Question about Philips 50PFP5332D 50 in. Plasma Television
Philips model 50PFP5332D/37 will not power on blue light stays on
The television will not power on or off. Makes a clicking sound and three different panels have green lights flashing inside, but picture doesn't come on and can't turn it on or off
  • James A Lyell Dec 08, 2012
    I've removed the back and have ordered a key controller. It is the volume and on/off switch, I think this may be the problem, will let ya all know when the part comes in. That part # is ME7EBJ2K7 and pulls up replacement part 313926804971.If it works I'll make a post in case anyone else runs into this.
    Top Expert:
  • Philips Master
  • 14,553 Answers
The real clue here is the unit will not turn off, this indicates the microprocessor in the set is locked up--may have got "confused".
The first and simple thing to do is disconnect power from the set AND A CABLE OR SAT BOX IF USED.
Leave with no power for several minutes and then power both set and the box if used back up--both the box and set will try to reboot.
I suggest this as have seen several boxes that cause a lockup of the set---fairly simple to do will not hurt.
Failing with that next would be looking at the set and its power supply---that would require taking the set apart and this one may have up to 50 screws to remove just to do that---a lot of these use those nasty torc screws.
Try the Unplug power on set, box, and receiver if used first.
Posted on Dec 05, 2012
SOURCE: Hi, I have a Philips model 37PF7321d/37, 37 inch
The power board numbers you need to search for on eBay is 310432847531 or 310432838621 - they are compatible according to Philips.
Posted on Nov 05, 2009
freetek
  • 5568 Answers
SOURCE: Philips lcd tv 42pfl5432d/37 no picture
If you feel you have isolated the problem board, you might check here for a replacement:
Jimmy's Parts
Posted on Nov 22, 2009
SOURCE: philips 50pf9631d/37 no picture sound. Red light flashing
hey crs246, I have the same exact problem with my philips tv same model. Have you gotten any help that you can share with me. Any help would be appreciated.
Posted on Mar 06, 2010
  • 8457 Answers
SOURCE: my philips 42pfp5332d/37 when i turn it on the
Power supply board is dead.Replaced the power supply board,that the board where the power a/c cord go into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Posted on Jun 06, 2010
sabreusa
  • 271 Answers
SOURCE: My Philips flat screen tv
It could be a power supply problem. In this model at least 2 capacitors, go bad in the power supply I think they're 1000uf/10V. If you look at the power supply board you will notice a bad cap with a blister on the top. The whole power board is from $100 - $200. I fixed a lot of these sometime the Y or sustain board goes bad. Visual inspection then measuring voltages..
Best of luck
Nour Sabre
Posted on Nov 03, 2010
Philips 50pfp5332d/37 won't power on...led light blinks 4 slow, 6 fast...i can not find error code 46 anywhere
Error 46
Description Pacific 3
Detected by VIPER
Device T6TF4HFG
Error/ Prot E
These info are for qualified service technicians.
Sep 09, 2012 | Philips 50PFP5332D 50 in. Plasma...
Philips tv model number 50PFP5332D 37 wont power up
I have the model Philips 37PF7320A/37 won't turn on and MOST articles on the Internet say it's the Capacitors capictors capictors..I checked all of them. My tv just blinked red lights, had the clicking sound at first power on, but then goes black. No sound. No picture. Nothing. Just blinking red lights.
MINE WAS RESISTOR no. 3318 , a 100 OHM RESISTOR ON POWER SUPPLY BOARD.
I BOUGHT REPLACEMENT FOR .99 CENTS SOLDER IT, AND EVERYTHING WORKED!!!
THAT WAS ALL IT TOOK.
JUST A SUGGESTION..
1. CHECK FOR BULGING CAPACITORS (90 PERCENT OF THE PROBLEM)
2. THEN CHECK FOR RESISTORS WITH MULTIMETER ( FALLS INTO THE OTHER 10 PERCENT OF THE PROBLEM.)
TELL ME IF THAT HELPS..normanw1@yahoo.com
Oct 30, 2011 | Philips 50PFP5332D 50 in. Plasma...
My Philips 50PFP5332D 50 in makes this clicking sound when I try turning it on. The blue indicator light is on, but the tv won't turn on, it just continues to make this clicking sound for one hour or...
its the capacitor inside the tv open it up and you should see atleast 1 capacitor which has bulged ( looks like glue coming out of it ) usually a 3000 ~ you can replace these yourself no problem for around 10p each but i do warn you there is a chance you could lose your built in freeview in doing so!
Oct 29, 2011 | Philips 50PFP5332D 50 in. Plasma...
I replaced three cans. they were bulged on the top. i plugged the tv in and it did the same thing. i said it blinks 4 times fast but it is only three. blink code says 3=RESERVED. i pulled the the y-sustain...
Philips lists 3 models of your TV:
1) 50PFP5332D/37
2) 50PFP5332D/37B
3) 50PFP5332D/37E
User Manual for your TV (actually for the 50PFP5332D/37E):
http://download.p4c.philips.com/files/5/50pfp5332d_37e/50pfp5332d_37e_dfu_aen.pdf
The user manual doesn't document the logic board blink codes for errors.
What this tells me is that the TV went thru two revisions before reaching version E.
in case it helps: Philips Customer Support: 1-888-PHILIPS.
If they can't help otherwise, they can at least tell you if your set is eligible for warranty service.
Mar 24, 2011 | Philips 50PFP5332D 50 in. Plasma...
I HAVE A 50' PHILIPS MODEL 50PFP5332D/37 FLAT SCREEN TV. I BLEW A BREAKER ON THE TV PLUG IN WITH A PORTABLE HEATER. TURNED BREAKER ON TV CAME ON WORKED FINE. TURNED OFF. 1HR. LATER A RED BLINKING LIGHT WAS...
HI:
This is a plasma unit and philips plasma's are nortorious for bad power supplys, your problem may very well be the power suppy in the television, it is possible you blew a low B+ fuse on the power supply. There is also a issue with the Y-sustain board failing in this model, If you open the back and looking at the unit from the rear the y board is on the left side of the unit and the PS is in the center. disconnect the Y-sustain power plug from the power supply and turn on the unit if the unit stays on with no red light then the y board is bad. it does the same then replace the Power Supply.
Mar 10, 2011 | Philips 50PFP5332D 50 in. Plasma...
I have a philips model 50pfp5332d 37 We turned it on and it just clicks (like it is turning off an on) no picture, nothing. Will not respond to the remote or to the on off switch. Had to unplug to stop...
The tv power supply board is the causes and the problems.That the board,where the power a/c cord plug into it.Try website like Ebay.com to buy a whole refurbish power supply board for the replacement.
Nov 28, 2010 | Philips 50PFP5332D 50 in. Plasma...
My Philips flat screen tv model 50pfp5332d/37 I turned my tv on the blue light is on but nothing is on the screen it's making a clicking sound
Best of luck
Nour Sabre
Nov 03, 2010 | Philips 50PFP5332D 50 in. Plasma...
I have a phillips 50 inch plasma- model 50PFP5332D/37- when its plugged in it makes a clicking noise and the light is on indicating it is on, but picture never comes on- help
you have a problem on one of the boards in this unit you would have to start isolating the source to pit it down
its probably best you get some help form a servicer in your area this is a philips inside and made by samsung
Oct 23, 2009 | Philips 50PFP5332D 50 in. Plasma...
How many Main Boards are in the Philips 50'' Plasma TV model 50pfp5332D/37?
has only one main board
has many sub bords supporting tat main board
Mar 08, 2009 | Philips 50PFP5332D 50 in. Plasma...
Philip plasma tv
My parents have a Philips 50PFP5332D/37 the blue indicator light is on but there is no picture or sound. Is there anything I can do to help them fix it outside of calling a tech. I can get parts and fix tvs but unfortunately I am in another state 7 hours aways.
Oct 19, 2008 | Philips 50PFP5332D 50 in. Plasma...
Philips 50PFP5332D 50 in. Plasma Television Logo
108 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
