Question about iLO 3200 32 in. LCD Television
Composite, no signal - iLO 3200 32 in. LCD Television
    Top Expert:
  • iLO Master
  • 14,553 Answers
What is or have you tried to connect to that input (I presume set only has one Composite?)
Posted on Dec 05, 2012
What is Bose 321 gsx video format?
The video formats are:
composite video (yellow phono/RCA) - 480i/576i [NTSC and PAL, respectively]
S-video video (black 4 pin din) - 480i/576i [NTSC and PAL, respectively]
Component (3x phono/RCA - Green Blue Red) - 480p NTSC only. Applies just to the DVD player output.
The 3-2-1 system has a couple of composite inputs, one s-video input, no (0) Component inputs. It has 1x composite output, 1x S-video output, 1x Component output.
The Bose system has very basic video handling capabilities. It will only pass through a signal in the same format as it is received. So, a composite signal in requires that the TV or display is hooked up with composite too. IOW, it won't up convert composite or S-video to component.
Sep 08, 2014 | Bose 321 GS series II
Tip
HOW TO CONNECT A DVD ON A STANDARD OR HDTV
TO START OFF WITH WE MUST UNDERSTAND SOME FUNDAMENTAL
BASICS .
1 We will examine together in a progressive way the different typs of cables available with a breaf description ,starting with the worst type of cable to the best
I would like to specify i will show 2 pictures 1 the connecter on a tv 2 the cable that goes with this connecter
No 1 Coaxial cable Coaxial cables have been around for a very long time until the end of the 70 s begine 80 s this was the only available cable .
Whats important to know about coaxiale cable is that audio and video signals pass all together this obligates a lot a filtration to seperate signals creating a lot of noise
No 2 composite or yellow , composite cable mainly appered in the beginning of the 80 s the main difference of composite compared to coaxial is that audio is seperated. The yellow cable is our video signal, composite (yellow ) must be matched with audio cables one red for right side one white for left side . advantages over coax better sound since audio is seperated from video , also better video because audio signals are absent from video signal so less filtration is necessary
10_31_2011_6_12_22_pm.jpgNo 3 S-video . S-video appeared at the end of the 80 s beginning 90 s . like composite video the audio signal is seperated it also has to be matched with a red and white cables for audio . whats the main difference between composite (yellow) and S-video ? well if we keep this simple lets say that a video signal is composed of many signals . Our composite cable passes all of them in the same time , but are s-video cable seperats colour signals cromonance signals and puts a seperate ground for each ,gives superier video signal and s-video can support higher resolution 480i 10_31_2011_6_34_01_pm.jpg.No 4 component . Component cables apeared mid 90 s. again like composite and s-video audio is seperated component cables must also be matched with red and white for audio .Component cables come in a paire of three one blue one green and one red , the main advantage of component is we are seperating the video signal even more with component we are seperating the three primary colours red blue and green ,also component cables have higher resolution than composite or s-video up to 1080
No 5 DVI (Digital Video Interface) appeared latte 90 s beginning 2000 . DVI was a majeur amilioration and like composite -s-vide and component, audio was seperated ,audio cables had to be matched . The main advantage of DVI is its multipine connecter that permitted us to seperate even more prescisly our video signal . Like composite DVI supports high resolution 1080
No 6 and the last HDMI (High Definition Media Interface ) the cream of all
there are many advantages with HDMI 1 1080 p resolution 2 no audio cables necessary 3 multi pine connecter 4 communication protocols ( the ability for devices like a tv and a dvd to comminicat together ,making things more user freindly 10_31_2011_7_05_52_pm.jpg
on Oct 31, 2011 | Televison & Video
How to connect hdmi to composite
Normally you cannot connect hdmi signal to a composite input as the signals are totally different. HDMI is a digital signal and composite is analog. You may have to buy an adapter like the one shown below but the video quality will suffer. HDMI is very high resolution image and composite video is very low quality in comparison.
https://www.youtube.com/watch?v=_YCfHZF77EA
Would be something like this from Amazon.
http://www.amazon.com/Etekcity%C2%AE-Composite-Video-Audio-Converter/dp/B008FO7PQA
Aug 13, 2014 | Sony BDP-S3200 blu-ray/DVD player with...
Missing red composite signal on panasonic pt-47wx52cf
Check your jacks and cables.
The RED jack is either (1) left or right channel AUDIO signal or (2) the RED color channel of an RGB (Red, Green, Blue) COMPONENT video signal.
Yellow is the COMPOSITE video signal.
Dec 31, 2012 | Panasonic PT-53TW54 53" Rear Projection...
Configuring a Sony STRDH510 - 3 HDMI & 1 composite input
Is the composite/analog signal going into the same input as one of the hdmi's? i.e. DVD,BD, etc.? If so, the receiver can only look at one of those signals at a time. To use two different signal types going into the same function, you will have to manually select where you want the receiver to look - either hdmi, analog, optical, etc. The receiver defaults to auto-selecting which signal to look at, and will always look for a hdmi signal if one is available.
Dec 26, 2012 | Sony STRDH510
ATI Radeon X1659 Pro - Which pins carry the composite video signal on the 7-pin S-Video output?
Looking at the female socket, there is a flat 'key' (slot) at the bottom of the socket, there are four pins directly above that.
The composite pins are the two middle pins of the four. Looking at the female socket, the left of those two pins (pin 7) is the composite video ground. And the right of those two pins (pin 6) is the composite video signal.
Aug 15, 2011 | ATI RADEON X1650 Graphic Card
Turn it on iget audio add video flashis for one second then iget kind of a white or gray screen?
The message you're seeing is part of your monitor's ROM programming. It is its response to an input signal that it doesn't recognize. If someone makes a composite to vga adapter cable, it's because they can sell it, not because it works. While both composite and vga are analog signals, they are not at all the same format. The signal gets to the monitor via the vga connector, but it's still a composite signal. Your monitor is all wtf about it. You can make HDMI to DVI cables, but that's because they carry the same digital signal. There is basically no way to connect a ps2 to a pc monitor that doesn't have composite or component input, unless you spend extra money. That can be on either a signal conversion box, which cost at least $50 and might not work so good, or a capture or tuner card for your pc that can capture the signal and relay it to the monitor as VGA or DVI signal. Either method basically converts the composite/component to vga or digital. There is such thing as a ps2 vga cable, but it doesn't work under the normal ps2 operating system, only under ps2 linux. It's hard to find, too. No point looking for one cause you'd only get to play homebrew games of which there aren't many.
http://www.seekic.com/
http://www.chinaicmart.com/
Jan 11, 2011 | Televison & Video
Im trying to connect my unit to my tv to record shows and i having trouble doing so please help i am hooking it up wrong
For OTA or CATV signals, you need to daisy chain the coax from the source (antenna for OTA) to the coax input on DVD recorder and then the coax out to the coax input of the TV. If you have a set-top cable box with an incoming CATV signal, it should be connected between the DVD recorder and the TV.
The unit can tune in and record 480i (SD) ATSC (OTA digital), NTSC (OTA analog), analog CATV and digital CATV channels.
A satellite receiver or a non-CATV cable box should get the incoming signal first and then have their composite video output (A/V) connected to the DVD recorder composite video input and then their coax (RF) output (if present) gets connected to the TV. For these, you would record from the IN1 or IN2 (press Select Input) instead of selecting a channel. Then connect the composite video out on the recorder to the TV's composite video in.
Digital signals are either enough to tune in or give no signal. So check that your antenna is correctly oriented for OTA.
Separately, you can connect the video signal when playing DVDs via composite (good signal) out and component out (better signal) out to the TV's matching input. For the component video, the sound is carried on a separate cable. Then set the TV to the input source.
In the case of wanting to watch a VHS tape while taping to a DVD, do not use the Component video source, set the TV to Input 1 (composite).
I hope this helps.
(you can get a copy of the manual here: http://tv.manualsonline.com/manuals/mfg/panasonic/dmrez47v_dmrez475v.html )
Nov 25, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
No display from composite video input
Composite video are yellow RCA jacks and are made for analog signals of standard definition video. If you are connecting a digital source or a high definition output, it may be beyond the capabilities of the projector. You may be able to find a VGA to composite adapter if you laptop or whatever has a VGA output port. VGA is along the same lines of composite (analog, standard definition).
Mar 24, 2017 | Hitachi CP-X325W LCD Projector
Cable box pass through
ur trying to downgrade the signal when ur running composite cords u need to either run the composite out or an hdmi out to upconvert the signal the svideo cant handle the composite
Dec 18, 2007 | Onkyo TX-SR605 Receiver
iLO 3200 32 in. LCD Television Logo
16 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Radames Pagan
Radames Pagan
Jaime Hernandez
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
