Question about Yamaha PSR-S500 Digital Keyboard
MY YAMAHA PSRS-550B, TWO KEYS PLAYING WRONG TUNES
    New Friend:
Guys i am using psr s 550b for 2years,,.and the problem was i stopped useing it for 2 months ....and when i started using it again my keys r not working only the styles r playing ....and i thought to do format since the keys r not working i am enable to format it ple tell me any solutions for it .ple.pleeeeeeeee
Posted on Jul 14, 2013
My yamaha psr 220 has suddenly begun playing a semi tone higher than concert pitch
any menu function that allows you to select it
all the keys out that much ?
possible diode failure ..repair shop to test
Nov 11, 2016 | Yamaha Music
My Yamaha psr e303 all keys from bass side stop playing what can I do?
You might have the accomp switch turned on?
If not try holding down the highest key whilst turning the keyboard on, this will start a factory reset.
Sep 18, 2016 | Yamaha Music
My Yamaha PSR S500 keys are playing wrong notes
Is there a pattern to the wrong notes ( eg all up a semitone ? )
If so you could have altered the tuning.
Try a master reset:
Hold down top key whilst turning on. This will reset to factory setup.
See attached for individual reset procedures:
Dec 05, 2015 | Yamaha Music
How do I repair 4 stuck keys on a Behringer Concert Keyboard CDP2000?
Counter weights are not rotating on the one octave pin that holds them in place. This is caused by the grease changing over the years. Two options: remove the pin and ream out the nylon hole with a drill bit. Not too big of a hole, because you don't want the weight clunking around while playing. Caution: they will all start drooping, so do them all. Better option: since this keybed was copied from Suzuki, look into having the entire rod set replaced with a Suzuki ACE rod kit. The new rod is Teflon coated and won't give you any problems after it has been replaced.
May 06, 2014 | Yamaha Music
My psrs 700 the back light its off i need to know ?where may i buy it !!!
Well first start by calling or emailing the manufacturer. They'll let you know who distributes their parts or If it's still available or not. But also could be a power supply problem.
Oct 01, 2011 | Yamaha PSR-S700 ARRANGER WORKSTATION...
Yamaha YPT-410 When playing the keyboard, the sound cuts out when playing multiple keys, and then begins again only to cut out again. Does not matter which keys. I have done a factory reset and it did not...
It's probably your keyboard. Some keyboards are limited with it's polyponic capabilities. Some can play many notes at one time, some cut out when it reaches it's limits. Check your manual for specifications.
Aug 25, 2011 | Yamaha Corporation Of America 61 Key...
I'm using the Yamaha P-85 Digital piano. Unfortunately it has lately had some problems. When I'm playing to notes next to each other (especially e and f (mi & fa) or b flat and b (si & si...
In playing fast you have to make sure to release the note fully and let the key come up. These keys have TWO contacts that are used in the scheme to measure note velocity. If BOTH contacts don't open, the note will NOT re-fire. The second symptom you have written would be a characteristic if one of the disconnect diodes has shorted. These diodes direct the strobe signals that scan the matrix of key contacts to avoid other octaves responding when multiple keys are depressed including those in other octaves. Servicing of the unit is required. It is unlikely you have the tools to DIY this problem. ONE THING to try is to tip the unit and gently tap it to see if some debris MIGHT have fallen in that may be shorting some of the matrix connections.
Apr 25, 2011 | Yamaha P85 88Key Portable Digital Piano
Yamaha keyboard not working
We have a Yamaha keyboard YPT-330 note E and F sharp not working why?
Feb 25, 2010 | Yamaha Music
Yamaha 88 key piano grand plays wrong pitches w/ changing volume
If it has a sequencer/ recorder built in, you have the ability to change the pitch/ detune by using some key strokes after initiating the program mode. If your not sure how to do that, try unplugging the keyboard for thirty seconds and push the power button while it's unplugged, then plug it back in. Any better? What model is it.
Jan 01, 2018 | Yamaha Full-Size Keyboard
Yamaha PSR-S500 Digital Keyboard Logo
134 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
