Question about Whirlpool Refrigerators
Icemaker not working
Icemarker not working Whirlpool ET1CHK/ET1CHM
3 Suggested Answers
peyton32034
  • 410 Answers
SOURCE: defrost parts missing ? Whirlpool ET1CHK / ET1CHM
there should be a wiring diagram in the kick grille at the bottom of the refrig.
Posted on Mar 03, 2009
TheMobilian
  • 8220 Answers
SOURCE: water is in the bottom
That water should be draining out the hole in the evaporation compartment. The defrost drain is stopped up. Remove the service panel and get the junk out the hole and the water from defrost will drain out instead of in the bottom.
If ice is forming in the hole a neat trick to know is to run a wire from the defrost heater down in the hole a hair to keep ice from forming over the drain hole.
Posted on May 17, 2011
Water is in the bottom of frig, whirlpool inside advantage, et1chk/et1chm,
May 17, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
Water in bottom of the fridge. I figured the
copper wire is best with a bit of cloth to pull thru
Feb 05, 2010 | Whirlpool 20.9 cu. ft. Top Freezer...
Ice stays in icemarker
Sounds like the heater in the ice maker to release the cubes isn't working. Best off to call a reliable service company such as Sears.
Feb 01, 2010 | Kenmore Refrigerators
Hi, I have a 20.9 cf (#ET1CHK/ET1CHM). Water
I HAD THE SAME ISSUE EVERY FEW MONTHS. REMOVE THE BACK COVER IN THE FREEZER, YOU WILL SEE A SILVER TRY WITH MOST LIKELY ICE IN IT. THAW THAT ICE AND THERE IS A DRAIN HOLE IN IT. USING A HAIR DRIER GET THE TUBE TO THAW ALSO. ONCE WATER IS FLOWING TAKE A PIECE OF 12 GAUGE BARE COPPER WIRE AND SLIP IT ABOUT 18" INTO THE HOLE. WRAP THE OTHER SIDE OF THE WIRE AROUND THE WIRE COIL YOU SEE WHICH IS THE DEFROSTER. WHEN IT WARMS IT WILL HEAT THE WIRE ALSO AND KEEP THE DRAIN CLEAR
Dec 28, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Freezer coil and back of freezer full of ice, never defrosting
Low on freon or the blower fan has stopped
Apr 11, 2009 | Refrigerators
Defrost parts missing ? Whirlpool ET1CHK / ET1CHM
Mar 02, 2009 | Refrigerators
Whirlpool icemaker
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Jan 23, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
The icemaker stop working on my Whirlpool side by side frig
If there are ice cubes setting in the icemake waiting to be dumped then the icemaker is bad. If the icemake is dry then the water valve is bad. You have one water valve with two solenoids. One works water in the door and the other sends water to the icemaker.
Dec 15, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
ICEMAKER DOES'NT WORK.
hi there sounds like your control pcb is at fault
Dec 13, 2007 | Whirlpool (ET8FTEXSQ) Top Freezer...
Refrigerators Logo
23 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
