I can't find a reference to the filter in the owner's manual or online. Help!
SOURCE: how to clean a affinity frigidaire front load
remove the toe kick panel just below the front door and its located right below the drum
SOURCE: Frigidaire Affinity Front load washer,
E10 code indicates there is no water supply.This can be confirmed by :
E10 also means that your cold water is coming in too slow, disconnect the
cold water hose and check to see if the screen on your washing machine
is clogged. If the screen is clean and the hose has good pressure then
you will need to replace the water valve on your machine--- this is the
piece that the hoses directly connect to.
SOURCE: From what I have read,
You will need to remove the lid by taking out the two screws that hold it down.
Then you will need to remove the screws that hold the control panel in place.then open the door and lift the bottom edge of the door boot to remove the retainer spring. then remove the front panel.
Then once the panel is removed you will be able to see the drain boot that goes to the drain pump.
loosen the clamp and pull the boot down so you can get at the coin trap.you should be able to push the trap up from the bottom of the boot it can be a little finiky but works. after every thing is clean you should be able to put it back together and work just fine
SOURCE: How do I go to clean cycle-Frigidaire affinity ATF6000fs
First, you put some bleach or tide washing machine cleaner inside. Then you make sure the washer is on and hold the spin speed button and the options button down at the same time for 10 seconds. You will see "Cln" appear on the display screen. Hit start and you are golden.
SOURCE: I have a frigidaire affinity front load washer, it
As you said in the question the error message is nothing but it is telling to call the Service Engineer .E20 error indicate to call the Service Engineer.This error indicates that due to long heating .Thanks for your question.
