Question about APC Smart-UPS RT 5000VA (SURTD5000XLI) UPS System
Apc smartups will not power up
No logic power when input breaker closed
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 91 Answers
Have you check the battery, SURT UPS will not on if the battery is totally drain.
Posted on Feb 20, 2013
5 Suggested Answers
DosHog
  • 168 Answers
SOURCE: problem with SmartUPS SU5000I
Before trying to replace an IC, make sure that the battery is capable of holding a charge. If there is more than 1 battery, check all. If it (they) are bad, it will probably be less expensive to replace the unit.
Posted on Jul 24, 2009
  • 59 Answers
SOURCE: APC SMARTUPS 1500VA Battery Problem When Replaced
You are correct. The APC Smart line has a partial charge when it's new. Similar to cordless phones, the work right away, but you're still supposed to charge them before use for best results.
Just leave it plugged in with no load for a couple hours and it will be fine.
Posted on Sep 23, 2009
SOURCE: My APC SmartUPS 1000 wont turn on
It sounds like a relay inside. I found that if I bump the UPS like pick up the front or back & dropping it about 2" or tipping it and letting if fall back level it'll finally kick back in. This makes me feel the relay has gone out. Maybe during it's test procedure.
Posted on Mar 28, 2010
tech240
  • 169 Answers
SOURCE: APC SmartUPS 3000VA
APC do not release cct diags and these are not easy to repair, if the battery fuse was open and there is some board damage, the thing is toast. Even if you get it going the battery will not be able to be calibrated, unless there the board/processor is 100%, I know this as we have a similar model on the bench right now with new batts in and the unit will not recalibrate, so even though the batts are new, as soon as the mains is dropped it goes to very low battery and shuts down in 2 mins.
Buy a new UPS save yourself a lot of time. Hope this helps
Thanks for using FixYA
Posted on Aug 02, 2010
How i can change input configuration of APC SURT15KRMXLI from single phase to three phase
http://www.apcmedia.com/salestools/KCHY-94P5CN/KCHY-94P5CN_R0_EN.pdf?sdirect=true Try page 6 of this document. It shows the connections and jumpers required. Make sure changes are made by a qualified electrician/technician who knows what they are doing so as not to damage UPS and not receive electric shock
Oct 14, 2015 | APC SMARTUPS RT 15KVA RM 230V...
I am looking for the battery wiring diagram for APC smartUPS 2200 Rackmount
Check out the link below. He claims that the PCB schematic for the 1400XL appears to be the same as the 2200 because he owned one. It's worth the explore. I have attached the schematic for the 1400 XL that when you go to the site, you can click on and enlarge then download
http://techno-fandom.org/~hobbit/power/dumbups/
Feb 07, 2015 | APC Computers & Internet
Why does an APC Smartups 30kva have high battery temperature alarm?
UPS should be located in an environment where the temp should not exceed 25 degrees Centigrade, or you may have a damaged fan (inside the UPS, or the temperature sensor is defective.
Jun 09, 2014 | APC SmartUPS VT 30kVA Rackmountable UPS ...
APC SmartUps SU1000I NET After we hit the power (I
The possibility of changing UPS code, so its capacity is smaller, the solution must first be returned to its original settings on PC via Hyper term,
or the relay damage, or overload
Oct 19, 2013 | Computers & Internet
No logic power when input breaker is closed
double check your batteries, SURT UPS wont turn on if the battery is totally drain
Dec 05, 2012 | APC Smart-UPS RT 5000VA UPS System
@MY APC UPS SURT15KRMXLI is not charging after installation on single phase input
we have installed a new ups but the battery light indicates red light even though its on charge
Aug 12, 2011 | APC SMARTUPS RT 15KVA RM 230V...
My ups 1000 watts suddenly get off for few minutes than again starts itself .it happens 2-3 times in 24 hours.
Back up devices on the computer creates copies of every new features that are performed. The backup devices default settings may allow to save data every often like 2-3 times in 24 hours. also, the backup devices save settings can be altered to suit user speciifcations. for example, important projects on important files may require to save every few seconds lest any malfuntion that occurs to the computer is misplaced. back devices are considered external structures and should be locate on the computer systems control panel area with a unique description. Clicking on the backup devices logos would allow to manipulate either create urgent backup or space the backup to make the computer faster where back becomes attainabel durign idle hours.( for example, set the computer backup to first tthing in the morning or last at close of computer usage.)
Feb 05, 2011 | APC Back-UPS RS 1000VA UPS System
APC SmartUPS 3000VA
Aug 02, 2010 | APC Smart-UPS 3000VA UPS System
Problem with SmartUPS SU5000I
Jul 24, 2009 | APC (SUA3000I) UPS System
APC Smart-UPS RT 5000VA (SURTD5000XLI) UPS System Logo
304 people viewed this question
Top APC Computers & Internet Experts
Shawn DuRee
Electro Med Services...
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
