Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
Nobody seems to be able to answer the question on how to change the belt on a bissell steam cleaner ..... Bissell is horrible for never giving customers proper instruction manuels .... THUMBS DOWN FOR BISSELL
I have the same prob. this is what i found
Since changing the belt is the easiest fix, we suggest you check that first. (Before attempting any repair be sure your machine is unplugged from the electrical outlet). Most Proheat models have two belts; a cogged belt that turns the brush roll, and a flat belt that turns the pump. If the pump belt is stretched or broken it needs to be replaced. The pump and belts are located in the front of the machine on the operator’s left. Turn the machine over and you’ll see a red retainer with 2 screws. Remove the retainer to gain access to the pump and belts. While you’re there check the red pump pulley, it’s where the two belts are. If that pulley is broken or loose you’ll have to replace the whole pump, the pulley is not available separate.
on your housing you will see a plastic cover adout 4 inches long remove this piece and you should see where your pump belt goes. flip your steamer over and remove the little red retainer that sits by the belt you have located. at this point you can take your brushroll out and slip the pump belt over the pump and onto your motor. then reassemble.
Posted on Jan 18, 2009
The belt cover is located on the left side just forward of the rear wheel. You must look closely or you will miss it.   It requires a flat tip screw driver to pop it open on each end.  The belt is inside, note the belt is thin and small diameter, do not confuse this small belt with a heavier duty vacuum cleaner belt, the vacuum cleaner belt will out the motor faster.
Posted on Mar 15, 2009
How do I change the belt on the Bissell Proheat Turbo?
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
fhjfh
Sep 14, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
How do I change the belt on my Bissell Pro Heat
heatman101
twerw
Apr 16, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
How do i change the belt on a bissell 8910-1 steam cleaner
Hello There,
Here's a helpful video that really helped me out the first time that I changed a belt on the Bissell Carpet Cleaner. I hope this helps you as much as it helped me.
Feel free to ask any follow up questions by adding a comment to the repair page, I'm always happy to answer any questions that you might have.
Here's the video:
http://www.bissell.com/VideoRating.aspx?id=1555
If the video helped you, please be so kind and rate the repair helpful by clicking the 4 thumbs up icons in the top right hand corner of the repair. Thanks so much!
Chris J.
GoVacuum.com
Apr 06, 2010 | Bissell 8930M Upright Steam Cleaner
I need a manual on bissell pro-heat steam cleaner. I have forgotten how to change the belts.
heatman101
Jan 30, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissel pro heat cleaner won't expell water -- seems no suction
The reason that it won't expel water is because your pump belt is stretched and worn. You need to replace that belt, it is pretty easy. Here is the belt you need:
Bissell ProHeat Pump Belt
Jan 30, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
My bissell steam cleaner clear views keeps
heatman101
ghhg
Nov 08, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell ProHeat Steam Cleaner
heatman101
ahdg
Aug 24, 2008 | Bissell ProHeat Turbo Deep Cleaner Upright...
BISSELL STEAM CLEANER
heatman101
jm,b
Jul 26, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
197 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
