How to change a techwood DVR 100A 500WATT Home Theater from analog to digital
    Sergeant:
  • 256 Answers
Get the manual for it,Try manuals online.com
Posted on Dec 06, 2012
5 Suggested Answers
SOURCE: techwood home theater remote code model #plr85
try 212, i have the same exact thing. I used the auto search remote codes method and it found and works on that code...
Posted on Jan 25, 2009
SOURCE: Phillips HTS3566D Home Theater/Comcast DVR 3 Device remote
I have the same problem. The only time that I can get it to work is whenever I turn on the cable box the home theater system turns on too. When I use the DVR it will turn it on too and want to play the CD/DVD. I have a Comcast Motorola DCH3416 DVR box.
Posted on Apr 16, 2009
  • 21 Answers
SOURCE: Can't get the Samsung HT-z310 Home Theater to stay on AUX2
you need a fibre optical cable for this, simply you connect that from your dvd to tv and then set the input on the dvd to digi in. i have exactly same home cinema system.
Posted on Sep 14, 2009
dunnbiker
  • 8546 Answers
SOURCE: HI Guys. I just upgraded to
You're correct and that is exactly how I always recommend setup (contrary to what the manuals tell you). It makes no sense to me to run any signal through any electronics or interconnections that neither use it nor improve it. Hence, I have NO SOURCE VIDEO going to or through my receiver and NO high end audio going to my TV (which could just as well be a monitor with NO audio capabilities, right)?
Audio electronics should receive the BEST digital audio directly from it's root source.
The TV should receive the BEST video directly from ITS root source.
THAT is why most all high end A/V gear has separate audio and video in/outputs.
If that means you have to make some switching choices when using different sources, oh well. At least you won't have experience potential degradation from multiple hops or have to troubleshoot problems that could be anywhere in that chain.
Posted on Jul 16, 2011
I want to upgrade to a 4k tv but my home theater does not support 4k. Can i run sound only thru it?
You can run the sound to the home theater system in many cases. It depends on the home theater system and the TV. If the home theater system has a digital audio input, it is easy to connect most 4K TVs. Connect the 4K source to the HDMI or Displayport connector on the TV. Check whether the digital audio uses an optical cable or a coaxial cable. Make sure that the TV has the matching output and get the correct cable. Set the TV to use external speakers (under the Audio part of the setup on most TVs) and turn off the internal speakers.
Very few 4K TVs have analog audio output. If your home theater system only has HDMI and analog (RCA red/white) audio inputs, you will need a digital to analog audio converter and both digital and analog audio cables. The converter will look like this: https://www.amazon.com/Gefen-Digital-Adapter-Converter-GTV-DIGAUD-2-AAUD/dp/B0013LWK3A .
I hope this helps. Please add a comment with the make and model of your home theater system if you need a more specific set of details about doing this.
Nov 20, 2016 | home Audio Players & Recorders
I dont have Aux in function in my philips home theatre model lx2600d Is there any way to create aux in to my philips home theatre?
Does your unit have any analog inputs? If you only have digital inputs, you can purchase a analog to digital adapter. For more information, please visit my website at audioserviceclinic.com. Thank you.
Nov 20, 2013 | Philips SoundBar DVD Home Theater with...
Techwood home theater pl 68
2005 2059 1061 1423 4367 4438. These are the codes to check with Techwood. If you wish to get more, check this link. Pull up previous posts,http://electrohelponline.blogspot.com/ either by its left side bar, or, view it in 'Timeslide' option. Setup code list and proceedings to many popular remote controls are given.
Jun 21, 2013 | Televison & Video
Can i connect dmp-bd871 to a home theater system
It will depend on your home theater system and TV. If your system accepts HDMI in from other devices and HDMI out to the TV, connect an HDMI cable from the blue-ray player to an HDMI input on home theater system. Then connect another HDMI cable between the home theater system and the TV. This will provide the best video and audio experience.
Another option is connect the HDMI cable from the Blue-ray player to the TV. Connect the audio output of the TV to the home theater system. (This will depend on the TV as well as the home theater system. Some TVs have digital audio outputs; others have analog outputs. If your home theater system doesn't have the same input as the TV's output, you would need a converter as well as the digital and analog audio cables. This is an example of one for digital to analog: http://www.gefen.com/kvm/dproduct.jsp?prod_id=4907 .)
If you do not want to get the best picture from the Blue-ray player and your home theater system has analog audio inputs, you can connect the composite video out to the TV. Then connect the audio outputs from the player to your home theater system. (This means only an SD picture will be provided to your TV.)
Panasonic has the manual for the DMP-BD871 here: service.us.panasonic.com/OPERMANPDF/DMPBD871-MUL.PDF .
I hope this helps. Please add a comment with the other devices in your entertainment system or their inputs/outputs. Then I can add specific information for your system and any tips for setting up the system.
Nov 26, 2012 | Panasonic DMP-BD871 Blu-ray Player with...
Hoe to connect Bose Lifestyle 25 Home Theater System speakers to onkyo SRX-508
Do you mean TX-SR508? The following should work even if that is not the exact model.
The LS25 supports ONLY analog stereo audio input and the speakers themselves are NOT desigend to be driven by anything BUT the LS25 electronics.
If you still want to use the LS25 as speakers just run an RCA cable pair from VCR / DVR Out on the Onkyo to the AUX IN on the LS25 Music Center.
http://www.retrevo.com/support/Onkyo-TX-SR508-Receivers-manual/id/23653ag910/t/2/
http://www.retrevo.com/support/Bose-Lifestyle-25-Series-I-Home-Theater-Systems-manual/id/525ag019/t/2/
Dec 28, 2010 | Bose Lifestyle 25 System
Hearing my television through my home theater system
Without knowing anything about your TV receiver all I can assume is that the TV has a least an RCA analog audio OUT. Run that to any available analog input on the HTS. make sure the TV's audio controls (hidden in a menu somewhere) is set to Fixed so the TV volume won't affect the HTS volume. Then you can turn the TV speakers off and still listen through the HTS.
You'll only get stereo this way. Ideally, you would have a digital audio source for the TV audio signal.
Jun 07, 2010 | Insignia Digital-to-Analog Converter for...
Lost several stations afyter conversion like al PBS stations. Is there something we can do?
Try rescanning for new channels. Some stations changed their Digital transmitter frequencies when they took their Analog transmitters off air. Rescanning will relocate those transmissions.
Jun 15, 2009 | Insignia Digital-to-Analog Converter for...
DTV converter automatically shits off
I just checked mine after reading your problem. I have a Magnavox converter. On the Setup Menu, there is a selection called Detail. One of the options on Detail is Auto Power Down. There are 4 choices in this: 1 hour, 2 hours, 4 hours, and OFF. Select OFF, then OK on your remote and exit the menu.
My Magnavox may be a little different, but there should be a menu item to turn it off.
Wayne
May 30, 2009 | Insignia Digital-to-Analog Converter for...
How to hookup to u dvr dish reciever to pioneer surround sound
You will need to run the video cable to the telivision. You will need to take the digital feed from the dvr and run it into the pioneer digital input.
Jan 28, 2009 | Pioneer Dolby Digital 5.1, Pro Logic II...
Bose 38 with a Scientific Atlanta 8300 HD DVR and Epson Projector
The Bose VS2 does not pass the HDMI audio. Must connect analog or digital audio direct to the corresponding audio input on the media center. Also, verify you have loaded laster Console Software revision provided by Bose.
Jan 17, 2008 | Bose Lifestyle 38 DVD Home Entertainment...
63 people viewed this question
 Grubhead
Grubhead
