Question about Proform 860 Competitor Treadmill
Proform 860 competitor motor wont run
Can turn the belt manually by hand, power is on.
    Top Expert:
  • Proform Master
  • 12,223 Answers
Lube the deck belt with 100% siicone or wax
2) Lube the rollers bearing
3)test tbe drive belt for worn
4) Test the input voltge motor, if there are the motor need repair, see my personal TIPS for motor help
5) Test the the output board, for input voltage motor if there are Not the board is faulty.
God bless you
Posted on Dec 05, 2012
SOURCE: My new treadmill belt is to tight, motor won't run
i discovered a bolt protruduing about one inch just behind the drive belt from the moto to the roller. The drive belt had gotten over the bolt and that was causing the interfearence.
Posted on Apr 09, 2009
  • 16 Answers
SOURCE: treadmill powers up begins to turn belt then shuts down
Have you tried to calibrate the speed. If not you might want to try it and see if it will help you with your issue.
Posted on Apr 14, 2009
  • 16 Answers
SOURCE: Proform 515s treadmill motor won't start
If the colse buttons make a chirping noise when you push them the console should be Ok. If there is no chirping noise with the push it is a bad console. If everything but the speed works it will probably be your motor controller that is bad.
  • 185 Answers
SOURCE: my proform belt wont start
i dont mean to be rude , but if its brand new call the company that built it and they should be able to help you. should be able to troubleshoot over the phone
Posted on Oct 03, 2009
  • 15 Answers
SOURCE: my proform 860 has belt slippage and sometimes
I had the same problem and was about to change the walking belt. Instead I removed the 5 screws holding on the hood and adjusted the Reed Switch and took a walk. Whenever I stomped on the belt hard it would stop. I Could now see (because I removed the hood) that the motor continued to spin and the Motor Drive Belt was slipping and was the culprit. Something that I had noticed before was all this fine rubber dust coming out near the left front corner where this belt is. If you see that it's a good indicator the motor belt is slipping and needs to be replaced.
Posted on Jan 10, 2010
860 Proform runs but the belt won't turn
could be the drive belt is broken. remove the motor cover on the font of the treadmill and inspect
Aug 17, 2014 | Exercise & Fitness
I have to adjust my belt every time I get on it. What could be causing this please?
LUBE the deck belt and rollers bearing and adjust the slipping see the video. If the problem persist is TIME to replace the old board deck belt.
God bless you
Mar 06, 2013 | Proform 860 Competitor Treadmill
Treadmill is stuck in fastest position and will not change
1) LUBe the elevation motor, in shaft and gear
2) adjust the small POTentiomenter for to liberate the elevation motor
3) clean the relais contacts, and tight every connector.
see the diagram and fix it.
Jan 18, 2013 | Proform 860 Competitor Treadmill
Power is on, motor doesnt run
1)Lube the deck belt with 100% silicones or wax follow the instr. manual
2) Lube the rollers bearing with wd-40
3) Test the drive belt motor,for worn and replace if necessary
4) Test the input voltage motor, if there are the motor need repair.
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty..
God bless you
Dec 05, 2012 | Proform 860 Competitor Treadmill
Proform 860 treadmill, want to undo incline feature, & use it without it
Run the software calibration for easy diagnose, troubleshooting, and fix it.
God bless you
May 16, 2012 | Proform 860 Competitor Treadmill
I need to tighten the belt, it keeps slipping while walking on it
Unplug unit then remove motor shroud then do the following: If the problem is in the drive belt, either the drive belt will stop when stalled or the front roller will stop when stalled. If the motor, drive belt, and front roller continue to turn when the walking belt is stalled, the problem is with the walking belt slipping on the front roller. If the drive belt continues to turn but the front roller stalls, you may have a broken front roller pulley.
1) Adjusting the running belt if the problem: If the walking belt slips when walked on, UNPLUG THE POWER CORD. Using the hex key, turn both idler roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 in. off the walking platform. Be careful to keep the walking belt centered.Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
2) Adjusting Drive belt: Find the motor mounts. Many motors in Icon treadmills have a main pivot joint in which a bolt runs the full length of the motor mount. This bolt will require loosening to provide maximum adjustability. Some models have a single jack bolt and others have an auto tensioner. Single jack bolts are the easiest to adjust.
May 14, 2010 | Proform 860 Competitor Treadmill
My proform 860 has belt slippage and sometimes stops after a few minutes
Dec 09, 2009 | Proform 860 Competitor Treadmill
I got my ProForm 860 treadmill and the previous owner said it shuts off after 1.5 miles (overheats). The company said its due to friction. How do I know what is causing the friction. Loose belt, worn belt,...
Be sure there is no damage to the walk board itself before replacing the belt. You may want to try lubricating the board before replacing the belt.(silicone spray from any hardware store) This is also caused by overtightening of the drive belt and/or walk belt. Good Luck, Tim
Nov 11, 2009 | Proform 860 Competitor Treadmill
Proform 860 Competitor Treadmill Logo
70 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
