Question about Dishwashers
I have. Kitchen aid dishwasher that will not run. Control panel flashing (see video) and can't be set. I ordered and replaced the ctrl board, but this did not fix.
Flip the breaker for 30 seconds turn back on. If still blinking, push and hold start up to 30 sec. one or the other should alleviate you issues
Posted on Dec 05, 2012
  • 1314 Answers
SOURCE: Replacing detergent dispenser on Kitchen Aid Model KUDI24SEAL3 Dishwasher
send me an email at b4829@yahoo.com and ill send inst
Posted on Mar 19, 2008
  • 171 Answers
SOURCE: Front panel on Kenmore Diswasher
Hi jenniferr922,
I'm Harvey the Master plumber.
Your question is: You purchased a white Kenmore dishwasher and you are redoing your kitchen and all of your appliances are Kenmore stainless steel. You were wondering if the front panel was the only replacement or if you needed to order something else for the control panel.
It's your choise. If you like the control panel, keep it. If not, replace it when you replace the white panel.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 13, 2008
aborcass
  • 2651 Answers
SOURCE: Kitchen Aid dishwasher Child lock light on and dishwasher will not start.
if your unable to unlock the "childlock" by holding down the button, then it woud seem that theres a problem with the user interface itself
Posted on Oct 19, 2008
  • 3 Answers
SOURCE: Cancel Light Flashing on Kitchen Aid Dishwasher
I ran into this same problem. Cutting the power didnt reset it.
After power reset, mine had the normal led blinking. If I pressed cancel, then the cancel and china button leds would start blinking too.
I pulled out the trouble shooting guide (from behind the baseboard kick panel under the dishwasher door). It that if the dishwasher wont run and button LEDs are blinking there is a short circuit in the keypad. It gave a keypad diagnostic sequence which I followed. (disconnect keypad and try to initiate the diagnostic cycle without the keypad by disconecting the yellow leads to OWI sensor twice in less than 6 seconds.
I could hear the diagnostic cycle start, so the problem is a bad keypad. Will order a new one tomorrow and let you know if it works.
Posted on Apr 27, 2009
  • 246 Answers
SOURCE: Want to replace dishwasher panel with stainless steel
Yes indeed! If you know the measurements, you can buy a stainless panel from www.applianceart.com cut to any size you would like. THey also have a cheaper "faux" stainless option too. Many colors and designs as well.
Posted on Feb 25, 2010
My Maytag dishwasher cycles seem to be confused. it beeps throughout, runs all day or won't turn on at all
control board issue probably, not made to last anymore
press the helpful button and follow me on Fixya for more good tips
Jan 27, 2016 | Maytag Dishwashers
My Kitchen Aid Dishwasher model # KUDS40FVSS0 has blinking cancel, sani-rinse and normal wash lights. It will not run at all. We replace the control board and still nothing. Please Help!!!
I have had this problem. Mine didn't work for over a week and by the time the repair man came over to 'replace the board' it suddenly worked. The guy told me that if you use ANY type of liquid dishwashing soap (for your sink) and any residue/bubble is on the dishes, it can cause your dishwasher to break. I have no idea why but I've been really careful to make sure I wasn't using dish soap prior to putting them in the washer.
I've had 3 service calls on this dishwasher since I purchased it 3 years ago. I'm having similar service issues with my Kitchen Aid Fridge. And of course no help from Kitchen Aid.
Sep 25, 2013 | KitchenAid Dishwashers
My kitchen aid dishwasher will not start I replaced the interface control board thinking that was the obvious problem. When you go to set the dishwasher to start some of the settings don't always light up...
check all cables especially the ribbon cables from the user interface to the electronic control assembly as steam from dishwashings will create small amounts of corrosion and inhibit signals to and from these 2 components,unplug each,inspect,and reconnect,if this fails,then replace the electronic control assembly located behind the user interface you previously replaced
Mar 23, 2011 | KitchenAid Dishwashers
What is the reset sequence of a kitchen aid kudi01fl my dishwasher wont start the control lock button is on
Press and hold the heated dry button for 5 seconds to unlock the controls. If that doesn't work go to the link below and it will tell you how to reset the control board.
http://www.appliancerepairlesson.com/dishwasher-2/dishwasher-clean-light-blinking-7-times/
Good luck
Mar 01, 2011 | Dishwashers
I little puff of smoke came from my Kitchen Aid Dishwasher Model 8531654 and now is not working. The lights are on but it never cycles through.
Sounds like the motor when ka-fooeey! Have a technician check the motor with a volt-ohm-meter to make sure that that's the problem.
Feb 23, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
None of the lights work on control panel, stainless steel top line kitchen aid dishwasher. won't run. won't do anything. no response
Check the power source to the machine.
If all power connections to and within the machine are O.K. then, it is most likely your door switch or worst case, the control board.
Best to get a technician to diagnose the problem.
Ash
Oct 22, 2009 | KitchenAid Dishwashers
"Normal" light flashes
You need a new control bd. #W10084141. If the diagnostic mode will not work then the board will have to be replaced.
Mar 06, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Mar 03, 2009 | KitchenAid 24 in. KUDS25SH Built-in...
Dishwashers Logo
99 people viewed this question
Top Dishwashers Experts
