Question about NVIDIA Quadro NVS 120M
Monitor does not display
I have 4 monitors connected to this video card and one of the monitors will display for 30 minutes and stop. No errors. No display. Blank Screen
    Guru:
  • 571 Answers
Try resetting the connection. Or make sure that the cable is properly plugged in.
Posted on Dec 06, 2012
I have a E152FP monitor will this work with a graphics card that has a DMS-59 connection
The monitor will work with that video card but the resolution needs to be set to 1024 X 768 or less. Your video card is trying to display the picture at a resolution that the monitor can not handle correctly so you get the video mode error. You will need to use the windows video settings screen to change the settings for that display than you will be good to go.
Sep 27, 2012 | Dell E152FP 15" Flat Panel LCD Monitor
How do I fix a flashing monitor?
Your monitor is bad and needs to be replaced. Try connecting another monitor to the computer just to verify that it is the monitor and not the video card inside the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays without flashing, then your video card is good but your original monitor is bad. If the Borrowed monitor flashes the same way as your original monitor then your video card inside the computer is bad.
Jun 05, 2012 | Computers & Internet
I put the card on my PC and connect de monitor to the card (VGA). when system boot, the speaker of the board sounds beep, like everything is good, but no video. And yet the card plugging in the board, but...
Hello friend,
Please i think you card is not acceptable by the system, or have you checked another card on the system to see if it displays the same thing. And when you remove the card the system boots normal without any error. So check on the card make a change on it.
Jul 04, 2011 | Creative Labs 3D Blaster 4 Titanium 4200...
Upgraded power supply, upgraded to AMD 965 Quad core, Mother board stops at error C5, monitor blank during this. C5 error says reset video controller. HOW?
try this: 1. turn off the computer 2. disconnect the VGA connector (the cable from the monitor) 3. remove the video card from the motherboard 4. the motherboard has the on board video controller, connect your VGA monitor to that slot. 5. turn on the computer, I hope by now your monitor is ok ;-)
Feb 03, 2011 | Jetway Computers & Internet
I have the VE278Q which is connected by display port, every time i turn off my computer and then turn it back on the monitor can't be found, I have to unplug the display port cable, unplug the monitor,...
when you say monitor can't be found did you mean the monitor has no reactions when you turn on your pc?
here are some test you may need to do to know which part is faulty
1. Turn on your computer, did it display the monitor's logo on screen? When it does monitor is good, when only blank screen it could be the vga cable or the video card.
2. See if the led indication lit. When it lit to steady green, it's good signal is coming in from the video card. It should be followed by screen display. If no display it could be the backlight inverter lamp busted or faulty inverter board. When lit green then turns red, no signal coming from the video card. Check vga cable if fix properly to both monitor and video card. Or may need to reseat properly connection of video card from the motherboard. If no led indication lamp, then monitor is dead. Check ac power cord for continuity using multitester. Check power supply section in the monitor, replaced bulged or blown capacitor with exact value, this components were the first to get affected when lcd monitor failed o turn on.
3. When computer was turned on got display and then monitor turns black, go check the vga cable, Fix the connection properly or may need to replace it with new one.
4. When no signal appears or display blank screen after logo, then check video card. First remedy is to disconnect it the reseat properly to the motherboard. If this have no effect change your video card.
go follow these steps and let me know which is closely to your problem so I can give you a good advise.
Jan 30, 2011 | ASUS LCD Monitor
Monitor going berserk
This could be due to corrupt display drivers on the notebook or the video card is going to die. Try updating the graphics drivers on the notebook and check for the issue.
If the issue still persists, then to isolate the exact cause of the issue, I recommend you to connect an external monitor to the notebook and check for the issue on it. If external monitor works fine, then the issue with LCD display screen of the notebook. In case, if the issue persists on external monitor then it states that the video card of the notebook is going to die.
To connect an external monitor to the PC, follow the steps listed below:
1. Turn off the notebook.
2. Connect the monitor cable from the external monitor to the monitor port on the rear/side of the computer.
3. Connect the monitor to a power source and turn it on.
4. Press the Power button to turn on the computer.
At this time, please follow the instructions mentioned below for switching the display to the external monitor:
The notebook's video card supports three modes. Built-in screen only; external video only; and both on simultaneously (mirrored). If you're not seeing the image on the desired device(s), the notebook's video card is probably in another mode. Press FN + F4 to cycle through the display options: Notebook display, External monitor, both.
If you press FN + F4 once, the external monitor will display & there will be no Notebook LCD display.
If you press FN + F4 twice, the external monitor will display & there will be some shading on the Notebook LCD.
If you press FN + F4 thrice, both Notebook LCD & external monitor will display.
If the issue persists on the external monitor, then this could be due to defective video card on the notebook. However, if the display on the external monitor is fine, then the issue is with the LCD display panel of the notebook. In either cases, the notebook requires a detailed onsite diagnosis by a service technician.
May 28, 2010 | HP Pavilion dv6000z Notebook
Dell 410XPs + Dell 3007WFP monitor issues
Vinod,
That's quite strange as during system startup you should see the Dell POST logo as at that point the card is only running at VGA, and the monitor will support display at this resolution. If you connect with a normal single DVI cable the monitor should display at 1280x800 also.
Have you tried this? Also have you had this monitor working on another computer at all? What happens if you power up the 3007 with no video cable connected? It should cycle through the pixel test screens. If you are not getting that, and you are not getting the pre POST logo during powerup i suspect that it is a screen failure.
Aug 03, 2008 | Dell Dimension XPS PC Desktop
Monitor Image Partially Freeze and PC Stop working
Hey, sounds like your videocard is about to fail. the only option now is to replace the card with another.
The card is damaged. Possibly overheating have you cleaned your pc recently? Might be full of dust and burned.
Feb 13, 2008 | ATI RADEON® 9600 Pro, (256 MB) AGP Graphic...
Computers & Internet Logo
61 people viewed this question
Top Nvidia Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Are you a Nvidia Computer and Internet Expert? Answer questions, earn points and help others
