Jamo Cornet 90 IV Speakers - Woofers need replacement
Kindlyrecommend suitable replacements for the Woofers, and therir source.
Thanks.
  • sratra Jan 12, 2009
    The Woofers of my Jamo Cornet 90 IV Speakers need to be replaced. I need suitable drivers(only woofers) that will match the Jamo Cornet 90 IV Speaker Cabinets and technical specs.
Replacement woofer for polk audio monitor 70
Posted on Feb 19, 2009
I had the sub woofer problem what i did was i found the fuse in back of the unit i took it out with a srew driver. I looked in the light to see if the tube had a smoke shot in it and it did then i got some aluminum foil just a tiny piece and put it around the tube and low and behold my unit pop back on what a relief. The foil is for testing only you need a fuses to not cause a fire!
Posted by charles on Jan 12, 2009
Posted on Jan 12, 2009
Replacement remote for Jamo 360 soundbar
Amazon.com: Replacement Remote Control for JAMO TORSTEN 360 ...
https://www.amazon.com/Replacement-Remote-Control-JAMO.../dp/B01E67NI6U
This is a custom built replacement remote made by Redi Remote for the JAMO remote control number TORSTEN 360. *This is NOT an original JAMO remote ...
Replacement Remote Control for JAMO TORSTEN 360 ' eBay
www.ebay.com > ... > TV, Video & Audio Accessories > Remote Controls US$38.81 - ‎In stock
This is a custom built replacement remote made by Redi Remote for the JAMO remote control number TORSTEN 360. This is NOT an original JAMO remote ...
jamo replacement remote ' AVForums
https://www.avforums.com > ... > Home Cinema Speakers Oct 5, 2014 - Hello, I have jamo p102 speakers. Unfortunately the remote is broken which means I can't control the speakers at all now. It can't be fixed. Is it... Replacement remote for Jamo 360 soundbar Google Search
Feb 01, 2017 | Jamo Audio Players & Recorders
Why won't my a102 speakers from jamo witch came
The Jamo speakers need an AV Receiver to drive them properly. The TV doesn't have the correct outputs nor does it have the power required.
The Jamo kit consists of a powered subwoofer ans 5 small surround speakers. Each surround speaker needs to be powered by the speaker output from an an AV Receiver. The subwoofer should also be connected to the receiver, but the connection is a phono/RCA lead from the receiver's "Sub Out" socket.
Your TV connects to the AV receiver via the Optical out.
Sep 01, 2014 | Audio Players & Recorders
Need to replace 5.5" woofer in Jamo S426 floorstanding speaker
contact maplin electronics they are really good at replacement units.
Jun 30, 2012 | Jamo S426HCS3 5pcs Home Theater Speaker...
I have Imperial 4 speakers circa 1971. One of the woofers popped the center black cap and is now fuzzy at moderate bass levels. Can I get a replacement speaker somewhere? Thx, Rich
I do most of my vintage audio shopping on eBay.
You could probably get a whole pair of them for less than sourcing the individual woofer.
http://cgi.ebay.com/Marantz-Imperial-IV-Speakers-model-4-nice-cond-/290510404317?pt=Speakers_Subwoofers&hash=item43a3c4fadd
Ends Dec 15, 201019:15:17 PST - Right now at $15.00 with $15.61 shipping.
Or maybe you just need to refoam them....
http://www.simplyspeakers.com/marantz-speaker-foam-edge-repair-kit-fsk-3.html
At $26.00 for this kit, I'd opt for whole speakers.
Dec 08, 2010 | Marantz Audio Players & Recorders
I own jamo speakers CL 30. One of the woofers is broken. Can i find anywhere one woofer to replace it?
Best to have it reconed ! The speakers need to be matched pair.
If you are using these for music instrument(s) make sure they are intended for that use. Home stereo speakers won;t take the power that music instrument speakers are designed for by a factor of say four.
If these are mis-applied, don't waste money repairing, but buy instrument grade cabinets.
Dec 26, 2009 | Music
One Tweeter died, burned... could I replace it? Where I find it? How much it cost? Thanks
I could be replaced even if not the original what make and modle is it Pro Line Music 215-736-8055
Dec 11, 2009 | Jamo Cornet 145 Speaker
Jamo Cornet 90IV
not sure what size you need but dayton audio subs are pretty killer check them our parts express usa, i a have a set of realistic mach ones with one of my drivers blown i did some searching and found parts express, due to rave reviews and the specs on what i look for in subs dayton is the way to go,happy hunting-z
Jan 10, 2009 | Jamo A4SUB Car Speaker
Defect woofers
If you can get the same woofers, then yes you should be OK, pull the units, get the part number off the back and then try Google for a source.
If you can't find a exact replacement then you are looking at replacing all of the woofers, rule of thumb is that you do not want to mix speakers, you end up having one speaker sounding different than the other, so what ever you do to one, you need to do to the other. In that way what tonal changes that happen will happen to both speakers and they remain matched.
Now if you need to find replacements, you need to replace with like impedance speakers, and try to find a speaker very similar to what you are replacing. Just don't throw anything in the cabinet, if the impedance isn't correct not only the sound could be bad, but you could also damage your Amp or Receiver.
john
Aug 17, 2008 | PSB Image 4T Speaker
Technics SU-X955 amplifier. which speakers ?
Helo you have to use speaker of the same wattage you have now chage crossover to get new clear digital soud
Feb 11, 2008 | Technics SUV500 2-Channel Amplifier
1,236 people viewed this question
 Grubhead
Grubhead
