Question about Panasonic Dmr-XW380 Dvd Recorder
No sound playing dvd recorder or hard disk recording or freeview
TV sound OK when TV Freeview is used. No sound from DVD recorder. HDMI cables are OK. It was OK but now no sound. I may have changed something when connecting wireless earphones to the Panasonic TV using the headphone jack on the side of the TV
  •  Stanley Halliwell
    Stanley Halliwell Dec 06, 2012
    The earphones only cut the audeo off when plugged into the TV when the TV Freeview is used. No sound when from Recorder
  •  Stanley Halliwell
    Stanley Halliwell Dec 08, 2012
    I reset the TV to default and problem solved. The 3 HDMI channels now show on the TV video channel
    Top Expert:
  • Panasonic Master
  • 14,553 Answers
It is possible as when the jack is used with a plug into it, it is designed to cut the sound to the speakers in the set.
Posted on Dec 05, 2012
5 Suggested Answers
SOURCE: Panasonic DVD Recorder - Digital tuner stopped working
Is your recorder hooked up to the new convert box for digital antenna reception?
I am currently researching the convert boxes for my dvd recorder. I found that some dvd recorders already have digital converter boxes already installed. This might be the case for you.
Posted on Sep 28, 2008
SOURCE: panasonic dmr-es45v
The disc drive motor is burned out, its junk...if you didn't finalize the discs, they're junk too unless you buy another Panasonic DMR.
Posted on Feb 10, 2009
  • 39 Answers
SOURCE: Panasonic DMR-ES10 DVD Recorder- does not read discs
this unit has an optical-eye, not recording heads. opening the drawer then unplugging unit will expose the eye. never look into the eye when unit has power. this x-ray can and will burn your owh eyes lens&retina. good luck. clean with 90% isopropyl alcohol and q-tip. mch
Posted on Mar 09, 2009
SOURCE: I have a panasonic dmr-es20d dvd recorder. It has
This worked for me... In the "Others" section of the Setup options, set Quick Start to Off. Then select and confirm the Shipping Condition option. Power the unit down using the unit's on/off button then switch the unit off at the mains. After a few seconds, switch it back on at the mains then turn it on via the on/off button. On power-up, it should (eventually) start scanning, but this time it should find the channels. I usually only need to turn Quick Start off to force a clock update when the clocks go back/forward, but it would appear that with Quick Start enabled, the unit attempts to used cached info about the channel multiplexes, which was obviously invalidated by today's mux re-organisation. Hope it works for you too.
Posted on Dec 02, 2009
Why when playing dvd still receiving tv sound off freeview
The problem is probably in how your audio is liked up. Is the connection from DVD to TV via hdmi, scart, phono, RGB, optical? You need to check that the video link from DVD to TV and the audio link from DVD to TV are the same. Hope this helps.
Aug 26, 2014 | Panasonic DMR-EZ47V DVD Recorder/VCR
Can't tune in tv with dvd freeview.it states ext link problem
If you've connected the DVD to the TV via HDMI or SCART you shouldn't need to 'tune it in', just select the HDMI or SCART input. If your TV is also a Freeview device and you want to tune it to Freeview, where you have the aerial connected to the DVD recorder, you need to also connect the DVD recorder to the TV via an RF cable or aerial flylead so that the aerial signal passes through the DVD recorder. It's all in the instructions
Oct 16, 2013 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Cannot record from tv to DVD Can play pre recordecdvd's
You cannot record from the TV as the TV doesn't give an output to the DVD Recorder.
You can only record onto DVDs from an external source such as Freeview, Cable or Satellite Box.
Jun 12, 2011 | LG DR-4912 DVD Recorder
Vcr tape . does not record to dvd-r disc Using hdmi cable from TV to recorder.
It is a HDMI OUT on the DVD/VCR Recorder.
You can only record to a DVD/VCR from the External DVD/VCR Input (Connected to a Freeview, Cable or Satellite Box etc) or from one to the other.
Jun 09, 2011 | Magnavox ZV427MG9 DVD Recorder VCR
LG RH266 setup with freeview tv
Sorry to say no it wont not unless the Tv set manuel says it has a Duel Freeview feed , you have to get another freeview box for the recorder .
besides If you used the freview in the tv 1 , the tv would have to be on when you wanted to record ?. and 2 you couldnt watch another channel whilst recording another .. only 1 tuner ?. also you could only record the program you had on .at the time no timer facility .
People are still used to the Old system of VHs and the fact that all videos had tuners built in so you could watch and record .. It will come and indeed some more modern DVD recorder have freeview built in again sorry but thats the facts , and dont forget if you want the pay per view channels on free view your going to need a tuner with a pay card port ... Regards Vortash
May 12, 2009 | LG RH266 Recorder
Similar problem as you helped me solve before.
OK, I think I see the problem there.
The aerial lead from the DVDR to TV should be removed.
You should have it setup the same as the other Freeview - VCR - TV
Nutshell time:
Main aerial to Freeview input.
Loop aerial from freeview output to DVDR areial input (all this does is allow you to watch freeview, or standard both out of the DVDR)
So..
Scart from Freeview to DVDR input
Scart from DVDR output to TV
Set DVDR to AV input mode.
Set TV to AV (whatever number you need for that..you now won't get anything on screen unless you have the right input selected)
If you can now see the Freeview picture on the TV and change the channels with the Freeview remote then you should be set for recording.
Having the aerial and a scart lead both going to the TV is not needed.
Apr 14, 2008 | Philips VR550 VHS VCR
CNNECTING DMREZ27EB FREEVIEWDVD RECORDER, TO MY TV 2 SCARTS, AND MY PANASONIC VCR VIDEO RECORDER
I CONNECTED SCART TO TV 1 TO DVD FREEVIEW SCART 1, THEN I VCR SCART IN/OUT TODVD FREEVIEW RECORDER SCART 2, THEN RF CABLE FROM FREEVIEW RECORDER OUT TO VCR RF IN ,VCR RF CABLE OUT TO TV RF IN. RF SLOT IN ON FREEVIEW LEFT EMPTY THEN CHANGED TV TO AV 2 WHEN USING TO RECORD /PLAY EITHER VCR OR/ FREEVIEW DVD . I DO HOPE THIS HELPS SOMEONE. IT TOOK ME A WHILE TO SORT OUT REGARDS R. ELLIOTT.
Feb 22, 2008 | Televison & Video
Recording Problems
Hi.
Yes.
Most tv sets with freeview built in do not allow you to record it.
Check your tv instruction manual to see if it is at all possible.
http://dysonmanuals.llc.nu/
Chris..
Feb 09, 2008 | Televison & Video
Samsung Digital TV and Sony DVD Recorder
hi, did you find a solution? i have in built freeview and have bought a recorder but i cant pick up any freeview channels on it. the dvd recorder is a Wharfedale DVDRHD400 cheers tom
Feb 11, 2007 | Samsung 4 CHANNEL DIGITAL VIDEO RECORDER...
Panasonic Dmr-XW380 Dvd Recorder Logo
118 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
