Motherboard is beeping, the fans are working but no video
  • scottyandpat Jan 14, 2009
    inboard graphics card
    Problem Solver:
  • 15 Answers
Grafix card may be loose
Posted on Jan 12, 2009
I have a foxconn mobo model g31mv and has a problem with the video, well it shows nothing at all. Ive changed the memory, power supply, jumped the bios and check all the wiring and nothing. So.. what...
Try this motherboard troubleshooting beeping code first.
No beeping means short circuit,loose parts.
One beep means everything is working good.
Two beeps means CMOS error.
One long beeps,two short beeps means video problem
Three long beeps means keyboard error.
Continuous long beeps means memory not detected.
Continuous Hi-Lo beeps means processor overheat,loose blower fan heat sink.
If no beeps need to change capacitor parts of motherboard for burn, short and open leakage.
Jul 16, 2011 | Foxconn G31MV-K Motherboard
No beeps, no video, fans working,
no the floppy disk is not faulty, it is normal and required that the floppy disk drive light blink to indicate that the drive is working. And about the power on the power button might be stuck inside that is why it keeps turning on immediately you connect to main power
Aug 03, 2010 | Intel D845PESV Motherboard
No video after replacing chip fan
Try a different video-card -- a "no-spin" fan and "no-video" implies a dead video-card (or at least a video-card that is not "seated' properly).
Check that the PC-speaker leads are connected to the motherboard, so that you could hear any "beep" codes. There should be one "beep" to indicate 'OK', or multiple "beeps" (bad RAM, no video-card detected).
Apr 09, 2010 | ASUS A8N-SLI Deluxe Motherboard
I have an ms9147c mainboard with 2,4gh centrino and it is not working. it makes beeps i need to interprete those beeps
Go to PCSTATS.com. There is a list there. One beep:Everything is normal. 2 beeps:POST/CMOS error. One long, one short beep:Motherboard problem. One long, two short beeps:Video problem. One long, 3 short beeps:Video problem. 3 long beeps:Keyboard error. Repeated long beeps:Memory error. Continuous Hi-Lo beeps:CPU Overheating. Hope this helps. Good luck!
Nov 07, 2009 | Gateway (4000798) Motherboard
NO VIDEO SIGNAL NO BEEPS ONLY CPU FAN WORKING
Please verify that you have a good processor. It seems that your processor is bad.
Oct 31, 2009 | Gigabyte GA-K8VT800 Motherboard
P5S800 board wont post. I have tried with onboard VGA and with video card. It seems the pc wont go to POST. It just beeps continually. 1 long and 2 short. I have reseated the RAM and tried different RAM. I...
That beep code is either a RAM or Video card issue depending on motherboard. It may be that when the fan went down it burnt out the video card slot & onboard video. Without physically seeing the board I couldn't tell for sure, but that is definately what the beep code is pointing to. Also make sure that when you are using a video card that you have the 6, or 8 pin power plug connected to it. As well as making sure both the main 20, or 20+4 psu plug and the 4, or 8 pin psu plug are connected to the mb. Hope this helps.
Jul 14, 2009 | ASUS P5S800-VM Motherboard
No VIDEO!!
Dear,
pl check step by step.
first to hang up all hardware ram,smps,processor with heatsink fan,keyboard all.
After check any beep sound comes from motherboard.
remove ram and check beep sound
remove cmos cell,ide cable and check beep
sound.
NO COMES ANY TYPES OF BEEP SOUND PROBLEM IN *********** BOARD ALOSO CHECK YOUR RAM AND SMPS AT ANOTHER COMPUTER WORKING OR NOT.
Regards,
Ravindra shah
Jun 02, 2009 | Gateway (4000782) Motherboard
Not message, not beep, not at all, this motherboard a8s-x is new, have connect the memory, cpu, fan, video card, keyboard, el power supply is of 400 watts,the fan work.
who have a solution for this problem of my asus a8s-x not boot up, not beep, not message, have connect the memory, cpu, fan , video card, keyborad, this is new, only the fan work.
Thanks
Feb 19, 2009 | ASUS A8S-X Motherboard
Power to everything but CPU fan and case fan - won't boot
Hi this is tech crazy
The solution to the problem is as follows
The main reason for CPU fan overworking or not working is due to the load we put on the syatem while operating.So,the first reason for fan not working may be due to the SMPS malfunctionality.Better check out for it.The reason if fan is working but Overworking is due to viruses is system.So go in for format
Hope this solution helps you
Please do rate me on the above said solution
Feb 04, 2009 | Intel Motherboard
Problem of motherboard
Could be a power supply fault, motherboard fault, or fan fault. Many new motherboards will not power up if the fan doesn't rotate, to prevent the processor getting fried.
Dec 06, 2007 | Intel D101GGC Motherboard
Computers & Internet Logo
583 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
