Question about Samsung Transfix R730 R 730 Android Cricket Touch Camera Market Wifi
Unlock transfix phone - Samsung Transfix R730 R 730 Android Cricket Touch Camera Market Wifi
  • Samsung Master
  • 14,641 Answers
Dear Brother:
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Posted on Dec 06, 2012
Unable to send texts from my GT-E1200
unable to send texts from my mobile
Aug 05, 2013 | Samsung Transfix
My samsung transfix want connect to my computer
first install cd key and then connect phone
Sep 11, 2012 | Samsung Transfix
How do I create a group message in samsung transfix
There's apps in the Google play store that can do that, Handcent is one of them.
Sep 01, 2012 | Samsung Transfix
Turn on predictive text cricket samsung transfix
On the SCH-R470C Samsung phone from CRICKET, you have to brig up the keyboard, (as if you were Texting someone ) and there is a Key on the bottom left side of the Keyboard that looks like a small "Gear". That brings up the "Settings" menu - uncheck the box that says "Predictive Text". Whoever invented that incredibly annoying feature should be severely beaten with both vowels & consonants...
Aug 02, 2012 | Samsung Transfix R730 R 730 Android...
Samsung Transfix wont turn on
if ur inside charger piece isnt out of place (u can find out by charging it on a duracell mygrid) then try a hard reset Press and hold the Volume Down + "R" in Qwerty Key + Power keys at the same time When the device displays "Samsung", release the power key only Continue to hold the Vol Down and back keys until you see the "Android system recovery" screen, then release all keys Press the vol down key until "wipe data/factory reset" is highlighted Press the home key Press the vol down key until "Yes - delete all user data" is highlighted Press the home key Once finished, and returns to the main recovery menu, press the home key again to reboot.
Jun 30, 2012 | Samsung Transfix
How do you clear the cache
go to your browser, click the list button, click settings, click clear cache
Mar 24, 2012 | Samsung Transfix
Jam c3t 15747 is indicated on the machin jan count whats the cause
If the Jam code is C3T, ensure the process drive assembly is correctly homed. 4. Ensure the stripper carriage moves freely 5. Run the transfix drive slow and transfix drive fast test.
Jul 22, 2010 | Xerox C2424 Copier
Timing, jams or prints off bottom of page
Hi hotpress:
Try these steps.
Print transfer jams
1.
If a piece of paper is trapped in the paper preheater, try pushing out the paper by
inserting a stiff piece of cardstock into the paper preheater.
2. Using diagnostics, test the paper preheater sensors. If the test fails, replace the
paper/drum heater assembly.
3. Check to see if the upper feed roller drive belt is broken or slipped off of its pulleys. In
such a case, the upper feed roller does not rotate when the lower feed roller rotates.
4. Check that the feed rollers rotate smoothly and that the front cover is fully closed and
seated.
5. Check the paper-eject path for obstructions. Ensure no small pieces of paper are
trapped around the stripper fingers or rapid release guide.
6. Ensure that the transfix roller rotates during the transfix process. See SF168 and
SB467.
7. Test the sensors in the paper path. Look for damaged or non-operating sensor flags.
8. Check the transfix solenoid and its cam. Ensure they operate correctly and are properly
lubricated. If lubrication is needed, apply a dab of grease to the contact point between
the cam and the latch and the cam and the cam-advanced spring. Refer to
"Lubrication" on page 6-177.
9. A stripper finger, or rapid release guide, jam can occur because of broken teeth on the
small section of the back-side of the compound gear. The root cause of this may be also
be due to a lack of transfix cam grease. If you find broken teeth on the compound gear,
check for proper lubrication of the transfix cam. Be careful to ensure that no grease
touches the Y-axis belts. If the belts get contaminated with grease they must be
replaced. wipe off any excess grease to prevent it from dripping onto the belts.
Hope this helps
May 23, 2009 | Xerox Phaser 850 Printer
Samsung Transfix R730 R 730 Android Cricket Touch Camera Market Wifi Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
