Question about APC Smart-UPS RT 5000VA UPS System
No logic power when input breaker is closed - APC Smart-UPS RT 5000VA UPS System
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 91 Answers
Double check your batteries, SURT UPS wont turn on if the battery is totally drain
Posted on Feb 20, 2013
Frigidaire oven temperature unreliable.
Is this an electric oven? Sound like a bad breaker to me if it is.
Dec 22, 2016 | Frigidaire Ovens
Hi I have a 2006 Lincoln navigator the air suspension pump will not turn on the vehicle dynamics module is not turning on the pump relay because in the pid data the drivers door says it is ajar when it is...
Hey Jeff, any U- codes stored in any modules ?
U1900 Missing CAN message(s) Door(s) ajar, PRNDL, 4x4, instrument cluster (IC), running boards, vehicle speed REFER to Section 418-00 . U2023 Invalid CAN message(s) Door(s) ajar, PRNDL, 4x4, instrument cluster (IC), running boards, vehicle speed REFER to Section 418-00 .
L4 CHECK THE VDM FOR DOOR AJAR INPUT
  • Key in ON position.
  • Monitor VDM door position status PID.
  • Close all doors, liftgate, liftgate glass and power running boards.
  • While observing the diagnostic tool, open and close one door.
  • Does the door status PID change between CLOSED and AJAR states?
When you open an close the driver door you have no PID change ,right ?
The door ajar input is an input to the Vehicle Security Module , then transmitted over the bus ! You'll have to find a diagram for the med. speed CAN data bus .
Jan 09, 2015 | 2006 Lincoln Navigator
Apc smartups will not power up
have you check the battery, SURT UPS will not on if the battery is totally drain.
Dec 05, 2012 | APC Smart-UPS RT 5000VA (SURTD5000XLI) UPS...
Nordic Track treadmill A2105 will shut down and trip my HOME breaker while in use, what could be the problem? I have tried lubricating the belt and it worked a little longer than usual, but after abo
1) you must LUBE THE DECK BELT+ ROLLER BEARING.
2) Test the input voltage motor, if there are the MOTOR is faulty need REPAIR.
3) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
4) SEE THE BLOCK DIAGRAM, whatever component can be faulty.
However you must test the power cord for short circuit between cable, repair, and look inside according the BLOCK, and proceed with logic, see any loose wires, or some wires touching the carcase, some filter, coil, power supply USE the VOM.
God bless you
May 27, 2012 | Nordic Track Exercise & Fitness
VIEWSONIC PJD5111 SHOWS VERTICAL LINES
Hi... Projector show vertical lines... Issue in your logic board filter's missing on logic input board check for fail signal on video input logic board,,, check input connector for broken pin inside connector... also check capacitor & resistance arround video logic processor, possibility of over heat conponent
Oct 25, 2010 | ViewSonic PJD5111 Projector
Trips breaker and get "PF" on display even when not tripped
This error code indicates "power failure" was detected. This could be caused by a bad/loose connection at either the logic board, the relay board, or at one of the three main power connection terminals on the back of the dryer. The logic board is located inside the control panel. The relay board is located in the base of the dryer. You can unplug and reseat electrical connections at these locations and check the main power cord hook-up at the terminal block. Hope this helped and best wishes.
Sep 02, 2009 | Maytag Neptune MDE5500AY Electric Dryer
With VGA input the screen randomly flashes on and off
power control chip of the VGA input screen is not controling the input settings
Jun 29, 2009 | Dell UltraSharp 1800FP 18.1" LCD Flat...
I have a GE Dishwasher model GSD4430X72WW.
Hi, the surge has fried the logic sector of the control. it will work upon reset until the logic chip is commanded to initiate a wash. thsi is when the fault will kick in. I recommend replacing the control. this is the best action.
Jun 19, 2009 | Dishwashers
Logic alx1280 2 ch amp
Amps can be rated based on their RMS power or their peak power. In this case, the amp's rated RMS power is 300x2 at 2 ohms (total 600W RMS) with a peak power rating of 600x2 (1200W peak). For the most part, peak power means almost nothing.
If your head unit didn't have RCA preamp outputs, you would used the standard speaker outputs from the head unit and connect them to the hi input plug of the amp.
Mar 17, 2008 | Logic Soundlab ALX1280 Car Audio Amplifier
Liftmaster garage door intermittent power loss
I had the same problem. Although it appeared to be the logic board, on mine it actually was the connectors between the logic board and the power supply board.
There are 2 connections on the logic board. One white connector with wires going to the main unit, and another set of connectors that plug directly into the smaller circuit board that holds the step-down transformer (120vac - 22vac). These pins were not making good connection between the boards. I simply bent the pins slightly so they would make better contact on the logic board and have not had a problem since. This must be a weak point on these door openers. Purchasing a new logic board would work too, as the connectors are newer and tighter.
Dec 27, 2007 | Sears Craftsman LiftMaster Chamberlain...
APC Smart-UPS RT 5000VA UPS System Logo
99 people viewed this question
Top APC Computers & Internet Experts
Shawn DuRee
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
