Question about LG DLG5932W Gas Dryer
Dlg 5932w hi i have a problem with my gas dryer while it was drying some kind of smoke came out from the rear it smells like burn . i quickly shut my dryier off and gas. i waited 1 hr tried it again ,but this time dryer wasnot drying it was blow hot air for 10 sec and stop.so i shut it off . please can some give a solution
    Problem Solver:
  • 6 Answers
My suggestion would be to make sure that the lint-filter and the exhaust flex hose are removed and cleaned. If you have the plastic type flex-hose, be aware that these can heat up and catch fire. Be sure to also check the exhaust port coming out of the dryer (that the flex hose attaches to); make sure that there is nothing obstructing the air flow, if there is, then clear & clean and try to restart. If not, I would call a service company...
Posted on Feb 25, 2009
Maytag Centennial Gas Dryer: Only runs in "Air Fluff" setting. If any other setting (Normal Dry / Timed Dry) are used the dryer shuts down immediately. If I force the dryer to run by holding down the start...
Hello Kevin;
My name is Peter. I am a retired field service appliance technician.
When you run your dryer on fluff you are not using heat. The burning smell is when you use normal dry and the lint starts to burn. This will shut your unit down.
You just need a good cleaning. Nothing major. Send me your model number and I will help you.
Dec 11, 2014 | Maytag Dryers
LGR7647 will dry fine but smells like gass only when it runs.
make sure the air shutter on the gas nozzle isnt completely blocked or changed positions as the flame needs oxygen to make combustion complete otherwise the gas wont burn completely and you will get a black smoke that smells like raw gas
Dec 06, 2012 | Dryers
Maytag Neptune Dryer with strong "burned electrical wiring" smell
Sounds like the motor went out. Before trying to start it it needs to be inspected. If you are not comfortable opening up the cabinet then I would would recommend calling a service tech. If you need further assistance please let me know.
Ken
Mar 17, 2010 | Maytag Neptune MDE5500AY Electric Dryer
When drying clothes in my gas dryer, you can smell gas upon opening the door. If the dryer is not running, you do not smell a gas odor. Sometimes our clothes also have a gas smell.This just started a week...
Hi, from what you describe, it sounds like you may have incomplete combustion, which would leave a residual odor while burning. Check your vent, on the outside where the flap opens and the exhaust leaves the building. Anything blocking that vent may cause an air flow problem. If you have good air flow when the dryer is running, the problem is going to be at the gas valve/burner and may need a professional. In my town, the gas company will come out and check problems like this for no charge, they don't replace parts but are good at troubleshooting. Best of luck.
Jan 17, 2010 | Estate TGDS740JQ Gas Dryer
Duet Gas Dryer- burning smell
first is first ,,, disconnect dryer from plug,, now open bottom panel 2 screws ,, now go and get youre vaccum,shop vac, anything ,, reason for burning smell ,, usually catching on fire ,, we recommend do this 1 as year,,, after cleaning , put about 2-3 fabric sheets inside dryer and let it runn for about 30 minutes to remive smoke from drum,,, thank you
Dec 29, 2008 | Dryers
LG Gas dryer doesn't dry clothes in one cycle
Have you checked your outside vent while it was running to see if the dryer was venting 100%. If your clothes are hot and humid I would say clean your vent pipe has a blockage and needs to be cleaned out. Also as far as the burning smell you could take the front off (unplug first) the dryer of by removing 4 screws one above and one below the latch and two at the bottom and there are two clips one at the top left and right push in with a puddy knife and lift the top up a couple inches and lift the front up off the bottom holders. Then you will have access to vacuuming the lint that is floating around the burner.
Dec 01, 2008 | LG DLG5932W Gas Dryer
Whirlpool duet dryer smells like smoke from back vent in dryer
If you don't clean out the lint trap frequently, your dryer may have small lint fires inside the cabinet. The smell from these fires can leave a strong odor in the clothes drum.
Also, if there are any solvents, paints, lacquers, etc. in use in the house, your dryer may alter and/or amplify the fumes to an odor unlike the natural fumes given by the solvent, paint, etc.
Here's what to do:
  • First, clean all of the lint from the inside cabinet and ductwork of your dryer.
  • Have a qualified appliance repair technician inspect the dryer for damage caused by any lint fire.
  • Move all containers of flammable liquids at least 50 feet away from the dryer. Gas dryers have a large flame when operating properly and can ignite the fumes of any flammable liquid or gas.
  • Then, try to clear the odor, by running a couple of loads of old rags or towels.
Nov 25, 2008 | Dryers
LG DLG5932W Gas Dryer Logo
134 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
