Question about Sewing Machines
Tension back from repair and the thread is looping on the back
  • Sewing Machines Master
  • 7,365 Answers
Change the needle--make sure it's the right one for the fabric
being sewed
adjust the top thread tension--one letter or number at a time till
stitch looks normal--use scrap piece of fabric for test stitching
clean under the needle plate and in the bobbin area for lint
Posted on Dec 05, 2012
SOURCE: The threads are no longer looping
To thread the overlock you start with the inner most looper first, then the outer looper, then the inner most vertical needle and then the outer. This is the order: | | | | #4 #3 #1 #2 You have to ensure that the lower looper (the furthest one out) has the thread going over the slightly higher looper, the first one you did. If you do this you will be making a stitch. To make the loops fall close to the material is simply a case of altering the tensions on all the needles - I have to do this with my wifes machine. Once I have the tensions for her machine I'll be able to pass them on to you although every machine is different it may give you a starting point. I will try and perform this task this weekend - I'll be online next week and perhaps we can chat and I can send you our tension levels. I hope this helps.. my wife sews and I re-thread - she won't go near the inside of the machine and I won't try to sew :) BXL830
Posted on Jul 13, 2007
SOURCE: Lower thread tension is too loose but no adjustment seems to work
From your description it appears that you have tried tension settings on the upper tension control adjustment knob without success.
Check that the bobin tension is adjusted correctly by taking out the bobin complete with the spool.
Pull the cotton thread and it should be a smooth light pressure if the tension is correct. If it is tight to pull or pulls freely then adjust the tension screw which is found on the outside of the bobbin. The screw is very small and requires a minature size screwdriver. The adjustment will only be a slight turn of the screw one way or the other to obtain the correct tension(depending if it was loose or tight).
Once this is set reinstall the bobin and tread up the machine, hopefully with the upper tension set at approx."2" the machine will sew correctly.
Posted on Nov 29, 2008
Mimito7
  • 128 Answers
SOURCE: Top thread stitches correctly but bottom thread loops.
FYI---- Loops on the bottom-- problem is in the threading..
Loops on the top--- problem is with the bobbin.
Posted on Apr 19, 2009
  • 55 Answers
SOURCE: Difficulty adjusting tension to avoid bobbin looping
it sounds like your bobbin tension is too tight. to adjust bobbin tension, remove bobbin case (remove needle plate first) and adjust bobbin tension screw on side of case until bobbin thread has a slight resistance as you pull it through the bobbin case.
this will be trial and error until you get best result. you should always try and match top and bottom threads. if the top thread is quite thick you may have continue to increase needle thread tension until balanced.
scott
Posted on Jul 26, 2009
  • 1116 Answers
SOURCE: I get loops on top and/or bottom of fabric during
Top tension back to 4 and leave the bobbin tension as is.
Make sure you have a new needle for the type of fabric being sewn installed with the flat side to the back of the machine. A bent needle can sometimes go unnoticed.
Always thread the machine with the presser foot up and this will give proper tension to the stitch.
Check the manual to be sure you are threading correctly (always with the presser foot up) and that the bobbin thread is feeding in the correct direction from the bobbin spool and through the guides.
Take hold of the thread at the needle as you lower and raise the needle to pull up the bobbin thread. Take both thread ends under the presser foot and to the back of the machine.
Posted on Mar 11, 2010
I cannot get the tension correct - big loops on the back with Gutterman all-purpose thread. Have cleaned tension discs and adjusted bobbin tension screw. Checked for correct bobbin and needle thread.
bird nesting ( big loops under material) is from the needle thread tension being too loose
thread the machine as if threading the needle but before threading the needle pull on the thread , there should be resistance to thread feed
if not the tensioner plates are not adjusting properly
Sep 17, 2017 | Sewing Machines
Back side of stitches are loose
increase the thread tension of the needle thread
this is an indication that the tension is not enough to pull the bobbin thread up tight
Jun 15, 2016 | Sewing Machines
Top tension has to be turned all the way down to get good stitch, then thread gets caught in bobbin and lower hooping on thread..
Grab some scrap fabric of the same type you'll be sewing. Tighten your top tension and test sew until you see until you see the top thread of a seam go like a straight line and the bobbin thread loops on top of the seam. Then back off of the top tension until those loops disappear.
If you never see it the top thread go like a straight line... your top tension needs to be cleaned... and make sure you have the pressure foot UP when you thread the upper thread.
Aug 03, 2012 | Sewing Machines
The top thread loops underneath. I believe the
Try threading the machine with the presser foot up and the tension set at 4.
If this does not fix the problem the machine will need repaired.
Mar 19, 2010 | Sewing Machines
Needle thread looping underneath, threads not interlocking at all
If the machine is now threaded, lift the presser foot.
Now, pull about 10" of thread through the needle.
The next time you thread the machine, lift the presser foot first.
When the presser foot is up, the tension control opens and allows the thread to "seat" into the control, then when the foot is down the control closes to the indicated setting.
When threading the machine with the foot is down, thread does not enter the tension control and when you start to sew, there is no tension on the thread.
No tension = loosey, goosey, loopy stitches underneath.
Because the lack of tension on the top thread, the bobbin thread cannot lock a proper stitch.
Mar 10, 2010 | PfaFF Quilt & Craft Pro 7530
Needle thread tension- huge loops
Put the tension settings back to the mfg's suggested setting.
Re-thread the machine with the presser foot up and there will be no more loops.
Mar 03, 2010 | Elna Sewing Machines
Upper thread tension wire broke off!!!
The part that is broken is called a check spring. It keeps the thread away from the point of the needle until the needle pierces the fabric. You should probably take the machine into a reputable repair shop.
Mar 12, 2009 | Brother Sewing Machines
WHITE 2037 TENSION ISSUE...
Okie Dokie..... Here's the way I see it.. The repair center was of little or no help to you . So, I will try to do my best..
First thing you need to do is unthread your machine and set the tension to 4.. Rethread the machine up to just before the needle.
When you get that far, put the presser foot down. If your thread pulls right thru easily, it is not threaded thru the tension wheel right. It your thread is hard to pull thru with the presser foot down, then it is threaded right.
General rule of thumb..
Loops on the bottom-- problem on the top
loops on the top--- problem on the bottom.
Hope this helps..
Mimi
Dec 15, 2008 | White Sewing 2037 Mechanical Sewing...
Looped bottom thread
Sorry I missed your problem, I have just signed up on here to help with problems like yours.
Thread looping underneath the cloth is a bobbin tension problem.
Folks in general are not aware that in addition to the top tension being set correctly so must the bobbin tension.
It is impossible to explain how to do this you need to be shown. However it should be explained how to do it in your manual.
Jan 29, 2008 | Janome Mini Compact
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
