Question about Ryobi RCS3535CA 14-inch 35cc Petrol Chainsaw
My rcs5335s engine starts but wont keep running, its starts ok but fizzels out after a few seconds
May have to do carb adjustment
Posted on May 13, 2014
Chevy tahoe 1999 now it starts but runs for a few seconds then i wait it starts and run for a few seconds again
Seem's like your fuel pump isn't able to keep the good fuel pressure.
Might be a good idea to check your fuel rail pressure. I assume that it drops before your engine dies!!!
If fuel pressure is ok in your rail, try cleaning the fuel rail and injectors. Sometimes dirt can go from a trashed fuel filter an clog yor rail or the injectors.
Jan 27, 2014 | Chevrolet Chevy Cars & Trucks
Engin wont stay running after it starts
How long does it run? A few seconds or minutes? Sounds fuel related. Generally rebuilding or replacing the carburetor will fix it if it starts and dies after a few seconds. If it runs for a few minutes then we need to look at something else for the issue
Jan 15, 2014 | Tecumseh 5hp Engine Snow King Mtd Blowers...
RUNS AND QUITS
You could try replacing the ignition coil. If it's failed, then it may run ok for a few seconds, but as it heats up it fails. Trying to start again immediately will be too soon for the coil to have cooled down. Leave it a few minutes to cool down and it will run again, but only for a few seconds again.
Hope that helps
Jan 03, 2014 | kawasaki 2011 Teryx 750 FI 4x4 Sport
93 toyota pickup 4x4 it will stay running after I turn it on to start it up, it starts up then after a few seconds it kills
if I'm reading this right...
... the engine starts and dies within a few seconds.
... you jumpered the fuel pump test connector and it will keep running.
... you smell fuel after trying to re-start when it dies.
Disconnect the plug to the cold start injector. Even if you have an issue with the engine running then dying after a few seconds after doing this, if you don't smell fuel after disconnecting the cold start injector and try to restart it, the cold start time injector time switch may be failing.
Buy a can of starting fluid and have someone start the engine then spray short bursts of the fluid around all the intake fittings. If spraying the fluid in any particular area keeps the engine running, I'd start looking for leaks around that area.
It does sound like an AFM or COR issue considering it dies after a few seconds, but the fuel smell when trying to restart the engine may be a separate issue that needs corrected / isolated first.it will keep running.
Mar 30, 2013 | Cars & Trucks
My 1993 nissan sentra 1.6 wont run and check engine light wont turn on,bulb is ok
Could be any of several things. If the crank sensor is marginal and not sending pulses, the fuel pump is shut off. This is for safety. The pump is energized for a few seconds as key is turned in preparation for starting then engine must rotate normally to keep the pump on. If it stops, in a few seconds the fuel is cut off.
Aug 17, 2012 | 1993 Nissan Sentra 4 Door
05 jeep grand cherokee, starter works, when i use starting fluid, will run for a few seconds, but wont stay running
The engine is not getting gas. Check fuel pump fuse and relay. If ok could be bad fuel pump.
Mar 02, 2010 | 2004 Jeep Grand Cherokee
Washing machine
Pressing and holding the two centre buttons ie on/off and start/cancel together for a few seconds causes the machine to run in 'test' mode. Doing the same again puts it back to normal wash.
I nearly called an engineer once because my daughter causes it all of the time!
Sep 28, 2008 | Hotpoint Ultima WF860 Front Load Washer
Ryobi RCS3535CA 14-inch 35cc Petrol Chainsaw Logo
149 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
