Question about HP " 20"" Touch-Screen TouchSmart All-In-One Computer - 4GB Memory - 1TB Hard Drive 300-1122"
Connected to my wireless router but it says no internet router working on other devices fine
300
    Master:
  • 551 Answers
Your internet devicce must fagged problem otherwise if you use prepaid devicce your account is less.
Posted on Mar 24, 2013
My netgear wireless N-300 adapter is not working. It will connect to the router but not to the internet and my other devices will connect to the Internet on the same router.
If it connects to the router and not to the internet, it sounds more like a configuration problem. Is it being assigned an ip address by router ?
You could try it on another computer to see if it works, that would tell us if it's the device or your windows.
Jun 19, 2012 | NetGear Computers & Internet
How many ip camera can this device handle? i already have 4 existing and it works just fine. How is it if I add 4 more ip camera? Is it going to work well?
D-Link DIR-615 is a Wireless N 300 Router, which delivers great performance, network security and coverage, etc. I have deployed a similar D-Link Router for about 10 Wired and wireless client PCs in a network for file, print and internet sharing and it performed without any issues. So, I think, you can add additional IP cameras and it should work fine.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 20, 2011 | D-Link DIR-615 Wireless Router
I cant get a internet connection with dlink dir-300 (cable or wireless), pls help, it's working when i tried with different router...
Welcome to FixYa! In regards to your problem there are possible options you could follow. 1. Check first if your computer is detecting the router. Go to your Network Connections and see if its detecting a connection with the D-Link router that you have. 2. I suggest go to this site that has a manual for setting up a D-Link DIR-300 Wireless Router.Check if you missed any of the process. Steps: Go to Google.com then type "cant get a internet Problem with the D-Link DIR-300 Wireless Router" and then look for DIR 300 Wireless Router Manual. There you will find all that you need in setting up your router. Hope this helps! Thank you for using FixYa!
Jul 04, 2011 | D-Link DIR-300 Wireless Router
My wireless router isnt working. I have a NETGEAR Wireless-n 300 Router with the label WRN2000. Is this a strong router and can I get a stronger one that produces the capability to use more wireless...
That is a good router.
Is your wireless device (iPad? laptop? notebook?) using a Wireless-N adapter?
If not, all you get is the much-slower "Wireless-G" speed.
Measure, measure, measure.
If you use an Ethernet cable to connect from your computer to your router, do you get a much-faster connection?
How far (and how many walls) between your router and your computer?
Dec 14, 2010 | NetGear WNR2000 Wireless Router
Can't establish connection by cable
Assuming you would have checked your LAN port. Try using a USB LAN port device and see if it picks up. Else you can test connecting the modem via Ethernet cable to another machine. Does it work,? If it does then its your machine.
Apr 11, 2010 | D-Link DIR-300 Wireless Router
My dir 300 is working fine but it disconnects from the internet
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Jan 09, 2010 | D-Link DIR-300 Wireless Router
D-Link DIR-300 Router not working properly
Try to configure your router again, maybe that will solve your problem.
Jun 24, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
I have a dir 300 router that when i try to hook it up it i cant
 Let me clarify this  your internet works when your PC is hooked up directly to the modem....
When you connect the router between the pc and the modem the internet does not work....
This sounds like the configuration settings inside the router need to be setup or adjusted.
Go to the web browser and type in 192.168.0.1 and for the username type admin and then leave the password blank hit enter and it should sign you into the router. Follow the setup wizard and everything should work just fine.
Hope it Helps!
Apr 12, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
No Active Internet Connection
If you want to use the wireless portion of your router, you would need a wireless adapter installed on your desktop. If you are getting internet on your desktop then this means that your wired connection is fine to the router is fine. The WMP54G adapter will work with your router, however if you are not planning on connecting to the internet wirelessly through the router then there is no need to purchase the adapter. Hope that this helps you out.
Serge C.
Mar 30, 2009 | Linksys Wireless-G WRT54G Router
HP " 20"" Touch-Screen TouchSmart All-In-One Computer - 4GB Memory - 1TB Hard Drive 300-1122" Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
