Question about Gateway Computers & Internet
How to open dvd to get disk out
Dvd eject dvd
  • suespiker
    suespiker Dec 07, 2012
    Found button on side of computer, wanted to open to put CD in
  • Gateway Master
  • 7,627 Answers
Open Computer in start menu, right click on the DVD/CD rom, Eject. If that fails,Turn off the machine, use a thin instrument to manually pry open the tray. OR remove the DVD/CD rom and disassemble the case. If the DVD or CD has exploded.
Posted on Dec 05, 2012
My dvd player is stuck on one dvd and wont let me eject, change disc, or even stop the current dvd. display reads "locked" whenever i press any buttons. can only turn on and off the device.
Hi, For some reason the disk will not play. You push the eject button over and over again, but the disk slot will not open. Here's one solution...
* 1 Turn off the DVD player. Wait a few minutes, turn the DVD player back on, and
then press the "eject" button. If this does not work, turn it off and unplug
the DVD player...while you keep pushing EJECT button plug the DVD and turn it on (your hand still on the eject..) is should come out..
* 2 ..if it does not eject , unplug the DVD player again, Remove the screws off DVD on the sides and take off the DVD casing.
* 3 Look for the DVD holder inside the DVD player. This device holds the DVD in
place while the DVD player reads the disk.
* 4 Push the stuck DVD disk toward the front of the DVD player until the DVD
ejects. Remember the DVD player is not on and some force ( gentle ! ) must be applied.
* 5 While it is open,plug it on and place a DVD disc just to see if mechanism works properly..
* 6 Replace the casing and the screws. Plug the player in and turn it on. Put
another DVD in to test whether the player is finally working ..
Hope this helps!..
Take care and please
Remember to rate/vote and give us 4 Thumbs Up
to continue f
or Helping out the Community :)
Jul 09, 2011 | Televison & Video
DVD does`t open. It have one disc inside and I need it. Exist one software command (by pc) that permit to open the dvd without use the open key? Thank you, Jorge Lopez
Any operating system that believes the disk is in use may restrict the disk bay from opening by the use of the drive button or a soft eject keystroke. In Windows this most commonly happens when the system believes itself to be actively accessing or installing from the CD/DVD drive when actually the disk is unreadable, the drive has become unmounted, or a software product has locked the drive. In this case, there is no soft key command to force it to open.
You essentially have three choices:
  1. Wait for the application using the drive to time out and then eject the disk normally
  2. Force quit the application or software that is monopolizing the drive then eject the disk.
  3. Restart the computer to terminate any processes currently monopolizing the drive.
  4. Force a paper clip in the small access hole to manually eject the drive. (I know this third is exactly what you didn't want to do)
Apr 26, 2010 | Sony (DDU1613) (ddu1613black) Internal DVD...
IMac5,1 DVD-R won't eject.
restart mac and hold down the mouse after you hear the startup noise
if that does not work try opening up disk utility and click on the icon of your disk under the left hand column then go up to eject button and click eject
Hope this helps.
Oct 30, 2009 | Computers & Internet
I inserted a disc (dvd) it will not eject. any
If the disk will not eject but however you got full power to the dvd rom then the dvd rom will need to be removed from the laptop and then opened up to manaul eject the disk.
Jun 30, 2009 | Dell Studio 15 Laptop
DVD DOOR AND VCR DOOR WILL NOT OPEN, DOES NOT EJECT TAPES OR DISK
I have had some luck in unplugging the machine for five or ten and then trying again. I have spent five to ten minutes trying to get the darn thing to spit out the disk and it refuses. Unplugging either gives me time to cool off or it helps the machine :)
Apr 30, 2009 | Panasonic PV-D4745S DVD Player/VCR
Dell Inspiron-1520 unable to read RW DVD's.
you have a faulty disk inserted in the drive. Restart the computer and continuously press eject while the pc is booting, it should eject then.
Oct 11, 2008 | Dell (313-1220) CD-RW/DVD-ROM Combo Drive
DVD Eject tray stuck
I took a stake knife from the kitchen and pried open the tray door as I hit the eject button this got it to open, I then cycled eject and close, eject close a few times and this did the trick, I even played a DVD and that worked fine also. I had the problem with the tray not opening, and the display would read OPEN when I hit eject and I could hear it trying to open. So I wanted to make sure the tray wasn't just stuck or wedged before I took the system apart and looked for sripped out plastic gears or the belt being broken. GoodLuck rayruiz10@yahoo.com
Aug 24, 2008 | Zenith XBS344 System
Sony DVD RW DRU-820A
HI,
Double check the Ribbon Cable Connector is installed Correctly ( 40-80 Strand IDE ) sometimes if these are not fitted squarely Or pushed in hard enough. Can cause a Problem.
Also try the emergency eject procedure on The Drive. Small jewellers screwdriver Or Needle, insert into the drives faceplate ( pinhole in drives faceplate drawer ) push to open dvd drawer. pull out drawer Gently. And push back in. This ocassionally works for a stcking Drawer/eject mechanism.
Finally try the drive without a disk in ( open/eject Or Close )
Mike @ Compurepair.
Jul 01, 2008 | Sony DRU-820A DVD RW Dual Layer Burner
DVD Tray will not open
Uhm..
Unplug it/turn it on and off
Try to press the eject button and lightly pry the tray open with your fingers.
Call support.
Good luck
Dec 21, 2007 | Jwin JD-VD130 DVD Player
Computers & Internet Logo
64 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
