Question about Sewing Machines
Instructions needed for jml gem styler
Have got gem styler jml but no instructions
Serger tension is off and I can't get it adjusted properly. I have a Necchi Lock machine that is 25 years old and it's been a gem. Do you know how to adjust the tension?
Do you still have the instruction manual for the machine? If you do, you get a great big gold star!
Unless this model has auto tension, there should be a tension knob or lever on each thread feed.
Open the tensions (set at zero). No access to the tension controls, raise the presser foot and this will open the tensions, if the controls are okay.
Re-thread the serger and then set the tension controls back to mid-range or lower the presser foot to re-set the auto tension function.
With the presser foot down, stitch a chain of threads and if they do not "knit" as the should - the serger needs to visit a repair shop.
Service for a serger usually begins around $100.
It could be just the timing needs to be adjusted.
If the tension controls need new springs or the controls needs to be replaced, this will add to the repair cost.
Mar 29, 2010 | Sewing Machines
Do i need to put oil in my huskystar 224 sewing machine If so where do i put it in the machine
Check your user manual. More than likely there are a couple of holes along the lower part of the machine where the material goes (throat of the machine). Usually oil goes in those holes but only a drop. The best oil is from the bicyle shop used to oil chains--Tri-Flow. I have a huskystar 217 for 5 years and have never felt that it needed oiling. Sews like a gem.
Feb 09, 2010 | Sewing Machines
How do I thread my Janome Gem Machine?
if you have a manual the instructions will be in it if not, janome usally color code threading instructions on the machine itself
Nov 23, 2009 | Sewing Machines
Sewing machine has no foot pedal control and operates immediately when power is connected
i believe you need to break that circut
if you cant find the working foot pedal
maybe you could use a tattoo machine gem footpedal
they are breakers fairly cheap online and very manuverable when in tight spaces....
Oct 19, 2009 | Bernina Sewing Machines
Pinnock trendsetter gem threading problems
This is a British machine, hereyou can download the manual
http://sewingonline.co.uk/pinnock-manuals.html
Cheers,
Embroidery Services
San Diego, CA
Mar 29, 2009 | Sewing Machines
Oiling my Janome Gem Gold
Janome Gem are self lubricating. Silicon is embedded in the gears and releases as it runs. If the machine is put away and not run every so often it will lock up. The hand wheel may have thread caught up around it. The Gems aren't assembled to be dissembled except to change the light bulb.
Jan 16, 2009 | Janome Jem Gold 660 Sewing Machine
Threading...
Take a look at the instruction manual on the JML site @ http://www.jmldirect.com/downloads/instructions/easy_stitch.pdf
Even if you have the instruction manual supplied with the machine as the pdf has colour images that make it easier to follow rather than the over exposed black and white splodges in the supplied paper manual.
Jan 10, 2007 | As Seen On TV Easy Stitch Mechanical...
Sewing Machines Logo
189 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
