How do I reset my canon powershot camera, I am get the message Lens error, reset camera
Fix #1:
Remove the batteries from the camera, wait a few minutes. Put a fresh
set of batteries back in (preferably rechargeable NiMH 2500mah or
better) and turn the camera on. If that didn't work, try pressing and
holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then
install new batteries, and turn on the camera. If you get an Error E30,
it means you don't have a memory card installed, so turn it off, slip in
the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the
camera on. Inserting this cable ensures that the camera's LCD screen
remains off during the start process. Thus extra battery power is
available to the camera's lens motor during startup. This extra power
can be useful in overcoming grit or sand particals that may be jamming
the lens. If the AV cable doesn't fix the lens error by itself, consider
keeping this cable installed while trying fixes 4, 5, and 7 as a means
to provide extra help to these fixes. But note that I DON'T recommend
keeping the cable installed during Fix 6 as you may damage the AV port
while tapping the camera. Reinsert the cable only AFTER tapping the
camera.
Fix #4: Place the camera flat on its back on a table, pointed at
the ceiling. Press and hold the shutter button down, and at the same
time press the power-on button. The idea is that the camera will try to
autofocus while the lens is extending, hopefully seating the lens barrel
guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels
with the idea of blowing out any sand or grit that may be in there
jamming the lens. Other variations include blowing with a hair dryer in
"no heat" setting, or sucking the gaps with a vacuum (careful with this
one).
