Question about GE X5 Digital Camera
WHAT DOES "WRITE PROTECT" MEANS AND HOW TO REMOVE
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • GE Master
  • 102,366 Answers
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Posted on Dec 05, 2012
Protect message
Protect means that a fault was detected, disconnect all the speakers
and connect one at a time to find the cause.
If symptoms persist , it needs repair, output stage or power supply
circuits should be the preliminary things to check.
Sep 24, 2012 | Integra DTM-5.3 Receiver
Screen reads "OVER HEAT"
It means the audio output stage in the receiver is getting to hot and goes into auto shutdown to protect the circuits, check all speaker wires for shorts, if by chance you added extra speakers recently remove them. If there is no change you will need a professional to assess the receiver.
Apr 08, 2012 | Harman Kardon Audio Players & Recorders
Sir my sony stereo system showing "protect push power" how i troubleshoot the problem please replay fast
Protect Push Power on a Sony is telling you that you have an output short circuit and to turn off the player to prevent further damage.
Check the speaker cables for connection fault. If all is OK it means you have a blown STK Amplifier Chip. Will cost you about 20$ plus labor.
Apr 30, 2011 | Sony MHC-NX3AV Shelf System
Why does it say "Write
It means that the SD card in your camera in on write protect mode and you will not be able to save any new pictures in it. Take our the SD card and there is notch on the side, slide it to deactivate the write protect mode.
Hope this helps.
Mar 12, 2011 | Olympus Cameras
The display just reads "protect"
Protect is bad. It means the amplifier thinks it is overloaded. Check the speaker wires to make sure there are no loose connections or shorts.
Mar 01, 2011 | Sharp CD-BA2600 CD Shelf System
Protect mode. will it work again? how can "i" fix
This indicates a load on the system, turn receiver off, remove speaker wires from the back of the unit. Now power up and turn volume right down, if the word protect stays off, there is a short in the wires or one of the speakers. But if the word protect comes on, "with wires and speakers dis-connected, it means there is a short in one or more of the audio outputs in the receiver. If you are handy using a digital meter then you may be able to track the shorts down, and replace the parts to get it up and running, also if you can solder then it will make the job easier.
Feb 08, 2011 | Onkyo TX-V940 Receiver
The word "Protected" keeps coming up on the
When the word protect comes on it means there is a load problem, first! turn off the receiver, next remove all wires and speakers. Now turn the unit back on and make sure the volume is turned right down, this will reset the processor controller ic, if the word protect stays off it means there is a short in wires or one of the speakers. on the other hand if the word protect comes on when the receiver is switched on "without wires and speakers" you have a short in one or more of the audio output ic's in the receiver that will need a tech to correct.
Jan 25, 2011 | Sony STR-DB830 Receiver
Its flashing the word "protect".. i need the
there is no code. protect means you have a short in the speakers or speaker wires, or a bad output ic.
Dec 28, 2010 | Kenwood KDC-MP338 Car CD Player
How do I remove the "write Protect " from my Olympus camera? I must have pushed some buttons incorrectly and suddenly it shows that "write Protect " sign. I already tried removing...
Find the flash memory card that plugs into your camera and stores the pictures. It's usually behind a door or flap on the side or bottom. Remove the card, usually accomplished by pushing it in and then it should spring outward slightly -- at least enough for you to pull it out the rest of the way. Check the card for a tiny sliding tab on the side and move it to the opposite end of its travel. See this wikipedia article for pictures and more info about write-protection.
Dec 17, 2010 | Olympus Cameras
VS-50705 50" rear projection TV does not
Hi is most robably that you are having a issue with the power supply.
Jun 27, 2009 | Mitsubishi VS-50111 50" Rear Projection...
GE X5 Digital Camera Logo
54 people viewed this question
Top GE Cameras Experts
Steven Wander
Steven Wander
jjanesic
jjanesic
Level 1 Expert
Are you a GE Camera Expert? Answer questions, earn points and help others
