Question about Maytag Neptune MAH5500B Front Load Washer
E3 code flashes when ready to spin - Maytag Neptune MAH5500B Front Load Washer
    Top Expert:
  • Maytag Master
  • 9,472 Answers
Evaluate wire harness for loose or unhooked connections.
Posted on Dec 05, 2012
What does the E3 code mean on the 540 model and is there a fix?
Troubleshooting the "E3" error code in Maytag MAH6700 ...
fixitnow.com/.../troubleshooting-the-e3-error-code-in-maytag-mah6700-...
Feb 20, 2011 - These codes in your (made-by-Samsung) Maytag washer might pop up during the ... In fact, the E3 error code means that the Machine Control wants to make the motor spin but won't do it because it's getting a weird reading from the tachometer.... MAH6700 and MAH8700 models (they use the same motor).
I have a samsung frontload washing machine. A code E3 is ...
www.shopyourway.com > Denise LaGrasse > Questions
Mar 15, 2014 - My samsung front loader is not working. do not no what E3 means. ...code F26 mean on a Kenmore Elite model 110.4708 washing machine?
How To Fix 3E Error Code On A Samsung Washing Machine
www.appliancerepairlesson.com/.../how-to-fix-3e-error-code-on-a-samsu...
May 15, 2015 - Samsung uses the 3E error code to indicate a drive motor tach fault. ...If you're handy, you can fix your Samsung front load washing machine error code ....My samsung frontload washer shows e3 and the drum does not turn ...
Jan 06, 2016 | Washing Machines
Wont pump out comes up with E3 on display
CLOGGED WATER PUMP HINDERING DRAIN AND SPIN CYCLE
Jun 11, 2015 | Washing Machines
Error e3
Thank you for your post, friend!
I understand that your Electrolux washer is displaying an "E3" error code while it is spinning. However, it appears "E3" is an invalid error code. It is possible that the error code is missing characters? I suggest resetting your washer. You can do this by flipping the household circuit breaker for roughly ten minutes. If resetting the power does not correct the issue, and your washer continues to display "E3" I would recommend contacting a professional to come and properly diagnose your appliance. -Matt
Aug 11, 2014 | Electrolux Washing Machines
E3 flashes when ready to spin
E3 = Machine control is attempting to drive the motor but is not seeing any tach response.
Post back the results.
Dec 05, 2012 | Maytag Neptune MAH6500A Front Load Washer
I got an E3 flashing, what does that mean. The
Okay; This will essentially be a Hall Sensor fault. The Error code (E3) Is issued when the Motor control board is attempting to drive the motor (during the spin out), but is not seeing any tachometer response readings. The Hall sensor monitors such movements to relay the necessary rotation information to the Motor control board. When the Hall malfunctions, the MCB will assume that the motor is "locked" and it will issue the (E3) code.
The necessary actions are to replace the Hall sensor. Here is a picture of the Stator(Motor) and Hall sensor.
Click here to access the service/repair manual for your unit. This manual will help you disassemble the affected area. You will first need to remove the rear access panel, before gaining access to the affected section. Once the rear panel is removed, focus on page 33-34 to help with removing the stator so that you can replace the damaged hall sensor. Please allow time for the manual to download, due to its size.
  • Once you have replaced the defective Hall sensor, the unit will return to its normal operating status.
Jul 25, 2010 | Maytag Washing Machines
E3 code error.
“E3” code – Machine control is attempting to drive the motor but is not seeing any tach response. Visual Check shows motor is not moving. (Locked or Hall Sensor fault.)
Possible causes of ‘E3’ codes: 1. Spin drum stuck – Verify that the spinner moves freely to eliminate this cause. 2. Hall Sensor fails or is loose – When the Hall Sensor fails or becomes dislodged, the control doesn't recognize that the motor is spinning and shuts down. The result will likely be an “E3” code in the worst case, or “SUdS” if it is only getting a partial rpm reading. Check wire harness connector(s) to motor.
Hall Sensor – PCB that is located on the back of the motor that senses motor rpm. It is not a separate part, but rather an integral part of the motor.
Sep 20, 2009 | Maytag MAH2400A Front Load Washer
E3 error
Aug 20, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytage Neptune E3 code - Model MAH8700AWW - machine won't finish cycle
May 28, 2009 | Maytag MAH6500 Neptune Front Loading...
E3 code showing sometimes on Neptune MAH-3
Mar 11, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
23 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
