Question about SanDisk Sansa Clip MP3 Player
Cant detect the device
When i connect my sandisk 1 gb...to the computer it says..a problem occure in installing the device..your device may not work properly...n after hat my device stops charging..n i cant even detect it in the safely remove hardware please help me out my device is a new one ....havent used it anytime...
  • jora6610 Jan 12, 2009
    I have the same problem. When I try to trouble shoot in the Add Hardware section of the Windows XP Control Panel, the wizard says: The drivers for this device are not installed. (Code 28)
Most likely why that isn't working correctly is because your usb port on your computer is most likely bad... I know someone who had the same problem and once she plugged the player into another usb port it worked like a charm.
Posted on Jan 13, 2009
My sandisk e 250 one gb ipod is not detecting in ubuntu 10.04 but is charging
you must follow 5 steps
1) connect ur device to windows xp or windows 7
2) go to sansa website download sansa updater and install it
3) then follow instructions by sansa updater it will then automatically search and install a program for detection of mp3 player on ubuntu install that program its around 16mb .the software will do this you just follow this
4 after completing sansa updater instruction ,go to settings you can now see a usb mode then change to msc mode for detection in ubuntu
5 for detection on windows change to mtp mode
Oct 22, 2010 | SanDisk Sansa e250 MP3 Player
When I plug my Sansa Fuze (8 GB) into the computer it won't download the driver into the computer.
if u have a installer cd with the device then
please install the driver then plug your device
in the connectivity cable.
Dec 28, 2009 | SanDisk Sansa Fuze MP3 Player
Sandisk 8gb pendrive not detected
You can try using another usb port, or it might be that other things conncected to the usb are interfering with it. Try disconnecting things attatched to other usb ports (check in the back of the computer) but be sure that they're not important before you go ripping out cords.
Aug 21, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
HDD enclosure does not work
For that you need to uninstall all usb driver from device manager.
Right click on my computer icon then you see system property then go to hardware -> device manager then uninstall usb drivers 1 by 1 .
Then restart computer then all usb drivers are automatically installed.
Then connect your harddrive if still face same problem then connect your harddrive to another computer then check.
If another computer cant see your harddisk then your harddisk has hardware issue.
It need repairing .
If it is in warrenty take it to service shop they replaced it.
Aug 01, 2009 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
My sansa refurb 1 gb gets charged and says connected but i cant access the device in computer.
Some of the sandisk products need a driver installed to work properly. Try this link and look for your model. http://www.sandisk.com/retail/driverdownloads.aspx
Jul 16, 2009 | SanDisk Sansa MP3 Player
Connecting sandisk mp3 player to a computer
try going to www.sansa.com click on support and then click on your model player. Go through the troubleshooting questions and find your problem. there should be a few solutions for you to try. Good luck :)
Jan 27, 2009 | SanDisk Sansa e250 MP3 Player
Windows XP wont install USB card readers
Did not reinstall the needed drivers. Download drivers from manufacturer support and install them.
Maybe just maybe you can use device manager to install the drivers by searching the web for them. Only take a minute to make the attempt.
Mar 05, 2017 | SanDisk ImageMate 12-in-1 USB 2.0 Card...
Cant view map on gps
When you go past 4gigs on a micro SD card it becomes HC (high capacity I believe) and will not work with most Garmins. The 2 gig's the limit.
Dec 11, 2008 | Garmin Rino 530 GPS Receiver
Sansa mp3 player not detected by system
1. I assume you are using a USB Port to connect the device?
--Yes - Continue - If No, please specify connection method
2. Does using another USB Port on the PC make any difference?
--No - Continue - If Yes, that port on the PC is not functioning.
3. Are other USB devices that you plug into the PC detected?
--Yes - Continue - If No - the USB system on the PC is not functioning - upgrading or reinstalling the driver might work if it is not a hardware malfunction.
4. Did you install any type of driver for the Sandisk mp3 player?
--No- Continue - If Yes - uninstall and reinstall the driver.
5. Do you have another USB cable to try with the device?
-- If No, try another PC.
CL23
Feb 15, 2008 | Computers & Internet
For God's sake help me!!
MAKE SURE YOUR SANDISK IS PROPERLY CONNECTED TO YOUR COMPUTER THEN-GO TO YOUR START MENU-CLICK ON CONTROL PANEL-THEN CLICK ON SOUND SPEECH AND AUDIO DEVICES ON THE BOTTOM CLICK ON PORTABLE MEDIA DEVICES AND FOLLOW THE STEPS YOU COMPUTER GIVES YOU. GOOD LUCK AND I HOPE I WAS ANY HELP TO YOU.
Jun 30, 2007 | SanDisk Sansa m250 MP3 Player
SanDisk Sansa Clip MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
