Question about Maytag Washing Machines
My maytag washer leaks when it is washing
It only leaks when it is washing
  • karen thomas Dec 05, 2012
    if your machine leaks while washing only try to turn the agitator clockwise as tight as you can and try washing again. That should stop the leak.
    Top Expert:
  • Maytag Master
  • 9,472 Answers
What is the complete model number of the unit?
Posted on Dec 05, 2012
  • 96 Answers
SOURCE: washer leaking water on floor
Need to check drain pump and its hose connections. If its not from the drum seal then that's usually where the leaks occur.
Posted on Mar 31, 2008
SOURCE: Repairing leaking Maytag washing machine
Maytag Appliances are ****!! Don't buy Maytag. Spent $2500.00 in 2005 on Maytag Neptune washer and dryer. They have been nothing but trouble. Washer has water running in tub constantly. Recall on ground and recall on footing. Dryer making loud noise when drying clothes.The Maytag man is dead and gone.
Posted on Oct 10, 2008
Maytag317
  • 1136 Answers
SOURCE: Top loading maytag washer leaking water during wash cycle
Hi, There are two spring clips located in the gap between the top and front panel. They are the edges.
If the pump and hoses aare ok, fill the washer with water and look up toward the center of the tub abd transmission area. It migth have a seal going bad.
I hope this helps.
Vic
Posted on May 30, 2009
localwonder
  • 6784 Answers
SOURCE: washing machine is leaking from bottom of machine
Wow, this washer is very old. im sure the drainage hoses will need to be inspected or replaced asap. i would also check the pump housing for cracks as well. make sure the water inlet valve assembly ins in good condition as well. Replace any hose or valve that is leaking or, damaged.
Posted on Jun 05, 2009
TheMobilian
  • 8220 Answers
SOURCE: Maytag Washer model LAT9606AAE, purchased 1999
PUMP
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Feb 27, 2010
Maytag heavy duty washing machine quiet series 100 leaks water from the top panel
Older maytags were equipped with an "air-gap" that can leak if the rubber sleeve part of it gets too stiff and cannot flex. It is along the left hand side of the machine fastened by a 5/16" screw between the machine cabinet and the upper panel... Maytag Injector Tube 12001677
If you remove the front panel and set the machine to fill, you should see water dripping off of the plastic frame the injector is sitting in.
If it is a newer maytag, check the fill spout for cracks or sediment build-up Maytag Water Supply Tube WP3360977
Jun 06, 2016 | Maytag Washing Machines
My Maytag MAV6000 washer leaks intermittently. In the past 3 weeks it has been used many times but has leaked 3 times. I removed the front panel to look at the pump and hoses and put the washer through a...
Realistically, a 10-year old Maytag is nearing the end of its usual life. The pump may be leaking at random times during a wash cycle. If you put 50% of the cost of a new one into repairs, it is time to thing seriously about replacement of the machine.
Apr 26, 2017 | Maytag Atlantis MAV6000 Top Load Washer
I have a leak under my maytag wadshing machine only when i do laundry what is the problem
the seal on the washer is leaking soon the bearings will start to make a lot of noise as the water leak will wash all the grease out of them
Aug 05, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag washer is leaking out of front door, its a front load washer
There are a couple of steps to be done to fix the issue. Please follow the steps provided in the bellow mentioned link:
http://www.ehow.com/how_2089565_fix-washing-machine-leaks.html
Thank You
Sep 12, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Leak from under the washer
tub seal has gone bad, will only get worse. Expensive fix,
Jul 02, 2009 | Maytag PAV2300 Top Load Washer
Washing machine is leaking from bottom of machine
Jun 05, 2009 | Maytag Washing Machines
Washer leaking water on floor
Mar 30, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
18 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
