top cooler fans not working. Please help
When pug into USB port fans do not work
Take rubber strips off and then take screws out you will find a little circuit board with bad connection
Posted on Feb 03, 2013
How to Use Different Stand to Cooling the Laptop?
get a cooling pad / fan that runs off the usb port.
http://www.officeworks.com.au/shop/officeworks/p/deepcool-n6000-notebook-cooler-annbn6000
You know why they are called notebooks rather than laptops ?
Because they get really hot when placed on a lap !
Oct 18, 2016 | Computers & Internet
My lap top gets too hot and shuts down
1. blow into the intake vents with canned-air
2. obtain a 'cooling-pad' for a laptop your size
example of a mat-style cooling pad
Xcellon ChillPad Laptop Cooling Mat Gray Black
example of a fan-style cooling pad
Generic Mini Fan USB Cooler Cooling Pad 2 Fans For Laptop Notebook PC...
Oct 28, 2014 | E-Machines Computers & Internet
My Lap top cooler stopped working. When I plug it up nothing happens...
The fan may have failed, you will have to replace the fan or cooler. Check to see if there are any loose wires.
May 02, 2011 | Antec (NOTEBOOKCOOL) Laptop Cooler
Hp probook 4510s is getting too hot and then it's swithing off alone then i have to wait for 10 mins minmum to could switch it on again? i changed the silicon part and after 3 monthes it's doing the...
Well, first you need to take the heat sink off the cpu & take it a part, remove giant dust ball. Then put it back together, replacing the cpu "grease/thermal paste" with arctic silver or some equivlent. Depending on where you use this lapatop, you may want to get a fanned cooler, to put under it.
Apr 16, 2011 | HP ProBook 4510s Notebook
When I push the power button to power the lap top up the light display that says outlet power changes from green to amber and the laptop will not power up.
try removing the battery and just use plug power only if it boots normally then change the battery and the change the power supply unit as well I would just start with the power supply unit first then see if the battery charges up if not the battery is bad replace it. Now if the computer will not start with the battery removed then you have a power supply issue.
Change and replace it. Hope this helps. Also when computer lap top get hot they will shut down to protect the computer wait and let it cool down then try to restart your computer. If this does work and the lap top restarts normally get a fan cooler that is USB powered and the lap top sits on top of it. Also make sure the fan is running and is not stopped. Clean and dust it out once in awhile. I hope this assists you with your problem. John
Jan 22, 2011 | Toshiba Satellite Pro 6100 Notebook
When I play games in my Laptop, It runs for 10-15minutes and then overhetas and shut down........Please help me
If you boot just into the BIOS screen, does it still fail after 10-15m?
Can you hear a fan running? If not you need a repair shop to fix it.
Check that all the vents are clear of dust.
Make sure you are playing on a hard surface, not your lap or a blanked.
You can buy an inexpensive laptop cooler that goes under the unit. Some have fans that plug into the USB port
These questions will help you determine what is wrong.
Aug 09, 2010 | Acer Computers & Internet
Why is my laptop overheating?
You can try a Targus Lap cooler to circulate the air a little better. The fan may be working but just not as efficiently as it used to. You probably have noticed that it works longer and better in cooler rooms as well. A lap cooler will help with the cooling issue.
Jul 22, 2010 | Dell Inspiron B130 Notebook
Computer just powers off while on the internet. All virus scans done battery good it just shuts off while I am playing games.
a lot of laptops simply run too hot inside .. if you actually use in on your lap or on a pillow or blanket then you may be blocking the air intake ports .. or they could be clogged with dust. the internal fan may not be working .. if you run it on a table top and still have the trouble then i have had good luck simply by putting "stick on" felt pads that raise the laptop a bit more off the table top .. also there is a laptop cooler .. its a platform with a fan or fans inside that blow air into the laptop and keep it much cooler .. those are worth while on many laptop brands because it keep it cool and extends the life of the computer .. the platform often gets its power from a USB port or seperate adapter ... one i bought at radio shack folds up to almost nothing for transportation .. and didnt cost much .. it also worked very nicely to keep the computer cool ..many stores carry versions of the cooler so you have a wide choice ... the ones i have seen range from $15 to $29 ... and the lower cost one turned out to be the best (on sale) .. the nice thing is that you can use the cooler in bed or on your lap since it has air intakes on the sides that are spread out so you cant stop the air flow even if you block some ports.
Nov 22, 2009 | Office Equipment & Supplies
Do I have to have a wireless roator for my laptop?
you can buy a wireles linksys usb for your lap top and have a wireless router linksys stationary and the lap top usb ..... will pick up the signal for your lap top, i have a usb port linksys and it works great, but u do need a router in your home to pick up the signal
Jan 21, 2009 | Dell Latitude 100L Notebook
I have a new optical USB mouse but the windows vista on my lap top did not recognise it it sea it but need driver to install it i tried every sing on the lap top to find solution but failed regarding i...
Usually Vista does not need driver to install an USB Mouse.
Try this:
Turn off the laptop, then put the mouse connection. Turn on again. See if now it is working. The mouse should be connected in "off"
If still does not work, try put in other USB port of the laptop. Usually a laptop has at least 2 USB port. Remember to connect it always in "off".
Apr 03, 2008 | Computers & Internet
Targus (AWE55US) Laptop Cooler Logo
108 people viewed this question
Top Targus Computers & Internet Experts
steve morris
steve morris
dhnguyen
Are you a Targus Computer and Internet Expert? Answer questions, earn points and help others
