Question about Whirlpool Duet GHW9150P Front Load Washer
Keeps saying f22 when trying to start wash - Whirlpool Duet GHW9150P Front Load Washer
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
F22 means you have a door lock issue -- not sure what these other guys are telling you but you need to unlock your door to correct the problem. Remove the lower kick panel by taking out the screws on the bottom. reach up on the right side---attached to the door latch is a 2 inch long plastic bar you need to pull directly down to unlock the door. After this disconnect the power to your machine for 1 minute and reconnect the power. If the error comes back replace your door lock assembly. Here is the part to order. Below is a video to show you how to replace the lock.
Posted on Dec 05, 2012
I have bosch classixx 6 washing machine with F22 code flashing ?
How to reset Bosch Classixx 1400 Express
hi,couldn't find too much detail about the fault , may be faulty brushes an commutato......the abovel ink gives details and how to reset after f22 message
good luck
r
Jul 09, 2015 | Bosch Washing Machines
Code f22 flashing when i try to start load. the door seems to lock fine
unplug washer and let set 30 min. should reset. plug in, turn on then turn off a couple of times to see if doorlocks and unlocks properly. If not you may need a new switch. That F22 is door lock malfunction. You may need to check hinges and see if they are tight.
Jul 15, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Keep getting F22 I removed lower front , found door release, opened door I cleaned catch, removed and checked impeller Checked electric connections under the hood Still get F22 code
You likely have a faulty door lock assembly, which is what this fault code is telling you. Most often caused by a faulty switch within the lock assembly itself, you will need to replace the entire assembly. The part is available HERE .
Jan 13, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Close door, f22 message, won't start
"F22" is a door latch error. The following link explains:
http://www.fixya.com/support/r1976388-f22_error_code_whirlpool_duet_kenmore
Read through all the steps listed and let me know if you still require assistance. I hope this helps you.
Apr 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F22, washer is locked and will not unlock
IT is a defective lock, unplug the machine for 30 minutes and plug it back in. Then once the door opens replace the door lock and all should be well
Apr 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error code f22 whirlpool duet wash cycle
f22 is a door lock error try this hit cancel turn your dial to another setting, hit start and once it starts hit cancel again and it should unlock. thats what i did anyway.
If you're getting an F22 error, you will want to check anything to do with the door latch switch.
Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpoo; wfw9200 F22, F28, A17 A27 error codes
f22 is a door lock error and f28 is a commication error you still have warranty thorugh whirpool. you're going to need pro. help
Dec 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet steam F22 error code
it needs a servicing as .the parts are getting blocked and not able to move frequently.
also check for the motor.
also try to clean it externally and see it should work.
and if not then calling a tech is advisable.
check out this link for more help
http://www.applianceaid.com/washers.html
thanks.
Oct 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
F22 Error Code
TAKE 3 SCREWS OUT THAT HOLD THE BOTTOM FRONT PIECE REACH UP BEHIND AND ON THE DOOR LOCK MECHANISM THERE IS A ROUND PLASTIC DOOHICKEY PULL IT DOWN ABOUT 1/2 AN INCH OR AS FAR AS YOU CAN AND IT WILL UNLOCK THE DOOR. I WOULD UNPLUG UNIT FIRST. I DON'T KNOW ABOUT THE F22 THING. MY JUNKER DOES THE SAME THING PERIODICALLY, I UNPLUG AND REPLUG IT TO CORRECT
Sep 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer F22
thats a door lock failure code try unplugging the washer then let me know shut the door firmley before operating
Mar 28, 2008 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
520 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
