Question about Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony doenst turn on
I plugged it in and all I here is the "click" of the power button, no sound or pic
    Top Expert:
  • Sony Master
  • 14,553 Answers
For most do it yourself people this may not be something to tackle.
You would have to safely get the cover off the set and about the only thing you could do then is a visual inspection of the power supply board (follow the power cord to it) and look for damaged parts or puffed up filter caps--see attached photos.
Short of that unless you have a good meter and some other things this is likely a shop repair---keep in mind individual parts are not sold for any of these sets-----only circuit boards.
guessing which board is bad and replacing can get expensive.
The set should have a blink code (most of the Sony sets do) and the click you are hearing is likely the mechanical relay in the power supply indicating the set is trying to come on but does not make it, if you hear it click on and then click again that is shutdown.
May be time to have a tech or a shop look at the set.
Let me know if you have questions.
Posted on Dec 05, 2012
4 Suggested Answers
RNS-Systems
  • 120 Answers
SOURCE: Power light comes on at plug in, on for 4 secs
The Tv is trying to boot and is hitting an error, entering protection mode, then reseting. With that model the most likely problem is a bad power supply. I would open it up and take a look for any clear problems (swollen capacitors etc) If you can you can google for a service manual to correctly diagnose the problem. It might be worth repair but for a 26 inch most likely not. Tiger Direct has 32 High def LCD 299 free ship right now.
If you can get a good price on a power supply and a main board this should fixyour tv. At your TVs market value (if your time worth anything) I would sell it as-is on E-bay and buy a new one.
You can check http://www.RNS-Systems.com
or E-bay for parts.
Posted on Oct 17, 2009
SOURCE: Sony Plasma TV.
I have the same problem. since I have 3 of these TV's, I switched boards around, and I came to the conclution that is the power board. I will try to repair it, and I'll let you know the component that is bad. Gaston
Posted on Oct 31, 2009
diodeic
  • 1622 Answers
SOURCE: I have a Sony bravia KDL32 L5000. pressing power
You need to check the output voltages of the power supply to see which one goes off. It may be due to short circuits some where, if otherwise
the power supply board is dead,do you know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hoping that this will help to solve the problem.....
Posted on Aug 07, 2011
Tip
How to Take a Screenshot on Sony Xperia Z1
1) Go to the display or the screen in your Sony Xperia Z1 which you want to capture.
2) Take a screenshot. Press the Volume Down button on the side and the Power button for about 2-3 seconds. Make sure that both the buttons are pressed TOGETHER, otherwise it won't work.
3) View your screenshot. You will immediately hear a clicking sound, confirming that the screenshot has been taken. You may also see the text "Saving your screenshot" on your phone's display during the process.
To view your screenshot, click on the screenshot notification in the notification tray or simply go to your Photo Albums and you will find the screenshots in a folder named "Screenshots."
on Jan 10, 2015 | Sony Xperia Z1 4G LTE"
My click botton to take the picture doesnt work, idk how to actually take the picture, am i doing something wrong??
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Aug 14, 2012 | ASUS Computers & Internet
My Sony TV only powers up if I unplug H2
Sounds like you are in the right direction. Replace the board, but if your supplyer will not restock the part if not needed I would find a supplier that will.
Jun 19, 2012 | Sony 32 Bravia Lcd Kdl-32ll150 Hdtv
I can't upload pics with my Sony Cybershot. When I plug it into my computer it says "USB mode = connecting..." for a couple seconds then it says "usb mode ptp/mtp Memory Stick" and...
I'm sorry for the difficulties you're experiencing in connecting the Camera to the Computer. Please click hear to view the troubleshooting steps to resolve the issue.
Thanks for understanding. Please let me know if you require any clarifications.
Sep 09, 2011 | Sony Cyber-shot DSC-S700 Digital Camera
My tv wont show a pic or sound. the green light comes on and it clicks but nothing. its a sony bravia kdl-55ex710. its happened before and my husband played around with the home button. it occassionly...
On the remote control to that tv, after the power is turned on, find and push the input button untill you have a picture. The input button switches where you are receiving your signal from, cable, component, video 1, vedeo 2,,etc,,,.
Hope this helps
Apr 19, 2011 | Televison & Video
NO PIC OR SOUND WHEN TURNING ON THE T.V. JUST A LOUD CLICK SOUND WHEN PUSHING THE BUTTON TO TURN ON. THE RED LIGHT AT BOTTOM JUST FLASES LIKE IT DOES WHEN IT WAS WORKING BEFORE SHOWING THE PIC. IS IT FIX...
YES IT IS FIX ABLE LOOK FOR A SONY SERVICE CENTER, CHEAPER IN LONG RUN. COUNT THE FLASHES IT SHOULD PAUSE AND BLINK AGAIN FROM LIGHT ON FRONT. DIAGNOSTICS FOR THE TECH.
Apr 15, 2009 | Sony FD Trinitron WEGA KV-20FS120 20" TV
My 32in sdtv red power light,no pic no sound
hi there, this may seem like a sstandard problem, but differs from mfg. to mfg. in the sony tv's it is usually an open cap in the stand-by power supply, since you werent specific in your problem, there can be many solutions even for a single series or group of tv's even within the same mfg. give me specifics and i can answer more precise. hope this helps even a little.
Jun 12, 2008 | Televison & Video
Sony Trinitron Kv24Fv12
stand by timer light flashes 7 times no pic no sound. how do i
stop timer
Apr 09, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony BRAVIA KDL-40S2000 40 in. LCD HDTV Logo
42 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
