Question about Car Audio & Video
How do I disassemble the JHT525 speakers so that I can paint the enclosure?
I would like to disassemble the speakers so that I can paint the enclosure and replace the speaker cloth. Suggestion welcomed. -Phil-
    Sergeant:
  • 256 Answers
Just takes the screws out that are holding the speakers in to the cabinet, Unhook one wire at a time from the speakers end keep track of where they go on The speakers for when you put them back in,
Posted on Dec 06, 2012
  • Phil Dec 06, 2012
    The speaker cabinet has only two screws. These screws hold the terminals for connecting the wire from the receiver. The case appears to be made of a two piece construction with the speaker cloth held in place, internally.
  • John Doe Dec 06, 2012
    Just look for different speaker cabinets that the speakers will fit into, That are in better shape then the ones that you have,
2 Suggested Answers
  • 94 Answers
SOURCE: I have found a PYLE POUNDER 8 inch speaker. I need
making a sealed box would be the correct enclosure for that sub, http://cdn.cloudfiles.mosso.com/c128031/sc-image/7/1/4/3/7143ed32a19c9a357a99e344a440d7e8.jpg th that image has one way you can have it look like, the black plastic piece is a connector point that is drilled out then glued to the side or back of the box, the other way is up side down/ reversed http://www.billkatz.com/images/ces_pics/ces_subwoofers.jpg Any sealed enclosure will do, 8 inch are not that powerful so any enclosure.
Posted on Jun 07, 2010
How to disassemble
Most speaker enclosure's, both wood composition and metal are hermetically sealed. This prevents damage to integral parts or moisture buildup. When a small speaker is malfunctioning, the magnet or cone may have sustained damage and is no longer viable. It is better to replace the entire unit than try to repair the interlace works.
Apr 17, 2015 | Brookstone Mobile Mini Speaker
Disassembly of transmitter
A great many speaker manufacturers use solid fixed enclosures fused or snapped together for permanent application. This is a cost saving measure to eliminate screws and added manual labor/time. You can use a Dremmel cutter to cut along the connection lines and open the enclosure, but be prepared to reseal when done.
Feb 09, 2014 | Recoton Advent Advent AW820 Computer...
I have a sub woffer JHT525 that bega humming. I have checked the fuze and did some reconnections but it is still humming. Anu suggestions? Anyone know where I can get a replacement. The model is JHT525
Disconnect everything, and turn it on. If it hums, it needs repair. Then try hooking up one cable at a time. If a connection hums, try another cable. If it hums no matter where you plug it in, try a 2-prong power plug adapter, or a ground-lift plug, as it's called. If nothing works, it may need a repair in its power supply. It would still turn on, but buzz no matter what you connect.
Dec 13, 2009 | Jensen Audio Players & Recorders
Subwoofer jht525
That's what subwoofers r meant to do.For a proper sound u need to connect the rear,center or surround speakers with the subwoofer.
Sep 23, 2009 | Audio Players & Recorders
Subwoofer jht525
Sounds like your connection is bad on the wiring to the Subwoofer. Try rewiring the connection with new wire.
May 31, 2009 | Jensen JHT525 System
The subwoofer JHT525 is only making a BOO loud sound it does not matter if I move de volumen up and down, I would like to know what is the reazon, if it was on for a long time or for what other reasons
I had this problem, too, and ended up throwing away the subwoofer. The reason in my case was the amplifier had a blown resistor. I could clearly see the burn marks and the broken resistor. I could have fixed it, but the subwoofer is 9 years old.
To find this, I unscrewed all of the bigger screws on the back except the two with the "ring" around the screw head. I then unscrewed all of the small screws. The amplifier/controller will come apart. Disconnect the speaker from the amp and then open the amplifier itself. In the "box" you will see a metal bracket, which was where the burnt resistor is.
Hope this helps.
How to connect mey speakers to the amp?
hi,i have 1000w 4 speekers but i have one amp.how do i connect to that?
Jun 24, 2008 | Jensen JHT525 System
I lost the installation manual on JHT525.
plug your low input into the subwoofer output of your reciever.that should get the sub working then you have to run speaker wire from your speaker outputs on your reciever into your sub in the top row of inputs then the outputs on the back of sub(the bottom row of speaker hookups go out to your speakers....my email is bsharp76@hotmail.com if you still cant get it i can talk you through it on there or ill give you my instant messenger name is you still have problems good luck,b
Apr 05, 2007 | Jensen JHT525 System
Car Audio & Video Logo
51 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
