No video output from iDJ2
When I play a music video on the iDJ2 it does not go to the monitor. It has a S video line hooked up and the Ipod is set for tv out also it is on the direct setting. Hope someone can help.I sure would like to play vedos on a large LCD tv Thanks Eric
  • easyduzit1 Jan 13, 2009
    Numark iDJ2 plays video on Ipod hooked up direct but does not go to monitor. The ipod settings are on tv out and it is hooked to a tv monitor with a s video line, but only sound ....no picture to tv
  • 19,396 Answers
Ensure the video input selector on the monitor had been set up properly.
Posted on Jan 23, 2009
  • 81 Answers
Is the sound coming from external speakers or from the actual tv? If not coming from the tv then maybe you need to change video input setting. Check for INPUT selection button or tv/video button or something like that on the remote or tv itself. If the sound is coming from the tv then maybe it's a bad S-video cable. Try a different one if possible. Hope that helped.
Posted on Jan 13, 2009
    President:
  • 1,952 Answers
The Numark iDJ2, besides having an iPod dock which feeds both players, can also accept two additional USB 2.0 devices such as a memory stick or external HD. It also has provisions and switching to accommodate just about any analog component that uses standard RCA cables. A grounding lug exists in case one of those devices happens to be a turntable. The iDJ2's software can be user updated in the field via the USB ports which is a real plus for applying patches and upgrades.
OUTPUTS: The main outputs are standard balanced XLR connectors, My Cortex DMix-300 has only unbalanced RCA outputs. There is a pair of RCA analog output jacks that can be used for recording or feeding a signal to an alternative processor such as an outboard mixer, video camera or whatever. It was also interesting to note that there is also an S-Video output just in case your iPod happens to contain music videos. I don't believe the unit will play video files from outboard USB sources as the wide variety of codecs needed are not pre-loaded into the unit's internal software and the hardware is just not video capable. However, this is a really nice capability for those of you that own the newer larger iPods with up to 160Gb of storage and like music videos or picture slideshows.
Posted on Jan 12, 2009
    Sergeant:
  • 221 Answers
There is an S-video output to connect the unit to a TV, monitor or projector. This function only works with the iPod photo and (we assume) the new iPod video. =========== S-VIDEO – If using a video iPod, the iDJ² can output the video signal through this S-video port. Please use a standard S-video cable to connect to a TV, monitor, or projection device. This will enable you to display videos from your iPod. Note: Video from your iPod can only be output when Deck A is in iPod Direct Mode. See “iPod Direct Mode” for details . for everything as how to connect.--- where to connect.------- why there is no video everything is given in this link .just go through the chapters in the link it is clearly mentioned with diagrams.read it properly and connect as per the diagrams. http://www.numark.jp/pdf/manuals/idj2_english_reference_manual_rev1.2.pdf
click the above link directly. thank you for using fixya.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, to my understanding, the Video would only display if:
  • Deck A is in "iPod Direct Mode" only;
  • iPod direct Mode however will limit you DJ functions (loop/scratch, pitch/blend) since Deck A is just a controller for the iPod player.
Check and perform preliminary visual or necessary inspection. Pls post back result(s). Good luck and Thank you for using FixYa.
  • Louie  Role
    Louie Role Jan 13, 2009
    Appreciate the additional information.
    Based on that, pls try:
    • connect the iPod direct to the TV without the Numark. If it works, then the iPod and/or the TV as possible culprits would be eliminated;
    • alternately, connect temporarily another video source to the TV (say a DVD player) but play a VCD not a DVD video disc. This is to determine if the TV will play low resolution videos;
    • if all of the above works, then it would be the video interface of the Numark;
    • if any of the above does not work, then the iPod has some issues and/or the TV has.
    Pls post again results. Cheers.
    Sergeant:
  • 378 Answers
But do you get sound with the connection .if yes then just interchange the connections and recheck it will be not connected at the proper jack in the socket.
What kind of connection do need to hook up my idj2 to my pc?
None.
you cannot use it as a controller.
Songs can be plays from USB sticks/Disks/DVD players and Ipods
Jan 19, 2011 | Numark iDJ2 - DJ iPOD Mixer Docking...
I want delete songs from idj2 pls help
There are no songs on the IDJ2
Only on your Harddrive / USb stick or Ipod.
If you want to play songs via the IDJ2, you need the librarian software for using the IDJ2 in combination with you songs.
Dec 02, 2010 | Numark iDJ2 - DJ iPOD Mixer Docking...
Hi, My IDJ2 plays the music through my headphones and stereo but not at the same time. There is a delay in the stereo output. I have swapped stereos and headphones but no luck.
this is a common problem i have found with several units that have come through our shop. best thing to do is to get it repaired if it is still under warranty. If not ask them how much to repair it. I personally dont like these units but i do love numark. there are multiple videos on youtube explaining how to fix or bypass these with everything from firmware updates to hard mods.
Aug 17, 2010 | Numark iDJ2 - DJ iPOD Mixer Docking...
Im trying to connect a bsr xr eq to my avr687 denon receiver
If you want the EQ to affect the iPod music only, you can hook up the iPod output to the EQ input, then the EQ output to your receiver's AUX input (or DAT input, or whatever you're using to listen to iPod music.
If you want the option of using EQ for other signals as well, then you hook up the EQ to the TAPE inputs/outputs (TAPE OUT goes to EQ input, and EQ output goes to TAPE IN)
If you hook it up this way, then you have to select MONITOR or TAPE MON to get the equalized signal.
Apr 15, 2010 | Denon Audio Players & Recorders
Video won't work using the s-video connector.
Which iPod model are you using? Not all iPod models support video with the iDJ2. Check the iPod compatibility matrix document at www.numark.com/idj2 to see if your model is supported.
Sep 13, 2009 | Numark iDJ2 - DJ iPOD Mixer Docking...
I just got an idj2. I downloaded the firmware. I went through the library process, though I'm not sure what that really did other than take a ton of time. I hooked my ipod touch (16 gig) to the idj2 and it...
Dan... I hate to be the bearer of bad news...
Located at http://www.numark.com/idj2 there is a link called iPod compatibility matrix v1.6 this link tells you which versions of the iPod work great with the idj2 and which versions of the iPod make you want to pick up your idj2 and smash it against a brick wall. Sadly, the iPod Touch falls into the "smash" catagory.
Generation 1 iPod Touch devices can only be used in "DIRECT MODE ONLY" which means you can use them like a cd player or as a music source on 1 channel of the mixer of the idj2.
Both Generation 1 and Generation 2 iPod Touch devices are not supported to be used with the idj2 in "MASS STORAGE MODE".
Jun 10, 2009 | Numark iDJ2 - DJ iPOD Mixer Docking...
Still asks me to download librian
The idj2 doesn;t search off your ipod. you have to put libraries together with the librarian tool.
Here is a manual for your idj2 it's clear and will tell you how to import a library to your computer for search and play.
send me your email and I will send you a manual i downloaded steveb661@yahoo.com
May 18, 2009 | Numark iDJ2 - DJ iPOD Mixer Docking...
IPOD TOUCH DOES NOT PLAY
instead of using your itouch in the ipod deck, plug it to the white cord used to transfer music to your pc, and plug it in the usb dock, it should work because i've tried it with the iphone 3g
Feb 05, 2009 | Numark iDJ2 - DJ iPOD Mixer Docking...
Numark idj2
ok try this do you have a master rest of the idjr? if you do use it and see if this will re initialize the device.
Sep 01, 2008 | Audio Players & Recorders
340 people viewed this question
 Grubhead
Grubhead
