Question about Compaq Presario R3000 Notebook
When I turn my computer on it's blank - Compaq Presario R3000 Notebook
Monitor keeps showing "Check signal cable"
Well, at least you got it sorted out and everything is working fine now.
Apr 21, 2012 | Samsung SyncMaster 2493HM Monitor
Printer keeps printing blank pages non stop going
drop kick unit across room:)))) sorry just kidding I had the same problem with mine. If the computer is continually printing that means the printer is receiving print orders from your computer. Best thing is just disconnect the printer from the computer and turn the computer off and wait 30 seconds then turn on . This should clear the print cache then reconnect the printer. Make sure to only request one print at at a time.
if the printer continues to print blank pages check to see if you have the latest software driver for the printer installed on your computer. You can do this by going to the manufactures website and download the software its easy to do just follow the prompts and install! Hope this helpful!!!
Jul 24, 2010 | Epson Stylus C84 InkJet Printer
Scans are blank. Have reinstalled software, but images are blank.
Just want to check that you are putting the paper face down.
Then i'd unplug it, turn off your computer, turn on your computer and then plug in the scanner.
Let the computer find the hardware, and if it has its own drivers, let it use them, if not, supply the disc and let it install from there.
Sometimes there is a lock, you must make sure you are not locked. (this is to protect the scanner during shipping.)
May 03, 2010 | Epson Perfection 1670 Flatbed Scanner
Blank screen
I'm assuming that it turns on. Make sure that it's connected. Try connecting it to another computer. If it still doesn't work unplug it from the computer and turn it on. If it doesn't display a self test screen it may be broken.
Feb 02, 2010 | LG W2242T-BF Monitor
When i'm online, my computer screen flickers then goes blank with a white screen. The computer is still running the screen just goes blank. how can i solve this problem? and sometimes when i turn on the...
Your computer is infected with spywares.You need to scan your computer for spywares from a good antispywares software like Malware byte, SuperAntispyware etc.
Jul 11, 2009 | Acer Aspire 4520-5141 Notebook
Screen goes blank within 1 second of being turned on
Bad capcitor in the psu would cause this to squel and even pop so have it looked at you be glad you did.
May 23, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
White blank screen
<Fn> + <F6> Screen blank
Turns the display screen backlight off to
save power. Press any key to return.
Dec 30, 2008 | Acer Aspire 4315 Notebook
Computer boots fine but the monitor is blank
if the monitor works fine on your laptop, the problem definitely is at the computer, possibly with the video card (if it is using one). it could have loose connection, or parts might have damages. it seems the problem is intermittent so electronic component of the video card could have parts partially damages or leaky components.
if your still using the motherboards built in video out put, try installing a new video card.
Oct 31, 2008 | Computers & Internet
Monitor displays breifly then goes to blank screen
There is just no way you will be happy to hear it needs service or replacement under warranty.
Jul 03, 2008 | Relisys RLT1720 17" LCD Monitor
check your system unit to make sure the problem is not from the system unit
the signal stage and cable is more likely to have faults contact a local technician for confirmation
Nov 27, 2007 | Star Logic 17" LCD Monitor
Compaq Presario R3000 Notebook Logo
98 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
