Question about Kenmore 63942 Dryer
Hello....i can start my in-laws dryer manually only, by holding the door switch closed, pushing the start button and rotating the drum counter clockwise. sound like a bad motor? thanks for your help
    New Friend:
  • 88 Answers
You are right about that, that motor is finished.
Posted on Jan 14, 2009
Dryer makes a buzzing noise when I turn it on but it doesn't come on, just buzzes.
Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem.
What is the model number?
Nov 06, 2012 | Dryers
Kenmore dryer 70 series doesn't always start, sometimes it will just put out a buzzing sound after its been running and trying to restart, will start back up after 20-30 minutes.
Oct 02, 2011 | Kenmore 63942 Dryer
Maytag Performa dryer blows fuse after clothes get hot. I cleaned a large buildup of lint from inside the dryer all the way to my roof. I then replaced the hi limit thermostat, thermal fuse and dryer...
their are two possiblities causing that
1) while cleaning the lint from the motor a wire accidently got pulled of of the motor switch
2) to me the buzzing when start button is pushed and may or may not start,the motor is bad
When trying the trick to start the motor by hand the door switch also must be pressed in
Gene
Aug 05, 2011 | Maytag PYE2200 Dryer
Start button buzzes when pressed, dryer doesn't start.
I assume the buzzing quit when you release the start button. Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem.
Apr 26, 2011 | GE DVL223EBWW Electric Dryer
My dryer keeps shutting off after about 10-15 mins. It starts make a noise likes it's slowing down just before it shuts off. If I try to push the knob back in to restart. It will make a buzzing noise. If I...
Mar 13, 2011 | Dryers
The dyrer will not turn on. The dryer makes a humming noise but will not turn on.
Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem. Also, check the blower on the dryer to see if a article of clothing may have gotten stuck there and preventing the motor from running.
Jan 22, 2011 | Whirlpool Dryers
Model # 72852 Burning smell Drum does not turn but a humming noise When door is closed it hums without the start button being pushed.
f you hear the motor humming and not starting at all it most likely has a severe friction problem with the drum or motor. It could possibly have some type of garment jamming the blower wheel preventing the motor from starting too.
Open the dryer door and manually rotate the dryer drum counter clockwise (CCW). It should take very little effort to rotate the drum. If it's hard to rotate that could explain why the motor hums instead of starting up. If it turns freely, shut the door and see if will start. If it still hums and not start it may have bad motor or a low voltage supply to the motor.
Jan 18, 2011 | Kenmore Dryers
When we press the button to start the dryer, we hear the buzzing but the dryer does not move.
Jan 09, 2011 | Frigidaire Electric Dryer
Have a Kenmore 90 series gas dryer. When I press the button to turn it on, it makes a noise but won't start
Assume the buzzing quit when you release the start button. Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem. Check the blower fan and motor for any obstructions.
Jan 09, 2011 | Kenmore Dryers
I have to manually get drum turning...
Yes, there is a "startup" switch. It's the button you push on the panel (but I'm sure you know about that).
This switch energizes the start winding in the motor -- when the motor gets up to speed, a centrifugal switch in the motor disconnects the power from the start winding and switches to the run winding.
Either the start winding is not getting power or the winding is bad. If "no power" is the problem, it could be the button on the panel or a loose/dirty connection between there and the start winding. Lot of possibilities which need to be explored.
But if you know about pushing the safety switch on the door and spinning the drum by hand to get the motor started, you can probably fix this.
May 04, 2009 | Amana NDE2330AY Electric Dryer
Kenmore 63942 Dryer Logo
37 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
