Cannon ipf750, has error code, 03130031-2f3a - Office Equipment & Supplies
Cannon ipf750, has error code, 03130031-2f3a - canon-ipf750-ipf750-user-manual-612e713_450_c239a330-oeferhzstr5xvjizix4fodki-5-0.png
Posted on Jul 22, 2017
Error E161-403E
Go onto the Canon Europe site and locate the error codes for your device. It will indicate the type of problem but not how to fix it.
Jul 05, 2016 | Canon imagePROGRAF iPF750 MFP
Error e161 403e en canon ipf750
Canon IPF750 Error Code E161-403E - so, I understand this means the printer head is shot & needs to be replaced.
Feb 03, 2015 | Canon Office Equipment & Supplies
Canon ipf750 error 2F30
Esse error ? relacionado a troca da cabe?a de impress?o.
Nov 07, 2013 | Canon imagePROGRAF iPF750 Wide-Format...
Error code 03130031 2618 print
The hardware error code indicates that a print head failure has been detected. Other possible causes of this error are a faulty cable connection to either one of the PCB's.
First try replacing the Print Heads and if the problem persist, re-seat the cabling to the Relay PCB and the Carriage Unit PCB.
Since you are unable to access service mode, you will need to ignore the normal print head replacement procedure and replace the printheads whilst the plotter is turned off.
The plotter will need to be disassembled to access the print head.
See the following service manual for a detailed guide:
http://mail.davin.be:8888/CANON/BOOK%20IPF/IPF750/ipf750_755-sm.pdf
Nov 06, 2013 | Canon imagePROGRAF iPF8000 Printer
Canon ipf750/upgrade firmware
I would first check the linear scale.That`s a small plastic strip ,positioned along the total lenght of the rail.Mind you ,I don`t have a ipf8000.But maybe the systems are the same.The linear scale is under tension ,by a metal spring.Check if the strip is not hanging loose.Also check the strip (linear scale) on dirt or ink splashes.If so clean it with alcohol (that`s what I did on a ipf5000).The scale runs through a slit ,at the back of the carriage.There are light grey patterns on the scale.The sensor on the carriage reads them ,and thus knows the position of the printheads ,with respect to the rest position.Check if the scale runs smoothly through the slit.
Feb 27, 2013 | Canon imagePROGRAF iPF750 Wide-Format...
Canon ipf 750 e161-4050
The error refers to a purge motor failure. Which could explain why the printer is saying that you do not have enough ink. You can solve this error code by removing the purge unit. You have to replace the purge unit with a new one.
Read more: E161-4050 on iPF750. error not in manual. Cleaned print head? - What is this? Not on internet anywhere. I`m sure others have had this issue. :: Ask Me Fast at
Jan 11, 2013 | Canon iPF700 InkJet Printer
Canon IPF8100 error code 03130031-2F3A can you please help vicki@westcountry.com.au Thanks
Same error in my ipf755. Canon suggests replacement of carriage (700 eur)...
Feb 16, 2011 | Canon imagePROGRAF iPF8000 Printer
269 people viewed this question
jasbo
jasbo
