Question about Cell Phones
My tab.was'nt charge well
  • Cell Phones Master
  • 14,641 Answers
Dear Brother:
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Posted on Dec 06, 2012
My lenovo s nt charging but my adapter s wrkg
If you have vibration when you hold the power button you can try this solution:
Aug 27, 2014 | Lenovo IdeaTabTM A1000 Tablet With 7in....
I have a msi tab. When I charge it was'nt charge
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Dec 08, 2012 | Computers & Internet
My daughter 2004 Kia won't hold a battery charge.
voltage regulator. it may be in the alternator, or remote mounted. ((the alternator can be charging, but if voltage regulator is'nt working then it won't allow voltage to get back to the battery to keep it charged
Sep 07, 2012 | Cars & Trucks
Nt get a wireless connection
You need to replace the Wireless NIC card
Nov 27, 2011 | Computers & Internet
Alternator is not charging but the local parts store tested it and it is working fine, all fuses are good
what makes you think its not charging? alternators should always be checked ON THE CAR.
Aug 03, 2011 | 1999 Oldsmobile Alero
I have a nokia1208 mobile and now its dad ;;;;; i checked this and supply has reached at on /off switch but is not getting on''''''''so plz tell me any soluion how can i...
Check the battery ! it must have been out of charge.. charge your cell for about 1 hour, and start the phone. If it does'nt, make it checked up by some engineer if the battery is damaged. or vice-versa... Thank You
May 09, 2011 | Nokia 1208 Cellular Phone
2005 Freestar Beeping noise while in drive or reverse . No beeping in park.
You have a blown fuse. It's likly that the battery is'nt charging as the altenator is'nt on either. Because the gauges fuse is blown the gas gauge can be wrong too. The best way to find the blown fuse is to check them all. The cigar lighter fuse can set this problem too as all systems effect all other systems ( big brother is watching ). Theirs other things that can happen but this is where to start. Add a conment and I'll see what you found out and try to help you more.
Apr 29, 2011 | 2005 Ford Freestar
I dnt knw its nt starting it just show apple symbol n its nt getting switch off also nt even charging
I would first try doing a soft reset by pushing and holding both the power button and the home button at the same time, continue holding until the apple logo reappears, then wait to see if it boots up. If that doesn't work, try doing a restore by plugging into PC and clicking on restore in iTunes on your PC. If this doesn't resolve your problem, call 1-800-MYIPHONE to set up an appointment in an Apple store so a tech can repair your device. Hope this helps!
Apr 26, 2011 | Apple iPhone 3G
Hi i purchased a laser Mp4 player for my daughter, it was turning on but now it is not, we only got it yesterday, I dont know how to reset this and it is not charging either
i cant help with charging cause mine is'nt ether with the on and off swicth leave it on to turn it off and on hold down the play button 4 a few secs and it should work im sorry if it dose'nt work
Apr 14, 2011 | Laser MP4-V970 MP3 Player
Cell Phones Logo
26 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
