Need to know if I need dtv converter for my Samsung combo tv
  • 4 Answers
If you are using a cable TV or satellite service to get your TV content then you do not need a dtv converter.
You only need a dtv converter if you use an antenna to get your TV content and you do not have a digital TV with a internal digital tuner.
If you have the model # of your TV I can look that up for you if you are unsure.
Posted on Jan 12, 2009
How record tv chanels using the DTV converter box? The converter box determines the chanel of interes while the DVD recorder must remain on chanel 3 in my area. My DVD recorder is a combo with a VCR...
Can you connect directly from the DTV converter to the DVD recorder input using RCA phono connector cables? You'll have to select the input on the recorder menu as well.
Oct 21, 2009 | GoVideo Go Video DVD/VCR Combo
Have digital TV have 3 yr old sony VHS VCR DVD player combo
A DTV converter box will take digital broadcast signals from the antenna and convert them to a format compatible with the VCR. You will be able to record programs received through the DTV box on your VCR if you could record analog over-the-air programs before the digital changeover. You can use either the RF output or the component output from the DTV box to input to the VCR.
Jun 30, 2009 | Quasar VHQ400 VHS VCR
Want to run my dtv receiver through new digital converter box.
You will not be able to record local station from a DTV converter connected thru a directv receiver unless there is a a/v input on the directv samsung receiver. Also check the user manual for this receiver if recording from an external source such as a DTV converter box is possible. The answer to seperating the DTV converter box from the directv samsung receiver is possible if your tv has multiple inputs. Try connecting the DTV box to the RF input and the directv samsung box to an a/v input then change inputs using the tv remote. you will need an av cable (yellow/ red/white) for the directv box and a rf jumper cable for the DTV box.
May 17, 2009 | Samsung SIR-S4040R DirecTV DTV Receiver /...
DTV Conversion Question
Yes you can connect a DTV converter box in your van.
If the TV is DC powered you will need to buy a DC to AC inverter, like these http://www.dcacpowerinverters.com/12_volt_power_inverters.html because there are currently no dc dtv converters available.
If the tv is ac powered you will only need to connect the converter to the inverter the tv is connected to.
If you need more help or installation instructions let me know.
Please rate this solution.
Lone99star
Apr 03, 2009 | RCA R52WH73 Projection Television
TV Guardian menu won't come up after hooking up DTV converter box
You may want to check the digital converter boxes and make sure they have analog pass through, it should be listed on the box or the instructions. My Magnavox and Zenith which were bought about a year ago, do not have analog pass through.
Feb 23, 2009 | JVC DRMH20 DVD Recorder
Do I need converter box for my 6720FDE Sylvania?
HOW DO I SWITCH FROM CABLE INPUT TO ANTENNA WITHOUT REMOTE ONLY HAVE USE OF BUTTONS
Jan 06, 2009 | Sylvania 6720FDG 20" TV/VCR/DVD
Magnavox 27mdtr20 17
The Magnavox 27mdtr20/17 is a standard def. television produced in 2003 by the Philips-Magnavox Corporation. This particular model was conceptualized long before DTV was an option, and much further before Digital Television Broadcasts were considered a viable option for our current current communications problems.
You will need a DTV box IF:
A) You use an antenna (roof top or otherwise) to watch television
You will not need a DTV converter box IF:
A) You subscribe to cable services, either analog or digital
B) You subscribe to satalite services
For more information on the reasons behind the DTV transition, as well as getting valuable cupons from the federal government to help subsidize the cost of a DTV box, please visit this site:
https://www.dtv2009.gov/
I hope this helped,
Remy
Dec 23, 2008 | Philips 27MDTR20 27 in. TV/VCR/DVD Combo
I need to know if the rca 27f500tdv needs a dtv box for signals
If your set is less than two years old .. you will have a digital tuner and will not need a converter.Only older sets with analog tuners will require a converter box.
Dec 05, 2008 | RCA 27F500TDV 27 in. TV/VCR/DVD Combo
Converter box
if you do not have cable, fios or directv you will need the converter box
Oct 08, 2008 | Sylvania 6313CB 13 in. TV/VCR Combo
Do I need a dtv digital converter box for my Symphonic SC313D 13 inch tv?
Pretty much a hoax on those diverter boxes. People ran out and bought them thinking that won't have reception. I have many years in maintenance and several years in nursing homes with different tv's in every room. Not once have I needed a box to pick up channels with or without cable. I myself get 16 channels with rabbit ears and thats enough for me. And I do own a combo as well and it has simple antenna and does me just fine. Depending on your location, the old tv antennas we use to put on our houses...they work amazing! Might be able to snag one on a freecycle or craigslist site. Good luck! :)
Jun 05, 2008 | Symphonic SC313D 13 in. TV/VCR Combo
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
