Question about Whirlpool Washing Machines
Whirlpool washer (WFW9400SW00) - Washer turns on, I can select a cycle, but no water comes in and there's a grinding noise. I receive no error message. Water supply is good.
The door locks. The minutes pass on the display. I tried different cycles, same thing.
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
You will need to replace the water inlet valve. Here is the part to order.
To replace the valve, remove the top to access the valve.
Posted on Dec 05, 2012
  • Mandy R Dec 12, 2012
    The water inlet valve was sticking and that's what caused the noise. We gave it a tap and it started working again. I was able to do a couple loads and now it's sticking again. Do you know why it might be sticking? Should we just replace it? We have a stacker and have the dryer on top, not sure if this is why it's catching.
  • Richard Roth
    Richard Roth Dec 13, 2012
    OK, you will need to replace the water inlet valve. You have minerial buildup on the solenoids of the valve that causes them to stick and they will eventually fail. Here is the part to order.http://bit.ly/UUVYqA
jsrock516
  • 5911 Answers
SOURCE: my whirlpool washer (Ultimate care
If the washer fills, but won't spin or drain, you may have a defective lid switch. This is a very common problem and a very common symptom.
Let me guess: The washer fills, agitates, but when it gets to the spin cycle it just stops. On some models the washer will fill and then shut off. Am I explaining your symptoms correctly?
If so, this what you need to do:
Open and close the washer lid and listen for a distinctive "clicking" noise. The contacts on the switch should close when the lid is shut, allowing the washer timer to run. This is a designed safety feature that prevents the washer from agitating or spinning with the lid open (don't need to lose any fingers). If you don't hear the switch, it may have come loose, or has broken.
Some lid switches are located on the right-hand side of the tub rim. There will be a slot where the lid strike pushes down on the lid switch. Make sure the lid strike (small plastic piece) is still present on the lid. This can prevent the washer from working as well and make it seem like a huge problem.
On some models the lid switch is located near the left-hand lid hinge under the washer casing. A small rod on the lid hinge activates the switch contacts.
If you determine the need to replace the switch, follow these steps:
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. The washer may have release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. If not equipped with this type of console, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. And, still there are some of the older models that have screws holding the console in place from the back. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
1. Under the console you will find the lid switch connector. Unplug the switch from the connector.
2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
You do not have to remove it all the way from the frame, just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in on the side of the tub opening and a ground wire attached to the casing. Remove the connector plug, by pushing in on the release tabs on either side and pushing it down through the opening in the washer casing. The wire harness will be held in place by clips under the washer rim. It's a pretty easy repair job. Some models will have the switch located on the right-hand side of the lid rim opening, while other models will have the switch located on the left-hand side near the lid hinge.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first, and then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle BEFORE you reassemble the console. This is easy to forget.
Good Luck.
Posted on Feb 27, 2008
aborcass
  • 2651 Answers
SOURCE: KHWS01PWH0 Front Loading Automatic Washer Leaking
out the bottom of door?? no through the bottom panel???. check the rubber door seal for rips or tears pull it back and look around entire circumference. smalll rip in very front of seal where door should close against will cause leak for sure
Posted on Mar 07, 2008
aborcass
  • 2651 Answers
SOURCE: Whirlpool washer fills up; makes LOUD whine/click metal noise
sounds as if you have a bad mootor coupling, part number 285753, easy enough part to change, easier to search on the you tube site for whirlpool motor coupling repair, fo rthe video, then try to explain procedure, but definalty easy enough repair for home owner
Posted on Nov 20, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Whirlpool Cabrio Washer Error message code F1
Whirlpool did a recall on this problem here is there number try this first. Whirlpool 1-800-253-1301
On a number of ranges this can mean a number of things, the most common being a failed ERC(EOC, Clock assembly)or a faulty touchpad. Firstly if you are using a recent Maytag range it may pay to test the oven sensor as described above as this may cause an F1 error if faulty (may apply to some other ranges as well) this is not a common cause but is worth discounting. To check the ERC and touchpad
  1. Disconnect the power
  2. Gain access to the back of the ERC
  3. Disconnect the ribbon cable that connects the ERC to the touchpad
  4. Check nothing will short when power is reconnected
  5. reconnect the power and switch on
  6. Watch for F1 and listen for the beep
  7. If you get the F1 and the beep this means the fault is with the ERC and it will need replacing
  8. If after 30 mins you do not see the F1 error and hear the beep, replace the touchpad
Posted on Feb 14, 2009
SOURCE: Whirlpool Duet Sport Washer Does Not Work, Door Lock is stuck
have you checked the belt to see if it came off or maybe broke off,if its not the belt then maybe the motor whent bad or needs reset,that just some of the possibilitys you might want to check,some motors have a reset butten on thim
Posted on Mar 01, 2009
Whirlpool cabrio makes grinding noise on the wash cycle
On this style washer the motor has a belt and pully type clutch under the machine called a splutch.There has been an ongoing problem with the nut coming loose and dropping the belt/pully down which in turn hits the safety shield.
Mar 31, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
Error H F
My Manual says (HF) = Water Inlet Problem- Insufficient Water Supply
Select Pause/Cancel twice to cancel cycle - Unplug Washer to disconnect Power-
Check the following:
Water faucets completely turned on
Screens at inlet hose connection to washer clogged?
Water inlet hoses kinked?
Plug in the washer- re-select cycle and press hold to start-
same error- call for service..
May 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool type 111 model LSQ9200LQ3 washer not
I have a whirpool model:lsq9200lq3, and recently it has stopped working. when ever you turn it on, its fine and the water fills up normally and right before it gets to the spinning cycle the machine makes a grinding noise like if something is stopping the motor from spinning, and it dosent spin inside the washer. if anybody has any suggestion It would be great thank you.
Jan 30, 2010 | Whirlpool Washing Machines
Whirlpool washer grinding noise when draining
there could be something in your pump.....remove the pump and see if there is not something inside...
Jul 04, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Water fills to proper level but agitator doesn't come on instead there is a grinding noise, when I move control to just prior to rinse cycle water drains properly, but still just grinding or buzzing n
Hi, Do you know if the washer spins at all?
It sounds like the coupler has gone bad.
Please let me know if it spins at all.
I can send yyou instructions on changing the coupler.
Vic
May 28, 2009 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool Duet Sport not running it makes clicks and it grinds
A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. Front load washers seem very common to this happen! If the tiny cloth is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth.=======
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Dec 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer Making Loud Grinding Noise
not nesseccarrily your pump, possible you have a rear bearing going bad, which will sound as if a helicopter is coming through your laundry room. ( noisy pump can be the issue , honestly a better and cheapre problem to have) in order to determine if its apump problem you can remove the lower access panel and unplug the pump then start the spinn cycle, if it still loud the pumpms not hte issue.
Nov 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Grinding noise when washer starts some spin cycles, washer stoped and game my wife a f-33 reading. whirlpool told me to unplug(reset) the washer for 30 mins. i did this and the washer still has the...
hi there,
the grinding noise may be coming from either the pump or you have something caught between the drums.
the f-33 error is the pump drive system error. it indicates that you have lost communication between the CCU board and the pump. the CCU board is the main control board that you see in the front of your washer.
i would recommend that you call a technician to check it out, as you will have to do some checks that require technical knowledge.
Oct 11, 2008 | Whirlpool Washing Machines
Buzzing noise coming from timer control area
Is your water on ??if yes than you may have a bad timer.
May 04, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
Dan Webster
Dan Webster
Sal DeAngelo
