Question about Dell S500wi 3D Ready DLP Projector - 720p - HDTV - 16:10 S500wi
Projecter over heating
    Champion:
  • Dell Expert
  • 225 Answers
Clean the filters?
Posted on Dec 06, 2012
Wheres the fan on a sony kf 200 u tv
there are several fans on this unit, but the one that seems to give most problem is the one right behind the LAMP. these usually fail because of the heat, age & the accumulation of dust. BE SURE TO VACUUM ALL THE DUST FROM UNIT in order for it to run cooler. Dust causes HEAT..HEAT DESTROYS ELECTRONIC COMPONENTS.
May 09, 2014 | Sony Grand WEGA KDF-42WE655 42" Rear...
Tv will shut off after 30 minutes- sony brand
try cleaning the filter. sometimes when the filter is dirty it heats up fast and shuts the TV down.
This is because the video ic is heated up and automatically shuts down to prevent overheating.
G
Jun 06, 2011 | Sony KP-57WS500 57" Rear Projection...
What kind of heat issue would my 56 inch projection tv have if after a couple hours shut off and on then then turns off . fuse, power supply . not sure
Sounds like it's possibly your convergence IC's overheating. On some projection tv's, after time, the solder joints on the IC's weaken from the heat and cause them to turn off the tv for it's own protection.
May 08, 2011 | RCA D56W20 56" Rear Projection Television
Samsung 47 inch Rear projection HCL4715W
Only If they are burted up,and no you should be able to use your heat Sinks.Rember to CK low ohm resistors samsung has 3 that can and do go bad. 2.7 or 3.9ohms
Jan 07, 2009 | Samsung HCL4715W 47" Rear Projection...
Cold room
Yes. The worst thing for electronics is Heat, it probably won't work better but it won't have any problems.
Dec 07, 2008 | Mitsubishi WS-55413 55" Rear Projection...
Mitsubishi rear projection tv color problem
I'm going to guess that this unit is a DLP projection set and that the lamp is not new. Try a new lamp. The heat of the lamp will char over time. If not the lamp, some of the internal filters in the light engine might be getting effected by heat and require replacement.
Keep us posted.
Dan
Sep 12, 2008 | Mitsubishi Televison & Video
Magnavox 9P5534C103
Its a common problem with model. Check the site www.TvRepairKits.com for a fix.
Aug 29, 2008 | Philips 9P5534C 55" Rear Projection...
Samsung HC-P4752W 47 in. Rear Projection bigscreen TV
You dont have to remove the aluminum heat sink. The ICs are attached with screws and then just unsolder the ICs from the circuit board and then replace the new ics into the pin hole locations after applying heat sink compound onto the back then screww the new ICs to the heat sinks then solder the pins. Very easy repair.
Jun 19, 2008 | Samsung HC-P4752W 47" Rear Projection...
Convergence IC,s overheat
the ic is getting too much voltage check a diode that feed into the ic it has a short.if you dont locate that defected component it will cost you much more than the set lol.good luck
Apr 23, 2007 | JVC AV-56WP74 56" Rear Projection...
Dell S500wi 3D Ready DLP Projector - 720p - HDTV - 16:10 S500wi Logo
37 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
