Question about Genie Company Televison & Video
Will a genie remote model # g3t-fr operate a model # 820 genie garage door opener
SOURCE: Reprogramming a Genie garage door receiver
I ned a akai audio timer DT-100
Posted on Aug 18, 2009
SOURCE: I need to replace the battery on a Genie GICT-390
If its a lighter grey colored intellicode remote: There should be a small slot on the side of the remote. Use a coin such as a dime or a penny, stick it in the slot and twist. The remote should split in half and you'll see the coin-shaped battery. After you replace the battery, you can snap the 2 pieces of the remote back together.
If its a dark grey/black intellicode remote: The back cover should partially flip open to reveal the battery. This remote takes a 12volt N-size battery.
If its a keypad remote you are referring to: The bottom half of the keypad's face should slide straight down to reveal the battery (you should see and arrow and some thumb grips). All Genie keypads take 9volt batteries. Source(s): I am a genie technician
Posted on Nov 20, 2009
SOURCE: how do you replace the battery in the genie garage
Never could get mine to work...turns out this model only works with Genie garage door openers manufactured in certain years, and mine wasn't one of those years. Bought a GIT model from a Genie garage door installer, and no more problems!
blanchettohd
  • 143 Answers
SOURCE: Genie Compact 3-Button Remote control will only open 1 door/not 2
On some of the remotes you will find a toggle switch to change frequencies, this might help. Note all new openers are operating on a different frequency than slightly older ones due to military interference. Even though both might be intellicode they might not work together on the same remote. Sometimes some openers are harder to program than others. So lets try to program the harder one. You need to find and press the learn button on the motor head. Then press the button on the remote once. The led light by the learn button should not flash. If so try it over. The light should either stay lit or go out after the first press. If it does press it again and then a third time. If it ever flashes during the program process try again. The third or fourth time the motor should operate. If not you either have a bad remote or more than likely a bed logic board. Thanks BB
Posted on Jun 06, 2010
blanchettohd
  • 143 Answers
SOURCE: Have a 3 Genie remote and the center button works
The other opener has to be a genie, compatible genie to be exact. An older one will not work with new devices. If it will not program it will be the openers fault not the remote. Thanks BB
Posted on Sep 05, 2010
If my battery went dead on my remote for my gagage door opener do I have to reprogram remote when I put in new battery?
WIth car remotes they do not need re-coding if the battery is replaced within a few minutes of the old one being taken out.
source: car remote battery sales assistant.
Dec 24, 2014 | Genie gict390-1bl new g3t-bx garage door...
I have a Master Mechanic Garage Door opener that I am trying to use a Genie Master Remote to operate. What steps do I need to take to operate the door with the Genie Remote?
You have to pair the remote with the opener, which will require the opener manual because you have to put the opener in programming mode.
Dec 06, 2014 | Building Materials
Can I use a chamberlain remote with a genie pro garage opener
you can try to see if it works but probably no- get anather genie remote
Oct 02, 2014 | Chamberlain 953cd multi-function 3-button...
Genie garage door keychain remote not working
Check the remote control for its infrared emission. Check it with fresh batteries. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Oct 11, 2013 | Genie G3T-BX Keychain Intellicode Garage...
Garage door opener Chamberlain - programming problems
I bought a new keypad and 2 VISOR remote (30498). As to programming garage door opener, I did like here:
- it tooks me 20 minutes and works great
Feb 07, 2013 | Sears Craftsman LiftMaster Chamberlain...
G3T-BX
check manual for erasing codes and reprgraming remotes should be something about a learn button
Oct 21, 2012 | Genie G3T-BX Keychain Intellicode Garage...
Genie g3t-r remote seems like it 's programmed but doesn't open door. led's suggest it was programmed.
1) test the batteries 2) rETIGHT THE spring contact batteries 3) Resolder wires for contact batteries, see if there are some wires missing. 4) Try again with the codes.
go www. fitness.manualsonline.com get the code , and reset again.
Otherwise the remote control you must go to the repair shop.
God bless you
May 09, 2012 | Genie Company IntelliCode GICT390-1BL...
I have a genie pro max PMX 300 IC/A garage door opener and bought a Genie 3-button remote (model G3T-R) and I can't get it programmed. I push the button on the back of the opener, push the button
Take the opener apart and see if there are about 4 numbers that can be set. If you have an older remote take it apart and match the numbers, then program it.
Feb 07, 2012 | Home Security
How do you replace the battery in the genie garage door remote, its the small one
Oct 28, 2009 | Genie Company IntelliCode GICT390-1BL...
Televison & Video Logo
178 people viewed this question
Top Genie Company Televison & Video Experts
Dan Apthorp
Leonard Manamela
Leonard Manamela
Are you a Genie Company Televison and Video Expert? Answer questions, earn points and help others
