Kenmore washer model #417.42042100 is not spinning the clothes all the way.
The washer washes the clothes fine but the final spin will leave the clothes full of water. I try to re-spin the clothes on final spin and watch it. The washer starts the cycle and acts like it is in a draining cycle then starts to spin to ring out the clothes and stops. Then it starts tumbling like it washing without water.
  • Carl Turley Dec 15, 2012
    The pump filter was the clean and I still have the problem. I did find out that I had a broken shock and replaced the shocks.
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
First you need to open the cabinet and remove the boot from the tub to the pump and clear the filter. Try that then run a cycle and post back the results.
Posted on Dec 05, 2012
5 Suggested Answers
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
  • 1294 Answers
SOURCE: Kenmore front loader
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
And pl rate me if helped.................
Posted on Jan 24, 2008
SOURCE: Kenmore front loader washer
you need to replace the speed control unit (board) in the lower right corner in the back of the washer it is faulty
  • 111 Answers
SOURCE: will not drain and spin....stops ..will only start wash and stop.
check the lid switch if is clicking if not try to by pass the switch
Posted on Jun 18, 2009
Kenmore 417.43142200 final spin is slow
obviously the timers contacts are bad so replace the timer.
May 16, 2017 | Kenmore 43142 Front Load Washer
Wet clothes
the reason the clothes are wet is the washer is not shifting to high spin,does the washer have a speed switch(normal wash spin,high wash spin)if its not the speed switch than the clutch is bad,how old is the washer?mike
Apr 19, 2009 | Kenmore 24032\24036 Top Load Washer
Model 110 washer will not go into a final high speed spin.
hi, i would suggest the timer/programmer is faultyas it is ok on the other cycles, the noises you have described may have caused some damage,
Feb 10, 2009 | Washing Machines
Drum speed slow on final spin
what waher is this and what speed is it
Dec 05, 2008 | Kenmore 46462 Front Load Washer
Spin water from clothes
i also have a kenmore model # 110.23832100. It drains the water but does not spin leaving the clothes soaked.
Jul 07, 2008 | Kenmore 23822 Top Load Washer
Washing Machines Logo
206 people viewed this question
Top Washing Machines Experts
