Question about UXcell Alba LST-048 (2 GB) Digital Media Player
Hi i have an alba mp4200buk 4gb and i would like to if i am able to put it on shuffle???
It has no screen and only has play/pause, forward, rewind, + and -?
Why does my MP3 player not play the songs that I have put on it. I knows that they are on because it says so when my device is connected to computer
Could your missing files be some other format, such as FLAC or MP4 or WAV? Some players only play MP3 format
Oct 23, 2014 | Audio Players & Recorders
How do i turn on my Polaroid Shuffle 4GB MP3 player?
There is a led light in the upper right corner of the front. The controls are on the large round button in the center. To turn in on, press in the center of the button; the device will turn on and playback will begin. To turn it off, press AND HOLD the center of the button until the LED light flashes several times and then turns off.
To play, press the center of the button and the LED should come on and stay solid. To pause, press the center and the LED will blink once a second Press again and playback will resume.
Think of the big button as a clock face. Press at 12 for volume UP. Press at 3 for next track; HOLD for fast forward. Press at 6 for volume DOWN. Press at 9 for previous track; HOLD for rewind.
For shuffle, press at 12 and 6 together and hold for 2 full seconds. The LED will flash 4 times to show you are in shuffle mode. To go back to normal playback, press at 12 and 6 together for 2 full seconds and the LED will flash 2 times to show you are back to normal mode.
Jul 15, 2014 | Polaroid Audio Players & Recorders
Alba DVCR-2 Err:03, Err:02, Err: 01 problems
you have a faulty SYSCON MICROCONTROLLER.+faulty associates circuits, like CLKS, RESET.
you must go to the repair shop TV for fix it.
However you can try as the last thing before to go the repair shopt, Clean tHE VHS+DVD, with tape cleaner+disc cleaner too.and Proof
God bless you.
Aug 02, 2012 | Broksonic DVCR-810 DVD Player/VCR
I am trying to find out what the blue symbols on the function keys of my sk 9020 keyboard stand for
The blue keys serve as a secondary function for your volume control, monitor controls and pause play fast forward rewind (in media mode). In order to use the blue keys that are numbered from F1 to F12, you must depress and hold the Fn key that is located at the bottom left side of the keyboard. Here is a way to test it: Open up any file that plays sound for longer than 1 minute (60 seconds). While this file is playing, hold down the Fn key and simultaneously press F8 and listen to the volume get louder or Fn and F7 together and listen to the sound get lower. The picture of the crescent moon F1 will adjust the brightness of your screen. F2 will magnify your screen. F3 will take you to your email. F4 will take you to your internet home page. F6 will mute the volume. F7 will lower the volume. F8 will raise the volume. F9 will rewind your video playing. F10 will stop the video. F11 will pause or play the video. F12 will fast forward the video.
Mar 06, 2012 | Gateway (7001434) Keyboard
I do not know how to use it, i have the manual, but i do not find it
The recorder takes 2 AAA batteries. Press Menu/Folder (on the right above the jogdial (Stop, Rewind, Fast Forward, Play)) to select the folder to add a new recorded item. (The folders are A,B,C, or S. Folder S will come up with a date and you can select another date for the recording.) Folders A, B and C can hold 100 files each; Folder S has 365 dates which can hold 15 items each.
Press and hold the Menu/Folder button for a second or longer. The Screen should show the Mode menu. Press Play and then the Fast Forward and Rewind buttons to set the recording quality. HQ is the high quality recording and will fill up the available storage on the organizer more rapidly. LP will record for the longest period.
Set the Microphone sensitivity by pressing and holding Menu/Folder. Then press the Fast Forward or Rewind button until Mic appears on the display. Then press Play and use the Fast Forward or Rewind buttons to select Low or High sensitivity. (An external mic often gives better results.)
Once you have set the folder for the next recording and the recording quality and microphone sensitivity, press Rec (center above the jogdial) to start recording. Press Stop to end the recording or Rec to pause it. (It will stop if the Pause is longer than 10 minutes.) Press Display to see how much longer you can record before using up the available storage space.
To play back a record, locate the item in the folder then press Play.
The manual for the Olympus VN-1800 is available from the Olympus support site: http://www.olympusamerica.com/cpg_section/cpg_support_manuals.asp?id=841 . The direct link to the English version of the manual is http://www.olympusamerica.com/files/oima_cckb/VN-900_VN-1800_VN-3600_Instructions_EN.pdf .
I hope this helps.
Aug 30, 2011 | Olympus VN-1800 Digital Voice Organizer
Shuffle mode
Cut and modified from Douglas E. Levy at Amazon forum:
When you're in the Now Playing screen press and hold the Play/Pause button (right edge of screen). At the top of the slide-in menu you'll see Play Mode. Click Pause button again and scroll to "Normal" and choose it.
Jul 03, 2009 | iRiver Audio Players & Recorders
Rewind and fast forward
Put the cd in when it loads and display the disc time, you can then spin the round wheels forward or backwards to the place on the song that you're playing, this only work when the song is paused or stopped. If the disc is playing the wheels are only used to slow down or speed up the song.
J Lofton(2Housepeople)
Oct 17, 2008 | Gem Sound CDM-150 Mixer
Audiobook download
Playing Songs, Audiobooks, and Podcasts on iPod shuffle iPod shuffle allows you to play your audio files in a couple different ways—you can play songs, audiobooks, and podcasts in the order in which they appear on your player, or let iPod shuffle work its namesake magic for you (that is, shuffle the files by playing them randomly).
Show Me How
If you want iPod shuffle to play audio files in the order in which they appear on the player, move the switch on the top of the iPod shuffle to the play in order (circular arrows) position. If you want iPod shuffle to play songs in random order, move the switch to the shuffle (crossed arrows) position.
ip02_playfnky_04_shuflebutton.gif This iPod Shuffle is set to shuffle.
To play music, an audiobook, or podcast, just press the Play/Pause button. To skip to the next song (or a different song if you're in shuffle mode, or a different chapter if you're listening to an audiobook or podcast), press the Next/Fast-forward button. To fast-forward through the audio, hold down the Next/Fast-forward button. To go back to the beginning of a song (or the previous chapter), press the Previous/Rewind button; press this button twice to go to the previous song or hold it down to rewind through the file.
To stop play, press the Play/Pause button during play. To turn off iPod shuffle, move the switch to the Off position (you shouldn't see green beneath the switch).
Jan 24, 2008 | Apple iPod shuffle Second Gen. Silver (1...
I-Pod not playing
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
http://www.apple.com/support/ipod/five_rs/
If you need more asistance, let me know. Good luck.
Jan 05, 2008 | Apple iPod shuffle Second Gen. Silver (1...
UXcell Alba LST-048 (2 GB) Digital Media Player Logo
104 people viewed this question
Top UXcell Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an UXcell Audio Player and Recorder Expert? Answer questions, earn points and help others
