Question about Watches
I do not have the old battery for Seiko model 7N43-8119 A4 watch
I need to know the model number of the battery for the watch listed above or a compatible battery.
SOURCE: seiko watch stuck crown
The crown maybe a screwdown type. Try unscrewing (like jar lid)them pulling out the crown.
Posted on May 04, 2007
  • 373 Answers
SOURCE: Replacement battery for Philippe Starck Fossil watch
can you check on web site
Posted on Jan 31, 2009
escapement
  • 2334 Answers
SOURCE: Resetting a SEIKO watch
You may can find instructions here:
http://www.seikousa.com/#FAQ
Go through the watches till you find the match.
Rate me, please.
Posted on Mar 14, 2009
  • 12 Answers
SOURCE: how to remove back for battery replacement - 19
This is a little tricky, I think this has a screw on back. It takes a two or better a three prong tool to remove back. A new seal shoud be on hand to replace this. Watch should have a consumption test and a min run voltage test, if either of these fail a new circuit board or movement should be installed. Take it to a good watchmaker and they will clean the outside before opening and do a water resistance test after assembly.
Posted on Jun 14, 2009
SOURCE: reset timer after battery change in seiko sna285
If the stop watch hands are not in the "0" (12 o clock) Position, follow the prodedure below to set them to the 12 o Clock position
1, Pull the crown to secound position
2, Press Button "A" for 2 seconds.
3, Press Button "B" to Adjust the minute Hand to "0" Position
4, Press Button "A" for 2 secounds then press Button "B" to adjust secound hand to "0" Position
5, Press crown into normal position
AmFix Jewelry & Watch Repair
203 N. LaSalle Street,
Chicago, IL 60601
Ph: 312 641 7000
Email: info@goamfix.com
Web: www.goamfix.com
Posted on Aug 28, 2009
What is the battery specifications for DKNY ladies Watch NY3971?
If you look at the movement inside the watch it should be possible to find the movement number (you might need a loupe or magnifying glass to see it clearly) and name (e,g, Seiko-Epson, Miyota etc.)
If you can supply that information I can tell you which battery it requires.
Oct 03, 2016 | DKNY Watches
I need help finding how old a womens Seiko watch it has two set of numbers can u help me
Farrah, Contact Seiko or try Google search your watch Seiko # and see what comes up then try the second #. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Ladies Watches
Seiko Ladies Gold Dress Watch Maroon Dial Gold Mesh Bracelet Ca 1970s
Seiko ladies watch Gold with maroon face Google Search
Aug 08, 2016 | Seiko Watches
Need help identifying watch
Take it to a local jeweler and they will tell you all about it for free.
Search Results
How to tell when your Seiko watch was made (Part 1)
quartzimodo.com/how-to-tell-when-your-seiko-watch-was-made-part-1/ Sep 21, 2010 - If you can't see the serial number on the glass, then look for them on the caseback ... Every Seiko watch manufactured is given a 6-digit serial number. ...... Your old Seiko watch is likely to be from the Seiko Sportsmatic or the ...
WatchSleuth - Seiko Date Finder
www.watchsleuth.com/seikodatefinder/ Seiko Date Finder - Find out when your Seiko watch was made. ... In the example images the serial number is highlighted in blue. Every watch has a unique combination of reference ... the watch was made. Looking at the example images:.
Watch Finder ' Seiko
www.seiko.com.au/collections/seiko-watch-finder Watch Finder. Seiko Watch Finder · Seiko Clock Finder. Search by Model Number. Collection. - Any -, Grand Seiko, Astron, Prospex Platinum, Prospex, Presage
images below
older seiko watch with dubai australia chicago on bezel Google Search
Jul 31, 2017 | Seiko Watches
My kenetic battery ( i think) operated watch ,N0, on the back plate-
First, does it say "Kinetic" on the face of the watch? If not, it is not a Seiko Kinetic. (You did not mention if it was a Kinetic or not.)
Second, the Serial number is not like any Seiko Kinetic I know, which is 2 4 digit numbers.
Third: The number you gave itself may indicate the type of button battery you need.
Good luck.
Mar 02, 2013 | Seiko Kinetic watch
Which watch battery fit my Pulsar?
372 or 373, they are interchangeable. It was listed under Seiko and not Pulsar.... the key model # is the vx43, the rest wasn't used. My source: MAXELL 373 SR916SW 1 Battery Official OEM 372 373
Feb 28, 2012 | Seiko Watches
Seiko watch ser#687612,need a new battery,need to know which one
Hi there, can you look on the back of the watch for the model number. It should be similar to 7T62-0AC0 - I can then tell you which battery you require -
May 11, 2010 | Seiko SNA413 Wrist Watch
I need a manual for a Pulsar watch calibur #7T62
Pulsar are made by Seiko and support can be obtained from their web site. (The number your quoted is a Seiko number- all Pulsar models seem to start with two or three letters).
Put "www.seiko.co.uk/support/instructionbooklets" into you search engine and you should come to the Seiko instructions list. Scroll down to find your watch and download the instructions.
Mar 06, 2010 | Seiko Pulsar watch
The ease of repairing Seiko watches.
No. First off no watchmaker has a "parts account" with Seiko. Seiko only sells watchbands to watchmakers. All other Seiko parts are sold through supply houses.
Seiko parts are not hard to find most times. The very old Seikos will have parts issues and some of the current styles of Japan only Seikos will not have parts available.
Case tubes for all Seiko watches are not available at all.
Finding parts for Seiko watches requires the use of the watches model number which is on the case back of the watch. The number listed in the title is not a model number. The SKA098 is a retailers number so the retailers can reorder the watch. It does not cross reference for parts.
There are many watchmakers that don't want to service Seiko watches so they can and do make up all kinds of stories as to why it is impossible to repair them and so on.
Actually Seiko is much better about parts supply than any of the Swiss watch companies.
Hope this helps.
Ken
Yellowstone Watch Inc.
Oct 01, 2009 | Seiko SKA098 Wrist Watch
Rate me, please.
Mar 14, 2009 | Seiko 0512037FA Wrist Watch
Setting time/date on old Seiko
With our 10 year old grandson's help, my husband was able to figure it out. Took a while, but he is now wearing his watch again!
Thanks for the follow-up.
Feb 08, 2009 | Seiko Watches
Watches Logo
57 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
