Question about Proform 860 Competitor Treadmill
Power is on, motor doesnt run
Can turn the belt manually, but not with the motor. The motor engages when the speed switch is increased, but doesnt turn.
    Top Expert:
  • Proform Master
  • 12,223 Answers
1)Lube the deck belt with 100% silicones or wax follow the instr. manual
2) Lube the rollers bearing with wd-40
3) Test the drive belt motor,for worn and replace if necessary
4) Test the input voltage motor, if there are the motor need repair.
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty..
God bless you
Posted on Dec 05, 2012
2 Suggested Answers
  • 75 Answers
SOURCE: The drive motor makes a noise which is louder at higher speeds
Bearing in the motor are bad. Replace your motor.
Posted on Jul 18, 2009
Kenmore dryer doesn't turn on and belt broken. I can hear timer on if I hold start button on. If belt was only problem wouldn't dryer motor still turn on
It depends on the model on some models they have a belt switch so that when the belt breaks the switch kills power to the motor and it wont run until the belt is replaced and the switch is engaged. If you need more help with making this repair visit the link below:
Appliance Repair Help With Live Chat
Mar 25, 2017 | Kenmore Dryers
Why wont it run?
Is the motor running? If not, is it receiving power? Is the belt slipping? If motor has brushes, they might need replacement.
Nov 18, 2015 | Nordic Track APEX 6100XI TREADMILL Console
Precor error 20
Precor Error Code 20 Error Code: 20 Manufacturer: Precor
Model: All Models
Error Description: Error 20, Too many Maximum Power Requests in 1 Second - The error 20 observes a treadmill's power bit reading when the treadmill was operating at speeds of 1 mph or less. Power bits indicate the relative time that the motor controller drive circuit is turned on. Power bits is an indication of the amount of power the load is demanding from the motor controller. Error 20 indicates that at a speed of 1 mile per hour or less, an excessive amount of power is being demanded from the motor controller for an excessive length of time. Possible Reason:
  1. Starting the running belt under a very heavy load can cause the error 20 to appear.
    1. The user (especially a heavier user) is standing on the running belt as they start the belt into motion.
  2. A badly worn deck and/or running belt can cause the error to appear when the user steps onto the belt.
  3. Badly worn drive motor brushes may not be making proper contact with the drive motor commutator causing the error to occur when the user steps onto the running belt. The unit may also slow down or become sluggish when the user steps onto the running belt.
  4. A leaky or shorted drive motor filter capacitor (on units equipped with SCR motor controller) could increase the current demand enough to cause the error.
  5. A leaky or shorted drive motor inductor (on units equipped with SCR motor controller) could increase the current demand enough to cause the error.
  6. The high power demand is caused by a shorted or de-magnetized drive motor.
Recommended Action:
  1. Instruct the user to straddle the running belt while starting the treadmill at a low speed, such as 1mph or less, and then step onto the running belt.
  2. Determine the amount of AC input current being drawn by the unit under no load and loaded conditions using a clamp on AC ammeter. The current displayed can be used to determine the condition of the deck and/or running belt. These same readings should be taken on a like unit, in good operating condition with a known good deck and running belt. The readings from the unit in good operationg condition can be used as the benchmark. Compare readings and replace* the deck and/or running belt if necessary. *Some units have a reversible deck. Be sure if the deck is being flipped or replaced, a new belt is installed on the new deck surface.*
  3. Inspect and repalce both drive motor brushes if necessary.
  4. Measure the AC input current without a load using a clamp on AC ammeter. Electrically isolate the filter capacitor from the drive motor circuit. The drive motor leads need be kept intact so the drive motor will operate with the filter capacitor removed from the circuit. Re-measure the no load AC input. If the AC input current is significantly lower, replace the filter capacitor.
  5. Measure the AC input current without a load using a clamp on AC ammeter. Electrically isolate the inductor from the drive motor circuit. The drive motor leads need be kept intact so the drive motor will operate with the inductor removed from the circuit. Re-measure the no load AC input. If the AC input current is significantly lower, replace the inductor.
  6. Swap the existing drive motor with a known good drive motor.
Precor Error Code 20 20 Too Many Maximum Power Request in 1 Sec
Mar 18, 2013 | Precor C962i Treadmill 220V
Precor c966i error 20
Model: All Models
Recommended Action:
Mar 18, 2013 | Precor C966i Treadmill C 966i
Belt doesnt run
see the video how to lube the deck belt.
2) LUBE the rollers bearing too
4) Test the input voltage motor, if there are the motor need repair see my personal TIPS for troubleshooting help
see the block diagram
God bless you
Nov 30, 2012 | Weslo Cadence G 5.9 Treadmill
Schwinn belt stopped
Dear Sir:
1) You must LUBE the Deck Belt, in according with the instruction manual. The deck maybe is worn.
2) See if the deck belt is in bad condition.
3) Test the drive belt if o.k
4) Test the main motor if running, if not the motor need attention and repair.
5)Test the input voltage for motor coming from the main motor BOARD.
see my personal TIPS for HELP.
sincerely. God bless you
Apr 23, 2012 | Schwinn 820 P Treadmill Silver Service...
My ProForm 750 only runs at low speed. Varying
If u r seeing the increasing variation takeing effect on the panel but the speed does not increase in real, then there is nothing wrong with the push button for sure.
what it could be is ,
1. Your motor is getting overheat quickly and does not accept the higher speed commands.
2. it could be a belt slip also (do u hear any extra noice / vibration when u increase speed)
3. next time, pls unplugg the unit for atleast 4 hrs and when u start after that increse the speed very next moment and see if it works. if it does increase this way then it is time take look first on the belt ans then check the motor.
Good luck.
Jul 25, 2010 | Proform iLog 750 Treadmill
My ac fan will not kick in....
replace fan motor the fan doesnt change speeds unless done by u
Jun 20, 2009 | Heating & Cooling
Blower fan motor won't run, '97 dakota with A/C
dash yes book time is 6.5 hours..ouch... check blower motor resistor first..and blower relay... the usual suspects here
Dec 08, 2008 | 1997 Dodge Dakota
Proform 860 Competitor Treadmill Logo
140 people viewed this question
Top Proform Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Owen Barnes
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
