Question about Texas Instruments TI-84 Plus Calculator
Sin 43 degrees 30'
I'm trying to find the exact value for sin of 43 degrees 30 minutes using the TI however, I don't know how to punch it into the calculator
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
Press SIN 4 3 2ND [ANGLE] 1 3 0 2ND [ANGLE] 2 ENTER
2ND [ANGLE] 1 gives you the degrees symbol, 2ND [ANGLE] 2 gives you the minutes symbol. If you need seconds, use ALPHA ["] (on the + key).
Note that this usually won't give you an EXACT value, but only a ten-digit approximation.
Posted on Dec 05, 2012
  • 7993 Answers
SOURCE: How do I calculate the ArcCos of say -.25?
There is nothing wrong. Your angle unit is set to radians and the calculator gave you the correct angle the cosine of which is -0.25: the answer is in the same unit as the one your calculator is configured for.
Press [MODE]. Use arrow to scroll to 3rd line, highlight Degree and press [ENTER]. Press [2nd][QUIT] to return to main calculator screen.
As long as the angle unit is set to degree, the angles calculated by the inverse trigonometric function will be in degrees.
Hope it helps.
Posted on Nov 14, 2009
  • 7993 Answers
SOURCE: How to use antilog?
As you well know the pH is the negative of the log in base 10 of the H+/H3O+ ion concentration. If we use [H+] to represent that concentration, then pH=-log[H+].
To obtain the [H+] you need to calculate the antilog. You write the definition in the form log[H+] =-pH and then calculate 10 to the power of each member. The equality remains valid as both members are treated similarly. Thus
10^( log[H+] ) = 10^(-pH)
Since raising 10 to a power is the inverse function of taking the log in base 10, 10^(log(x))=log(10^(x)) = x (they are inverse of one another), you are left with
[H+]=10^(-pH)
Your calculator has a function [10 to x] accessed by pressing the [2nd] function key. To use it you must enter the negative value of the pH, press the [2nd] function key then the [10 to x], then the = key to get the result (concentration)
Exemple: let the pH=5.5, what is the H+ concentration?
With [(-)] being the change sign key, then
[H+]:[ (-) ] 5.5 [2nd][10 to x] [=]
The result is 0.000003162 or 3.16 x 10^(-6)
Hope it helps.
Posted on Dec 10, 2009
  • 7993 Answers
SOURCE: TI-84 Incorrect sin/cos/tan values
What is so surprising? The sine and cosine functions have ranges that span the closed interval [-1,1]. As to the tangent function, its range is the the whole real line.
This being said, you should keep in mind that there are three angle units: the degree, the radian, and the grad.
When you want to calculate the sine, cosine, or tangent of a number, that number is not just a number. It is an angle, and as an angle it has a unit.
For this reason a calculator generally has two angle units defined (degree and radian), and possibly the grad. BEFORE calculating any trigonometric function you must ascertain that the angle is in the correct unit.
Clearly, in the problem you are trying to solve angle values are given in degrees, but your calculator is configured to interpret angles values in radians.
To set the default angle unit to degree press [MODE] , then press down arrow twice to reach the line (radian, degree). Highlight the word degree and press [ENTER] to set the default angle unit to degree.
Unfortunately the TI 8xPLUS family of calculators does not have a status bar on screen to remind you of the modes, and if you do not remember to check the current unit you get errors (at least unexpected results).
However, there is a way to avoid the errors and that is to enter the unit explicitly after the angle value. To do that you press [2nd][APPS] to open the (ANGLE) menu list. Try it.
  1. First item in list is the degree symbol, a raised 0
  2. 2nd is the minute, an apostrophe
  3. 3rd is radian, a raised r
By selecting the degree symbol and pressing [ENTER}, that symbol echoes on the screen just after the angle value. Closing the right parenthesis of the trigonometric function and pressing [ENTER] will give you the result in the correct unit of your choice. This can be done regardless of the default unit the calculator is configured for.
Posted on Jan 21, 2010
  • 7993 Answers
SOURCE: How to plot a graph on TI-83 plus texas calculator?
Prepare calculator to graph
Turn StatPlotsOff to avoid errors:
Press [2nd][STATPLOT][4:PlotsOff][ENTER].
Setup Graph type
  • Press [MODE] key.
  • In Mode set up screen, make sure that the angle unit is the degree.
  • Use the arrows to move cursor to 3rd line to highlight {degree} and press [ENTER]
  • On same screen, verify that Func is highlighted.
  • If it is not, use arrow to highlight Func and press [ENTER] to validate.
  • Do not worry if you do not have exactly the same screen as in the screen picture (We may have different OS Versions)
Entering the functions to draw.
  • Press [Y=] to enter function editor.
  • Type in a function
  • Press [ENTER] at the end of each function.
  • Before pressing [GRAPH], make sure that all the = signs that define the functions to be graphed are highlighted white on black. If one is not highlighted, use arrow to move cursor on the sign and press [ENTER].
  • In the screen capture 4 functions are slated to be drawn.
Selecting the Graph Style (You may ignore this now, because it is unimportant for just one graph)
  • Select the graph style: The small piece of line to the left of a Y that defines a function is the style.
  • Move cursor on it and press [ENTER] .
  • Each [ENTER] (on same line) selects another style.
  • On the next screen you have all the styles available on the calculator.
  • Do not select the bubble on line 6: It is for animations. It will not leave a trace at the end of the plot.
Drawing the Graphs
  • Press [GRAPH] to see the graphs.
  • If one of them is missing, verify that its = is still highlighted, then use the [WINDOW] to set the Window dimensions,
  • Here are the dimensions of the standard window
ZOOMING
You can also press [ZOOM] to adjust.
The selection 6:ZStandard sets the dimensions as on the screen Titled Window (above).
In the window screen you can set Xmin=-180, Xmax=180, Xscl=10, Ymin= -0.6, Ymax= 1.5, Yscl=1. The minus here is the change sign (-) to the right of the [.] dot.
Posted on Mar 14, 2010
Testimonial: "Thank you so much for your kindness in helping me. "
  • 102366 Answers
SOURCE: My new calculator is giving incorrect answers to
Your calculator is set to radians, which is the norm for higher mathematics. To set it to degrees, press MODE to bring up the mode editor, press down-arrow twice to get the the angular mode, press right-arrow to highlight "DEGREE," and press ENTER. Press 2ND [QUIT] to exit the mode editor.
Posted on Sep 15, 2010
Hello i for some reason my ti-nspire won't update automatically and also when i use tan, sin, and cos i don't get the right values, i tried changing the settings (angle) to degrees to fix this...
It is very likely that when you change the angle unit, you are not saving the changes made.
After you finish changing settings, use the TAB key repeatedly to move cursor towards the OK button at the bottom. If you do not confirm changes by clicking OK, they will be lost.
You can also make the changes the default ones by clicking the Make Default option.
Jul 15, 2011 | Texas Instruments TI-Nspire Graphic...
When I try to solve a sine, cosine, or tangent problem, it comes out differently than the real answer. Other keys work fine though... ex: sin(37) Real: .6018 Mine:-.6435 How do I fix this?
When you use trigonometric functions you should always make certain that the angle unit the calculator is configured for is the intended one.
When the unit is set to degree sin(37)=0.6018
When the angle unit is set to radian, sin(37 rad)=-0.6435
Change the angle unit to degree.
  1. Press the MODE button
  2. Scroll to reach the Angle line.
  3. Use right arrow to highlight deg and press ENTER to validate.
Jun 09, 2011 | Texas Instruments TI-83 Plus Calculator
How do I use the arcsine function to transform compass degrees
Cristina,
You might be referring to something else, so let me try to knock out two birds with one stone.
The arcsine function is the inverse sine function. It will take a ratio input and produce a degree/radian output. It isn't exactly transforming anything into degrees. Instead, it is telling you the corresponding angle that goes with the ratio of opposite over hypotenuse (your input).
With that said, I am going to try to answer your question with two possible solutions.
1. To find the arcsine of a value/input (between -1 and 1) you simply have to press {[2ND]} {[SIN]} {["NUMBER"]}. For example, if I wanted the arcsine of one-half I would press {[2ND]} {[SIN]} {[.]} {[5]} {[=]}. The computer would display 30 (degrees) because the sine of thirty degrees is one-half, therefore the arcsine of one-half is 30 degrees. Inverse functions in math are often written with a faux-exponent of negative one. Inverse sine (ie arcsine) should be written in blue above the sine button on your calculator.
2. To convert a compass reading into a concrete degree measure you will NOT use arcsine. Instead, you can use the Degree-Minute-Second key which is on the TI-30X. The degree portion is naturally symbolized by the superscript o; the minute is symbolized by the single apostrophe mark, the second symbol is the quotation mark. So, to convert a compass reading of 10 degrees-30 minutes - 30 seconds you would type {[10]} {[o ' "]} {[=]} {[30]} {[o ' "]} {[ -> ]} {[=]} {[30]} {[o ' "]} {[->]} {[->]} {[=]} {[=]}. The calculator should display 10.50833333, which represents the hardcore angle measure that corresponds with 10-degrees-30minutes-30seconds. Also, it should be known that this is a much better thing to do by hand because it will deeply ingrain the basic mathematics going on. Even though we're talking about degree measures, the minutes & seconds are still at a 60 unit benchmark: meaning that there are 60 minutes in a degree and 60 seconds in a minute. Therefore, 30 minutes & 30 seconds is 30.5 seconds, which is 50.83333 percent of 1 degree. Thus, 10.5083333 degreeees. Also, you can think of it as 3600 seconds in a degree, therefore you had 1830 seconds which equated to 50.83333% of 1 degree. Thus, 10.50833333 degrees total.
Alright...I hope that helps you with either question you might have been referring to. Also, I hope you enjoyed the minor math lesson involved here. Maybe you already knew it. If that was the case then I am sorry. Either way, I own a TI-30XB Solar (among many other TI Calculators) and I highly doubt that the buttons on my calculator are starkly different from yours.
If you have more calculator or even math questions just post them on here and I'll hack away.
Arrivederci.
The Math Cheetah
www.THEMATHCHEETAH.com
Feb 27, 2011 | Texas Instruments TI-30XA Calculator
I have a IITI-30XIIS and I am trying to calculate the angle of impact of blood spatter for a science fair project. The formula is sin to the -1st power (width/length). I can't figure out how to put...
To set the calculator to degrees, press DRG and select DEG.
To calculate the arcsin, press 2nd SIN followed by the value of the sine. For example, if the width is 3 and the length is 5, press 2nd SIN 3 / 5 ) ENTER.
Jan 12, 2011 | Texas Instruments TI-86 Calculator
How do you use the sin-1
You would press on the SIN key, "sin(" should come on the display, then enter the value, for example 3.5 or -1 so that the display shows
sin(3,5) or sin(-1) for example.
remember to close the sin with the ) on the end.
sin(-1) = -0.841470985
Feb 16, 2010 | Texas Instruments TI-30XA Calculator
Jan 21, 2010 | Texas Instruments TI-84 Plus Silver...
How to use the SIN botton EX: 25 x SIN(65)
Before starting to enter the angle measure to calculate the value of a trigonometric function (sine, cosine, tangent) you must make sure that the current angle unit (degree, radian, grad) the calculator is configured to be using is the same that your problem requires. For instance, if you are solving a problem in which the angles are given in degrees you must verify that the calculator is configured to work in degrees.
When calculator is turned on, the angle unit is reset to degrees, but just to make sure it still is, look at the display: It should show the indicator DEG. If the display indicator is not DEG press the key [DRG] once or twice until you see the DEG on the screen.
The angle unit being taken care of, we turn to the actual calculation
Usually, to calculate the sine of an angle, you enter the angle value, press the [SIN] key and hit [=]. As you can see the sine function eats the number stored in its current register and calculates its sine.
To make sure that the calculator is taking the sine of 65 and not of 25*65, I would enter the calculation as follows
[65 [SIN] [*] 25 [=] : the result should be 22.65769468
or
25[*][ ( ] 65 [SIN] [ ) ] [=]
In the last key sequence, the use of parentheses forces the calculator to pause all previous calculations and wait for the closing right parenthesis. When the right parenthesis is entered, the calculator takes care of the contents of the parentheses first, then resumes the operations entered before the parentheses.
Importance of checking the angle unit before a calculation
Let us perform the calculation with angle unit
  1. in degrees : 25* sin(65) = 22.65769468
  2. in radians : 25 *sin(65) = 20.67071699
As you can see, the two values are not very far apart and since you are expecting a value that does not exceed 25 you might want to check your result.
Hope it helps.
Thank you for rating this solution
Dec 12, 2009 | Texas Instruments TI-30XA Calculator
Need to know how to obtain the cot,csc, and see in the degree mode and radian mode
There are no dedicated keys for these trigonometric functions, for the simple reason that they can be obtained from the tan, sin, and cos by a simple division.
cotangent (x) =1/tan(x) . Do not confuse with the arc tangent tan^(-1)
cosecant (x) = 1/sin(x) . Do not confuse with the arcsine sin^(-1)
secant(x) =1/cos(x) Do not confuse with the arccosine cos^(-10)
If you know how to use the tan, cos, and sin, with angle unit in degrees or radians, then there will not be any problem
If angle unit is degree, any number you give a trigonometric function is interpreted as degree. For instance if mode is in degree , and you calculate cos(PI) do not expect the value -1. You will have the value corresponding to the cosine of of 3.14159 degrees, namely 0.99849715
Now for you if you are interested.
If [MODE] is in degrees you can still enter angles in radians
You use the [2nd][ANGLE] [3: raised r] [ENTeR].
Here is a screen capture to show you more clearly.
The raised r is obtained by [2nd][ANGLE][3: raised r] [ENTER]
Hope it helps.
Oct 13, 2009 | Texas Instruments TI-83 Plus Calculator
Wrong trig ratio
Your calculator is set in radians. Press mode key. Arrow down to 3rd line. Highlight degree and press enter. Your calculator is now in degrees, not radians. To get out of the mode screen and back to home screen, press 2nd and then mode.
Aug 05, 2009 | Texas Instruments TI-84 Plus Calculator
Using Cos/Sin
Calculator turns on in "degree" mode. Just enter angle in degrees then press "SIN", "COS" "TAN".
Most people work in degrees but you can switch to Rads or Grads to Degrees modes by pressing "DRG" repeatedly with zero displayed, Current angular mode will show in display.
Get a new instruction booklet by download from TI website
Oct 24, 2008 | Texas Instruments TI-30XA Calculator
Texas Instruments TI-84 Plus Calculator Logo
228 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
