Question about GE DBXR463GB Gas Dryer
Drum won't turn with load of clothes in it
Put new belt and pulley on. Checked front pads and back rollers. Motor turns, belt slipping.
    Top Expert:
  • GE Master
  • 14,553 Answers
Wrong belt or does the unit have a belt tension unit that adjusts tension on the belt?
Posted on Dec 05, 2012
vanni7
  • 163 Answers
SOURCE: dryer belt snaped
Hi!!! Make sure you install the belt correctly maybe this can help you..2447c24.gif
Posted on Jan 04, 2009
  • 11 Answers
SOURCE: GE profile model # DPSQ475ETWW or ET0WW drum belt slipping
the rubber side should be on the drum
Posted on Jan 11, 2009
larryyb
  • 291 Answers
SOURCE: need to know the exact
with belt around drum, pull idler back with tension on it and put belt over pulley of motor and let idler up against belt and it should be right ,,,, larryyb
Posted on Dec 10, 2008
dragonsthatk
  • 547 Answers
SOURCE: Drive Belt replacement for GE DDE7200SBLWW Dryer
http://www.partstap.com/ please go here for diagram thank you please rate me
Posted on Feb 22, 2009
beltronic205
  • 1461 Answers
SOURCE: My dryer squeaks loudly when running. I have
Yes .I would say its the jockey pulley @ fault..
Posted on Nov 26, 2009
Dryer drum won't turn
Hi
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley.
Note: This method works for most front loading machines.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place, some seals are furnished with the cement to glue it in place.
Remove the electrical console that holds the timer switch,start switch, etc. from the top of the dryer if necessary. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the two screws that hold the filter housing to the top of the dryer lid.
Then remove the top of the dryer by inserting a screwdriver between the top and frame on each side of the dryer to pop the lid up from the retaining clips.
Note: Some of the tops tilt backwards on a type of hinge and do not have to be removed completly.
Remove the front of the machine by disconnecting the door switch and removing the two screws located on either side of the dryer frame.
Move the door and front of machine forward to remove.
This will expose the belt,idler bracket and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
Note:The way the belt goes back on is, as the belt comes off the drum has to be doubled (pushed together to form a loop) and goes under the idler pulley then to the motor pulley.
Here is a link to see a picture of your belt routing in case the belt is broken when you open your dryer:
http://www.expertappliance.com/dryerbeltconfiguration.html
While you have the drum out, I would recommend that you remove and lubricate the drum rollers.
And also clean the shafts of the rollers as they will collect hair,dust,etc and cause problems and then lubricate the shafts and rollers with a good grade of machine oil like 3 in One oil or a vasoline type of lubricant. This will save you a problem later with the rollers getting dry and making a squeeling noise, also check your drum rollers for flat spots, if they have flat spots on them this will cause a thumping type noise.
You will need to replace the drum rollers if they have flat spots on them.
Please take time to rate me
Oct 04, 2012 | Whirlpool WED4800XQ Traditional Electric...
Maytag atlantis gas dryer turns on,gets hot but the drum won't turn
Hi raddis...
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley or a faulty motor.
Remove the lint filter and the screws that hold the filter housing.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil or a vasoline type of lubricant. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
This is a FREE answer, Please take time to rate me
May 16, 2011 | Maytag Atlantis MDG6400AW Gas Dryer
Whirlpool dryer model LE5800XSW3 Tub won!t turn , Dryer had a high pitch whine for awhile before it quit.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Then remove the top of the dryer.
Note: Some of the tops tilt backwards and do not have to be removed completly.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Note:The way the belt goes back on is, as the belt comes off the drum has to be doubled (pushed together to form a loop) and goes under the idler pulley then to the motor.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
This is a FREE answer, Please rate me
Apr 14, 2011 | Whirlpool Dryers
I can see the heat come on but there is no rotation of the clothes the bucket that holds the clothes is not rotating
If you have to replace your drum belt and if you have a front loading machine.
Be real careful not to knock any of the wires off of the timer switch.
Pay attention to the route of the belt,this will come in handy when you go
not to turn.
on them this will cause a noise like a thumping type noise.
Please rate me
Dec 09, 2010 | Kenmore 62802 Electric Dryer
My dryer drum does not turn during drying. The belt is not broken and the dryer is heating the cloths. Why has the drum stop turning?
You could have a faulty motor, or maybe the belt has slipped off of the idler pully or motor pully
Sounds like your problem may be the belt may have slipped off of the motor pulley, or idler arm pulley, or maybe a faulty motor.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer some slide off.
Then remove the top of the dryer,some are clipped on,others slide off.
Sometimes the belt will slip off of the idler arm or motor pully causing the drum
not to turn.
If you cannot find the proble there, then maybe the timer switch is faulty and needs replacement.
NOTE:
Free answer...Please rate me
Dec 06, 2010 | Dryers
Drum wont turn
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good luck,
I hope this helps
Please do not forget to rate me
Thank you
May 26, 2010 | Dryers
My clothes dryer squeaks when it runs. If I dry
Good luck,
I hope this helps
Thank you
May 19, 2010 | General Electric DCVH640GJ Gas Dryer
Heating but drum does not turn
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley. If you have to replace your drum belt and if you have a front loading machine. Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer. Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum. Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn. While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them. I will include these two websites for parts and further help:
http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7.
Good luck, I hope this helps Please do not forget to rate me Thank you
Dec 26, 2009 | Estate TGDS840JQ Gas Dryer
Tumble will not turn the belt was off but now put it back on still not turning altho motor at bottom is
if the motor is running, the belt is on but the drum is not turning then either the belt is slack and slipping, or the drum is jammed. possibly and item of clothing is stuck between inner and outer drums. remove belt and turn drum pulley, it should turn easily.
Nov 01, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
The dryer won't turn, it is only 18months old.
Check your belt from the drum to the dryer, it sounds like the belt has come off of the idler pulley or the motor.
If you have to check your drum belt and if you have a front loading machine.
While you have the drum out, I would also recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
Good luck,
I hope this helps
Oct 15, 2009 | Frigidaire Dryers
GE DBXR463GB Gas Dryer Logo
289 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
Sal DeAngelo
Are you a GE Dryer Expert? Answer questions, earn points and help others
